Radeon Software Adrenalin 2019 Edition 19.2.1 für AMD Radeon VII
Mit der Ver­si­on 19.2.1 bringt AMD ein Update der Rade­on Soft­ware Adre­na­lin 2019 Edi­ti­on für die AMD Rade­on VII her­aus. Anders als der “nor­ma­le” 19.2.1 mit der Ver­si­ons­num­mer 18.50.17.01 trägt die­ser die Num­mer 18.50.19.01.
Radeon Software Adrenalin 2019 Edition 19.2.1 Highlights
Support For
  • AMD Rade­on VII
Known Issues
  • Rade­on Watt­Man may expe­ri­ence issues with chan­ged values fai­ling to save or load and Tuning Con­trol fea­tures fai­ling to apply.
  • Rade­on Over­lay values for Rade­on Watt­Man may fail to app­ly after Rade­on Over­lay is closed.
  • Rade­on Set­tings may expe­ri­ence an appli­ca­ti­on hang when loa­ding the per­for­mance his­to­gram in a game pro­fi­le through game manager.
  • FRTC may fail to cap frame rates when enab­led for games or may fail to disable once enab­led for a game.
  • AMD Rade­on VII may inter­mit­tent­ly expe­ri­ence a sys­tem hang when attemp­ting to per­form a time­out detec­tion and reco­very on Windows®7 sys­tem configurations.
  • AMD Rade­on VII may expe­ri­ence inter­mit­tent sys­tem sta­bi­li­ty issues on some X399 motherboards.
  • Apex Legends™ may inter­mit­tent­ly expe­ri­ence line cor­rup­ti­on on AMD Rade­on VII.
Package Contents
The Rade­on Soft­ware Adre­na­lin 2019 Edi­ti­on 19.2.1 instal­la­ti­on packa­ge con­ta­ins the following:
  • Rade­on Soft­ware Adre­na­lin 2019 Edi­ti­on 19.2.1 Dri­ver Ver­si­on 18.50.19.01 (Win­dows Dri­ver Store Ver­si­on 25.20.15019.1002)
Down­loads:
Wei­te­re Links:
