Advansus, a joint-venture company of ASUS and Advantech, announced a tiny wireless Nano-ITX barebone system for any space-limited and frequent network access applications. The NTC100-LX800 accommodates one AMD Geode LX800 @0.9W Nano-ITX motherboard which is capable of running high-quality multimedia streams up to 500 MHz clock rate. The compact system measures 170 mm x 155mm x 42mm, which square size is smaller than a Mini-ITX form factor.
Fanless & Wireless
Advansus builds the NTC100-LX800 with an ultra low power AMD LX800 processor and CS5536 Companion Chip which dissipate a total of 2.5 Watts TDP (thermal design power). The NTC100 series provides a fanless operation with one 12V DC power connector, one optional antenna via Mini-PCI slot, along with other VGA, Audio and LAN connectors. This highly reliable barebone system provides an ideal solution for IP-STB, thin client, LCD wall displays and ultra-mobile applications.
Easy operation
The NTC100 series comes with a 12V DC adapter which provides a direct power connection. The black-coated system also provides an easy operation interface equipped with a power switch, two USB ports and two LED indicators for power and HDD status on the front panel. All these features make the NTC100 series easy to set up and use.
Scalable Design
The NTC100 series design is scalable and accepts most Nano-ITX form factor mainboards for application flexibility. Customers can contact us for custom design. Our Advansus team is well experienced in design and manufacturing service (DMS) solutions that deliver tailor-made design and has broad industry expertise which provides total cost competitive solutions for OEM/ODM customers.
Features
- Onboard AMD Geode LX800 500 MHz @ 0.9 W with 128K L2 Cache & 64K L1 Cache CPU
- Scalable with Nano Options
- 24-bit TTL, 18-bit LVDS
- AC97 Audio, LAN
- 2 LEDs for Power & HDD
- 4 USB ports, 1 x CF, 1 x Mini-PCI Slot
- 12 V Power Adapter
- Optional Antenna for Wireless LAN
- Fanless Operation
About Advansus
Advansus is a joint-venture company between ASUSTek and Advantech. The company aims to provide specialized D&MS (Design and Manufacturing Services) to satisfy the demand for system longevity and cost control. In addition to its DMS business, Advansus delivers a variety of Industrial Motherboards (Nano-ITX, Mini-ITX, MicroATX, and ATX). Customers can enjoy our product and service, which combines several advantages: excellent quality, cost effectiveness, durability and long-term revision control.
