Download AMDGPU-PRO Driver 17.10 (17.10-429170)
User-News
Von eratte
Release Notes & Download
AMDGPU-PRO Driver 17.10 Highlights
Provides support for
Radeon™ RX 560 Series
Fixed Issues
Fixed an issue with Mad Max on Vulkan
Updated marketing names for Radeon™ Pro Duo and AMD FirePro™ S9300 x2.
Some performance issues with AMD Radeon™ R9 2xx cards on glmark2, tessract and gpuplot3D addressed.
Known Issues
System hangs when OpenCL attempts to allocate more than available system memory.
Deadlock when running Vulkan CTS dEQP-VK.synchronization.internally_synchronized_objects.pipeline_cache_compute test. This is caused by an issue in Linux kernel mutex, which is fixed by the following patch https://patchwork.kernel.org/patch/9443007/
Xserver crashes when running Ansys V18 application on RHEL. The issue can be avoided by running the following two commands as root before launching the app:
"ln -sf /opt/amdgpu-pro/lib64/libGL.so.1.2 /usr/lib64/libGL.so.1"
"ln -sf /opt/amdgpu-pro/lib64/libGL.so.1.2 /usr/lib64/libGL.so"
Package Contents
AMDGPU-Pro Driver
AMD Radeon™ Product Compatibility
The AMDGPU-Pro Driver is designed to be compatible with the following AMD products.
AMD Product Family Compatibility
Radeon™ RX 550 Series Graphics
Radeon™ RX 560 Series Graphics
Radeon™ RX 570 Series Graphics
Radeon™ RX 580 Series Graphics
AMD Radeon™ RX 460/470/480 Graphics
AMD Radeon™ R9 Fury/Fury X/Nano Graphics
AMD Radeon™ R9 380/380X/390/390X Graphics
AMD Radeon™ R9 285/290/290X Graphics
AMD Radeon™ R7 240/250/250X/260/260X/350
AMD Radeon™ HD7700/7800/8500/8600
AMD Radeon™ R9 360 Graphics
AMD FirePro™ W5100
AMD Radeon™ R5 340
AMD FirePro™ W4300
AMD Radeon™ Pro WX-series
AMD FirePro™ W4100
AMD FirePro™ W9100
AMD FirePro™ W2100
AMD FirePro™ W8100
AMD FirePro™ W600
AMD FirePro™ W7100
AMD FirePro™ S-Series
Compatible Operating Systems
RedHat Enterprise Linux® 7.3 (64-bit version)
RedHat Enterprise Linux® 6.8 (64-bit version)
Ubuntu 16.04.02 (64-bit version)
CentOS 7.3 (64-bit version)
CentOS 6.8 (64-bit version)
SLED/SLES 12 SP2 (64-bit version)
Base Feature Support
Supported APIs:
OpenGL 4.5 and GLX 1.4
OpenCL™1.2
Vulkan™ 1.0
VDPAU
Basic display features
Basic power management features
Notes: AMD does not perform QA validation for S4 (hibernation) function as it is highly platform dependent
KMS (Kernel Mode Setting) and ADF (Atomic Display Framework) support
GPL compliant kernel module
AMD FirePro™ Features (EDID Management and 30-bit color)
Radeon™ FreeSync support (Please refer to this FAQ for more information)
DirectGMA for OpenGL
Install script and native packages for all supported operating systems
What? Wieder kein Tahiti Support?
Aber warum sollt man sich die Mühe machen, den zu installieren statt dem normalem AMDGPU...
Und welche Kernel werden unterstützt??
