Probleme beim brennen
- Ersteller -RAMMSTEIN-
-RAMMSTEIN-
Hallo
Ich versuche schon die ganze zeit bin/cue dateien zu brennen. Leider erfolglos.
Ich bekomm meistens folgende meldung :
Cdrdao version 1.1.7-suse - (C) Andreas Mueller <andreas@daneb.de>
SCSI interface library - (C) Joerg Schilling
Paranoia DAE library - (C) Monty
Check http://cdrdao.sourceforge.net/drives.html#dt for current driver tables.
Using libscg version 'schily-0.7'
/dev/cdrecorder: HL-DT-ST DVDRAM GSA-4040B Rev: A302
ERROR: No driver found for 'HL-DT-ST DVDRAM GSA-4040B', available drivers:
cdd2600
generic-mmc
generic-mmc-raw
plextor
plextor-scan
ricoh-mp6200
sony-cdu920
sony-cdu948
taiyo-yuden
teac-cdr55
toshiba
yamaha-cdr10x
For all recent recorder models either the 'generic-mmc' or
the 'generic-mmc-raw' driver should work.
Use option '--driver' to force usage of a driver, e.g.: --driver generic-mmc
Falling back to generic-mmc
Using driver: Generic SCSI-3/MMC - Version 2.0 (options 0x0000)
Starting write at speed 12...
Pausing 10 seconds - hit CTRL-C to abort.
Process can be aborted with QUIT signal (usually CTRL-\).
WARNING: No super user permission to setup real time scheduling.
Turning BURN-Proof on
Executing power calibration...
Power calibration successful.
cdrdao: Input/output error. : scsi sendcmd: no error
CDB: 2A 00 FF FF FF 6A 00 00 1A 00
status: 0x2 (CHECK CONDITION)
Sense Bytes: 70 00 05 00 00 00 00 10 2A 00 00 90 30 05 00 00
Sense Key: 0x5 Illegal Request, Segment 0
Sense Code: 0x30 Qual 0x05 (cannot write medium - incompatible format) Fru 0x0
Sense flags: Blk 0 (not valid)
cmd finished after 0.003s timeout 180s
ERROR: Write data failed.
ERROR: Writing failed.
Auch mit K3b hab ich versucht zu brennen, da bekomme ich folgende meldung :
cdrecord gab einen unbekannten fehler zurück (Code 255)
unbekannter fehler 255
Kann mir jemand weiterhelfen ?
THX
cdd2600
generic-mmc
generic-mmc-raw
plextor
plextor-scan
ricoh-mp6200
sony-cdu920
sony-cdu948
taiyo-yuden
teac-cdr55
toshiba
yamaha-cdr10x
THX
Um da was genaues zu sagen, sind's wieder viel zu weing infos:
Du scheinst einen DVD-Brenner zu haben
Aus der Fehlermeldung
Vielleicht kann man das per Firmware-Update beheben.
Poste doch mal genau was du mit welchem Brenner auf was für Rohlinge brennen willst.
würde ich jetzt auf das falsche Format schließen, z.B. +R's bei Minus-Brennercannot write medium - incompatible format
-RAMMSTEIN-
Ich versuche nur Cd´s zu brennen.
Ja ich hab LG 4040B DVD-Brenner.
Rohlinge sind TDK,Verbatim,Sony. Firmware A302 (neuste)
Also Rohlinge und firmware kanns nicht sein , was gibt es noch für möglichkeiten ?
mj
- Austin, TX
- 2,4kg schwer
- eckig... glaub ich
- quadratisch, praktisch, gut
- kühler?
- ja
- auch
- viel bunt
- ist drin
- ist auch drin (irgendwo)
- tut manchmal tuuut
- mit aufkleber!
- nunu!
Hast du cdrecord und cdrdao auf den neuesten Stand gebracht? Damit die mit DVD-Brennern zurechtkommen müssen neue Versionen vorliegen. Ich hab hier keine Probleme mit dem Brennen von DVDs und CDs mit folgenden Versionen:
cdrecord-2.01-0.a25.1mdk
cdrdao-1.1.7-3mdk
cdrdao-1.1.7-3mdk
-RAMMSTEIN-
Hab folgende versionen :
Cdrecord-Clone 2.01a18-dvd
Ich hab mal irgendwas mit SCSI - IDE umstellung gelesen. Hat jemand von euch nach SUSE installation für den Brenner was eingestellt ?.
Ausserdem hätte ich noch eine frage: Ich hab in mein "Home" Verzeichnis, ein Ordner namens "Eigene Dateien" erstellt. Wenn ich unter konsole cd Eigene Dateien eingebe komme ich nicht in den ordner rein. Das passiert meistens wenn ich ein Ordner mit langen namen erstelle.
Kann mir jemand sagen wie ich über die konsole auf die "Eigene Dateien" Ordner rein komme.
PuckPoltergeist
Mit cd "Eigene Dateien". Leerzeichen müssen in der Shell maskiert werden.
Zu der SCSI-IDE Frage:
Ab Kernel 2.6 kann man auf IDE-Brenner direkt schreiben.
Mit dem 2.4er Kernel muss man IDE-Brenner über das SCSI-Interface ansprechen.
Aber unter SUSE bzw. anderen Distributionen sollte man sich normalerweise nicht
selber drum kümmern müssen.
Beim 2.6er ist das Brennen über SCSI weiterhin möglich.
Eine andere Möglichkeit ist, einfach "cd Eig" einzugeben und dann <TAB> zu drücken.
Dann sollte die Shell erkennen, dass du in Eigene Dateien wechseln möchtest und den
Namen vervollständigen zu "cd Eigene\ Dateien".
Ist vor allem bei längeren und komplexeren Dateinamen mit Versionsnummern sehr hilfreich.
-RAMMSTEIN-
Jep THX das mit dem " Eigene Dateien" hab ich verstanden.
Aber ich kann immmer noch nicht brennen. Hat jemand hier Suse 9.0 und LG 4040B ??
THX
THX
PuckPoltergeist
Jein. IDE-SCSI hat noch immer keinen Maintainer (es sei denn, es hat sich da in den letzten Tagen was getan), und zuletzt war es immer noch broken. Soll heißen es kann funktionieren, muß aber nicht.
Luzypher
- "Stadt der 1000 Feuer"
- Intel Core2Quad Q6600
- Gigabyte GA-EP35-DS4
- Original boxed Lüfter
- 4 Stck. 2048 MB OCZ "Reaper" DDR2-800 CL5
- Club 3D Radeon™ HD3850 512 MB "OC-Edition"
- 19 Zoll TFT, EIZO Flexscan S1901
- 2 Stck. 500 GB Seagate Barracuda 7200.10
- Sony Optiarc AD-7200S, TSST Corp SH-D163B
- Club 3D Theatron Agrippa DTS 7.1
- Chieftec Bravo-Serie BH-01B-B-B
- Enermax Liberty "ELT400AWT"
- Windows 7 Ultimate 64 Bit
- Internet Explorer 10
- Scanner: Nikon Coolscan V ED KB-Filmscanner , Drucker: Epson Stylus Photo R800
Hi folks!
Die ide-scsi Emulation muss auf jeden Fall zum Brennen aktiviert werden. Ich nutze unter Suse Linux 8.2 und 9.0 den LG GSA-4081B und nen Plex PX-708A. Beide funktionieren mit cdrecord bzw. cdrdao und dvd-rw Tools und dem Front-End k3b sehr gut.
Du solltest für das Schreibgerät den verwendeten Treiber (unter "Geräte") von Hand auf "generic-mmc" umstellen, die automatische Auswahl ("auto") funktioniert leider nicht (immer).
Bei bin und cue dateien gilt zu beachten, das man die bin nicht einfach als iso-Image oder per Daten-CD-projekt brennen kann. In "Extras" gibt es unter CD eine Option "bin/cue Abbilddatei brennen", unter der man dann die cue auswählt (passend zum bin).
Also emphfehle ich dir einfach mal diese Punkte durchzugehen und die ide-scsi Emulation zu überprüfen. In den Bootoptionen (von lilo oder grub) kann man die Emu mit "ide-scsi=hdc" für das jeweilige Laufwerk (hier: hdc = Secondary Master) aktivieren. In der /etc/sysconfig/kernel muss allderings das "ide-scsi" Modul eingetragen sein.
Bei mir funktionierts jedenfalls seid k3b 0.10.x einwandfrei.
cu ...
Luzy
cu ...
Luzy
PuckPoltergeist
Falsch! Mit 2.6er Kernel und aktuellem cdrecord/cdrdao benötigst du ide-scsi nicht mehr. Es wird sogar dringend davon abgeraten dieses zu nutzen (Gründe, siehe weiter oben).
Luzypher
Ups, das habe ich übersehen. Bin vom 2.4er ausgegangen. Alles weitere würd ich trotzdem mal überprüfen, insbesondere mit dem cdrdao-Treiber, da hatte ein Kollege von mir auf arge probleme auf "auto", die sich mit einer manuellen Wahl beheben ließen.Original geschrieben von PuckPoltergeist
cu ...
Luzy
Cybered
- Unimatrix-Zero
- Spin;Seti;QMC
- SETI
- Athlon 64 X2 3800+
neue CDRDAO für Woody her. Müßte ne Version höher als 1.1.7 sein. Habe bei BAckports. apt-get.org und rpmseek geschaut aber leider nix gefunden.
Cybered
Cybered
Luzypher
Hi folks!
Soweit ich weiss gibt es keine (offizielle) neuere Version als 1.1.7!
Vielleicht hilft dir die Homepage http://cdrdao.sourceforge.net/ weiter.
cu ...
Luzy
cu ...
Luzy
- 7K
- 11K
