Download Radeon™ Software Adrenalin 2019 Edition 19.6.2 BETA verfügbar.
- Ersteller eratte
User-News
Von eratte
Hinweis: Diese "User-News" wurde nicht von der Planet 3DNow! Redaktion veröffentlicht, sondern vom oben genannten Leser, der persönlich für den hier veröffentlichten Inhalt haftet.Release Notes & Download
Filename z.B.: Win10-64Bit-Radeon-Software-Adrenalin-2019-Edition-19.6.2-June17.exe
Radeon Software Adrenalin 2019 Edition 19.6.2 Highlights
Added Vulkan™ Support
VK_EXT_host_query_reset
Allows resets of queries from the host, rather than on the GPU.
VK_EXT_full_screen_exclusive
Gives applications explicit control over exclusive full-screen modes (this is for instance useful for HDR support).
VK_AMD_display_native_hdr
Exposes FreeSync2 capabilities for improved HDR support.
VK_EXT_separate_stencil_usage
Separates the usage flags for depth/stencil aspects of a depth/stencil image making it possible to restrict/expand the usage relative to the depth aspect.
VK_KHR_uniform_buffer_standard_layout
Provides more flexible alignment for uniform buffers, enabling among other things, the usage of std430 layouts in Vulkan.
Fixed Issues
Wireless VR may experience performance drops across multiple game titles on some Radeon RX 400 and Radeon RX 500 series graphics products.
Performance Metrics Overlay may fail to enable or may be disabled when toggling Radeon Overlay while in game.
A TDR may occur when exiting some gaming applications that are using DirectX®12 API when multiple displays are connected and in clone mode.
Microsoft® PIX tool may fail when a GPU is connected using AMD XConnect™ Technology.
Crackdown™3 may experience an application or game hang on Radeon R7 370 series graphics products.
Known Issues
Radeon ReLive streaming and uploading of videos and other content to Facebook™ is currently unavailable.
ASUS TUF Gaming FX505 may experience discrete GPU connection issues with devices disappearing from device manager when the system is idle.
Performance Metrics Overlay and Radeon WattMan gauges may experience inaccurate fluctuating readings on AMD Radeon VII.
ACER Swift 3 with AMD Ryzen Processor may experience system instability when upgrading to Radeon Software Adrenalin 2019 Edition 19.6.2 using the Custom Clean Installation option.
Graphics driver may not uninstall correctly when using the express uninstall option on some Ryzen APUs.
Important Notes
AMD Ryzen™ Mobile Processors with Radeon™ Vega Graphics FAQ for Radeon Software Adrenalin 2019 Edition can be found here.
Package Contents
The Radeon Software Adrenalin 2019 Edition 19.6.2 installation package contains the following:
Radeon Software Adrenalin 2019 Edition 19.6.2 Driver Version 19.20.01.07 (Windows Driver Store Version 26.20.12001.7006)
Radeon Product Compatibility
Radeon Software Adrenalin Edition 19.6.2 is compatible with the following AMD Radeon products.
Radeon™ VII Radeon™
RX 500 / Radeon 500X Series Graphics
Radeon RX Vega Series Graphics
Radeon™ RX 400 Series Graphics
AMD Radeon™ Pro Duo
AMD Radeon™ R7 200 Series Graphics
AMD Radeon™ R7 300 Series Graphics
AMD Radeon™ R5 300 Series Graphics
AMD Radeon™ R9 Fury Series Graphics
AMD Radeon™ R5 200 Series Graphics
AMD Radeon™ R9 Nano Series Graphics
AMD Radeon™ R9 300 Series Graphics
AMD Radeon™ R9 200 Series Graphics
AMD Radeon™ HD 7700 - HD 7900 Series Graphics
AMD Radeon™ HD 8500 - HD 8900 Series Graphics
Mobility Radeon™ Product Compatibility
Radeon Software Adrenalin Edition 19.6.2 is a notebook reference graphics driver with limited support for system vendor specific features.
AMD Radeon™ R7 M400 Series Graphics
AMD Radeon™ R7 M200 Series Graphics
AMD Radeon™ R9 M300 Series Graphics
AMD Radeon™ R5 M200 Series Graphics
AMD Radeon™ R7 M300 Series Graphics
AMD Radeon™ R5 M300 Series Graphics
AMD Radeon™ R9 M200 Series Graphics
AMD Radeon™ HD 8500M - HD 8900M Series Graphics
AMD Radeon™ HD 7700M - HD 7900M Series Graphics
AMD Processors with Radeon Graphics Product Compatibility
DESKTOP
AMD Ryzen™ Processors with Radeon™ Vega graphics
AMD Ryzen™ PRO Processors with Radeon™ Vega graphics
AMD Athlon™ Processors with Radeon™ Vega Graphics
AMD Athlon™ PRO Processors with Radeon™ Vega Graphics
AMD A-Series APUs with Radeon™ R4, R5, R6, or R7 Graphics
AMD A-Series™ PRO processors with Radeon™ graphics
AMD Athlon™ Series APUs with Radeon™ R3 Graphics
AMD Sempron™ Series APUs with Radeon™ R3 Graphics
MOBILE
AMD Ryzen™ Mobile processors with Radeon™ Vega graphics
AMD Athlon™ Mobile Processors with Radeon™ Vega Graphics
AMD A-Series and FX processors with Radeon graphics
AMD Ryzen™ PRO Mobile processors with Radeon™ Vega graphics
AMD Athlon™ PRO Mobile processors with Radeon™ Vega graphics
AMD Pro A-Series APUs with Radeon™ R5 or R7 Graphics
AMD FX-Series APUs with Radeon™ R7 Graphics
AMD E-Series APUs with Radeon™ R2 Graphics
AMD Radeon™ HD 8180 - HD 8400 Series Graphics
Compatible Operating Systems
Radeon Software Adrenalin Edition 19.6.2 is designed to support the following Microsoft® Windows® platforms. Operating System support may vary depending on your specific AMD Radeon product.
Windows® 10 64-bit version
Windows 7 64-bit version with SP1 or higher
Fixed Issues
Known Issues
Important Notes
Package Contents
Radeon™ VII Radeon™
AMD Radeon™ Pro Duo
DESKTOP
MOBILE
psychocyberdisc
- Mystery Lake
- OMEN by HP Laptop 16-c0xxx
- 230 Watt
▼50 Mbit/s
▲25 Mbit/s
Die Dateien wurden ausgetauscht.
https://www.amd.com/en/support/apu/...a12-apu-for-laptops/7th-gen-amd-pro-a12-9800b
win10-64bit-radeon-software-adrenalin-2019-edition-19.6.2-june24.exe
win7-64bit-radeon-software-adrenalin-2019-edition-19.6.2-june24.exe
- Je nach Gusto
- AMD Ryzen 9 5900X
- ASRock B550
- 2x 16 GB DDR4 3200
- GeForce GTX 1650
- 27 Zoll Acer + 24 Zoll DELL
- Samsung 980 Pro 256 GB
- diverse
- Fractal Design R5
- Logitech Cordless Desktop
- Logitech G502
- Firefox, Vivaldi
- ▼250 MBit ▲40 MBit
Hm,
ich hatte den zuerst extra nicht gepostet, da es mit der ursprünglichen 19.6.2 Probleme gegeben haben soll.
Wenn ich das von der E3 richtig in Erinnerung habe, kommt zum Launch dann sowieso ein 19.7.1 mit Navi-Support.
Offiziell bei AMD verfügbar dann auch eine NEWS - das meine Meinung.
psychocyberdisc
- Mystery Lake
- 230 Watt
▼50 Mbit/s
▲25 Mbit/s
Nun gibt's die Version 19.6.3 (ohne WHQL).
https://www.amd.com/en/support/kb/release-notes/rn-rad-win-19-6-3
