"No GPUs usable found" unter Ubuntu (14.04)
- Ersteller Raspo
Raspo
- Hamburg
- Oneplus 6 64GB
- Ryzen 3900X@65W
- Asus Crosshair VI Hero
- be quiet silent loop 280
- Sapphire Pulse Vega 56
- Philips 436M6
- Samsung 960 Evo
- onboard @ Dali Zensor 1
- Phanteks Evolv ATX TG
- Win 10 64bit Pro
Hi, folgendes Problem.
Boinc erkennt unter Ubuntu die 2 Radeon 7750 im System nicht:
So 19. duben 2014, 18:13:27 CEST | | Starting BOINC client version 7.2.42 for x86_64-pc-linux-gnu
So 19. duben 2014, 18:13:27 CEST | | log flags: file_xfer, sched_ops, task
So 19. duben 2014, 18:13:27 CEST | | Libraries: libcurl/7.35.0 OpenSSL/1.0.1f zlib/1.2.8 libidn/1.28 librtmp/2.3
So 19. duben 2014, 18:13:27 CEST | | Data directory: /var/lib/boinc-client
So 19. duben 2014, 18:13:27 CEST | | OpenCL CPU: AMD Opteron(tm) Processor 6176 (OpenCL driver vendor: Advanced Micro Devices, Inc., driver version 1411.4 (sse2), device version OpenCL 1.2 AMD-APP (1411.4))
So 19. duben 2014, 18:13:27 CEST | | No usable GPUs found
So 19. duben 2014, 18:13:27 CEST | | Host name: G34
So 19. duben 2014, 18:13:27 CEST | | Processor: 24 AuthenticAMD AMD Opteron(tm) Processor 6176 [Family 16 Model 9 Stepping 1]
So 19. duben 2014, 18:13:27 CEST | | Processor features: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp lm 3dnowext 3dnow constant_tsc rep_good nopl nonstop_tsc extd_apicid amd_dcm pni monitor cx16 popcnt lahf_lm cmp_legacy svm extapic cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw ibs skinit wdt nodeid_msr hw_pstate npt lbrv svm_lock nrip_save pausefilter
So 19. duben 2014, 18:13:27 CEST | | OS: Linux: 3.13.0-19-generic
So 19. duben 2014, 18:13:27 CEST | | Memory: 31.36 GB physical, 32.00 GB virtual
So 19. duben 2014, 18:13:27 CEST | | Disk: 12.39 GB total, 7.87 GB free
Fglrxinfo gibt das zurück:
display: :0 screen: 0
OpenGL vendor string: Advanced Micro Devices, Inc.
OpenGL renderer string: AMD Radeon R7 200 Series
OpenGL version string: 4.3.12798 Compatibility Profile Context 13.35.1005
Wer kann helfen?
Wer kann helfen?
heizzr
- Freiburg
- milkyway; Einstein; TN Grid; WCG;
- milkyway
- Ryzen 1700; Ryzen 2700; Vega 56 & VII; 6x Odroid U3; 4X Odroid C2
- Ryzen 1700 @ Stock
- MSI B350M Mortar
- Boxed
- 2X 8GB G.Skill Trident Z DDR4-3200 CL16
- Vega 56
- 28" Samsung U28E590D 4K Freesync
- 256GB ADATA Ultimate SU800
- 2TB WD Red WD20EFRX
- LG BH16NS55 Blu-ray Combo
- Realtek ALC 892 onbord
- Lian Li PC-A76wx
- 650W be quiet! dark power pro P9
- Win 7 64bit
Wie hier schon beschrieben Boinc beenden und den Dienst stoppen und wieder starten:
Dannach sollte die Grafikkarte erkannt werden.
Wenn Du den Betatreiber installiert hast, musst Du eventuell noch vorher das App-SDK 2.9 Dingens für OpenCL support installieren.
APP SDK Download
Code:
sudo /etc/init.d/boinc-client stop
sudo /etc/init.d/boinc-client start
APP SDK Download
Raspo
- Hamburg
- Oneplus 6 64GB
- Ryzen 3900X@65W
- Philips 436M6
- Samsung 960 Evo
- Win 10 64bit Pro
Danke, Heizzr.
Das hat etwas geholfen.
Jetzt kommt das:
Ne 20. duben 2014, 13:48:36 CEST | | Starting BOINC client version 7.2.42 for x86_64-pc-linux-gnu
Ne 20. duben 2014, 13:48:36 CEST | | log flags: file_xfer, sched_ops, task
Ne 20. duben 2014, 13:48:36 CEST | | Libraries: libcurl/7.35.0 OpenSSL/1.0.1f zlib/1.2.8 libidn/1.28 librtmp/2.3
Ne 20. duben 2014, 13:48:36 CEST | | Data directory: /var/lib/boinc-client
Ne 20. duben 2014, 13:48:36 CEST | | CAL: ATI GPU 0: AMD Radeon HD 7700 series (Capeverde) (CAL version 1.4.1848, 1024MB, 743MB available, 2048 GFLOPS peak)
Ne 20. duben 2014, 13:48:36 CEST | | Host name: G34
Ne 20. duben 2014, 13:48:36 CEST | | Processor: 24 AuthenticAMD AMD Opteron(tm) Processor 6176 [Family 16 Model 9 Stepping 1]
Ne 20. duben 2014, 13:48:36 CEST | | Processor features: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp lm 3dnowext 3dnow constant_tsc rep_good nopl nonstop_tsc extd_apicid amd_dcm pni monitor cx16 popcnt lahf_lm cmp_legacy svm extapic cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw ibs skinit wdt nodeid_msr hw_pstate npt lbrv svm_lock nrip_save pausefilter
Ne 20. duben 2014, 13:48:36 CEST | | OS: Linux: 3.13.0-24-generic
Ne 20. duben 2014, 13:48:36 CEST | | Memory: 31.36 GB physical, 32.00 GB virtual
Ne 20. duben 2014, 13:48:36 CEST | | Disk: 12.39 GB total, 7.17 GB free
Ne 20. duben 2014, 13:48:36 CEST | | Local time is UTC +2 hours
Ne 20. duben 2014, 13:48:36 CEST | | Config: GUI RPCs allowed from:
Ne 20. duben 2014, 13:48:36 CEST | | No general preferences found - using defaults
Ne 20. duben 2014, 13:48:36 CEST | | Reading preferences override file
Ne 20. duben 2014, 13:48:36 CEST | | Preferences:
Ne 20. duben 2014, 13:48:36 CEST | | max memory usage when active: 25687.39MB
Ne 20. duben 2014, 13:48:36 CEST | | max memory usage when idle: 28898.31MB
Ne 20. duben 2014, 13:48:36 CEST | | max disk usage: 7.07GB
Ne 20. duben 2014, 13:48:36 CEST | | (to change preferences, visit a project web site or select Preferences in the Manager)
Ne 20. duben 2014, 13:48:36 CEST | | gui_rpc_auth.cfg is empty - no GUI RPC password protection
Heißt doch, nur 1 Graka wurde erkannt und CAL ist doch veraltet, oder?
Jetzt kommt das:
Eventuell hilft Dir das weiter. Dort sind einige Beiträge zu Boincproblemen mit Cal und OpenCl unter Linux.
Ab Post
tomme
Am 15. Januar 2014 um 09:57 Uhr veröffentlicht
http://www.sebastian-siebert.de/201...iber-amd-catalyst-13-12-als-rpm-installieren/
Ab Post
tomme
heizzr
- Freiburg
- milkyway
- MSI B350M Mortar
- Boxed
- Vega 56
- Lian Li PC-A76wx
- Win 7 64bit
Du musst noch folgendes in die cc_config.xml schreiben:
Dann sollte es auch beide GPUs erkennen
http://boincfaq.mundayweb.com/index.php?language=1&view=91
Code:
<cc_config>
<options>
<use_all_gpus>1</use_all_gpus>
</options>
</cc_config>
Raspo
- Hamburg
- Oneplus 6 64GB
- Ryzen 3900X@65W
- Philips 436M6
- Samsung 960 Evo
- Win 10 64bit Pro
@Pollux
Danke für den Link. Nur bin ich Linux-DAU und komme da nicht weiter.
So richtig schreiben sie auch nicht woran es liegen kann.
@Heizzr:
Wie kann ich in die CC_config.xml schreiben?
Ist schreibgeschützt.
Wie kann ich denn diesen Stop/startbefehl automatisieren?
@Heizzr:
unterstudienrat
Moderator (DC)
- Anne Elbe
- SIMAP, F@H, POEM
- F@H; SIMAP
- Opteron170, 175
- AC WaKü
@Heizzr:
Bin zwar kein Linuxer, aber eigendlich solltest Du BOINC ganz ausschalten, dann müßtest Du dort auch schreiben können.
D.U.
heizzr
- Freiburg
- milkyway
- MSI B350M Mortar
- Boxed
- Vega 56
- Lian Li PC-A76wx
- Win 7 64bit
Mit Admin Rechten geht das:
Code:
sudo gedit /etc/boinc-client/cc_config.xml
Man kann wohl in den Boinc Startup-Script eine Verzögerung einbauen
Code:
sudo gedit /etc/init.d/boinc-client
Trage in diese Datei irgendwo ( eher am Anfang ) den Befehl sleep 6 ein.
Dadurch bekommt der Grafiktreiber beim Systemstart die Zeit sich vor dem Boinc-Dienst zu initialisieren.
Ich hab das aber selber noch nicht ausprobiert, von daher musst Du mal schauen ob das funktioniert.
Raspo
- Hamburg
- Oneplus 6 64GB
- Ryzen 3900X@65W
- Philips 436M6
- Samsung 960 Evo
- Win 10 64bit Pro
cc_config.xml habe ich entsprechend angepasst, hat aber nichts gebracht. Sieht so aus:
This is a minimal configuration file cc_config.xml of the BOINC core client.
For a complete list of all available options and logging flags and their
meaning see: http://boinc.berkeley.edu/trac/wiki/ClientMessages
<cc_config>
<options>
</options>
<log_flags>
<task>1</task>
<file_xfer>1</file_xfer>
<sched_ops>1</sched_ops>
</log_flags>
</cc_config>
Edit:
Ich dachte, vielleicht liegts daran, dass das System die 2. Graka nicht erkennt. Das scheint aber zu klappen (mit lshw):
*-display
Beschreibung: VGA compatible controller
Produkt: Cape Verde PRO [Radeon HD 7750 / R7 250E]
Hersteller: Advanced Micro Devices, Inc. [AMD/ATI]
Physische ID: 0
Bus-Informationen: pci@0000:04:00.0
Version: 00
Breite: 64 bits
Takt: 33MHz
Fähigkeiten: pm pciexpress msi vga_controller bus_master cap_list rom
Konfiguration: driver=fglrx_pci latency=0
Ressourcen: irq:78 memory:d0000000-dfffffff memory:fbf80000-fbfbffff ioport:e000(Größe=256) memory:fbfc0000-fbfdffff
*-display
Physische ID: 0
Bus-Informationen: pci@0000:02:00.0
Version: 00
Breite: 64 bits
Takt: 33MHz
Ressourcen: irq:79 memory:c0000000-cfffffff memory:fbd80000-fbdbffff ioport:c000(Größe=256) memory:fbdc0000-fbddffff
*-display
Produkt: ASPEED Graphics Family
Hersteller: ASPEED Technology, Inc.
Physische ID: 1
Bus-Informationen: pci@0000:01:01.0
Version: 10
Breite: 32 bits
Takt: 33MHz
Fähigkeiten: pm vga_controller cap_list
Konfiguration: driver=ast latency=0
Ressourcen: irq:21 memory:fb000000-fb7fffff memory:fbce0000-fbcfffff ioport:bc00(Größe=128)
Das Einfügen in sleep 6 hatte leider keinen Effekt.
<cc_config>
<options>
</options>
<log_flags>
<task>1</task>
</log_flags>
</cc_config>
Edit:
*-display
Physische ID: 0
Version: 00
Breite: 64 bits
Takt: 33MHz
*-display
Physische ID: 0
Version: 00
Breite: 64 bits
Takt: 33MHz
*-display
Physische ID: 1
Version: 10
Breite: 32 bits
Takt: 33MHz
heizzr
- Freiburg
- milkyway
- MSI B350M Mortar
- Boxed
- Vega 56
- Lian Li PC-A76wx
- Win 7 64bit
Ok, das mit sleep 6 hab ich jetzt auch gerade ausprobiert und es hat bei mir leider auch nicht funktioniert. Musst es halt händisch machen, Dein Server wird ja wahrscheinlich 24/7 laufen, von daher wird es ja nicht so häufig vorkommen.
Ansonsten solltest Du aber zumindest erst mal eine Grafikkarte zum rechnen bringen.
Wenn bei Dir also weiterhin nur was von CAL:ATI GPU 0: AMD Radeon HD7700....steht und nicht:
Mo 21 Apr 2014 13:55:58 CEST | | CAL: ATI GPU 0: AMD Radeon HD 7700 series (Capeverde) (CAL version 1.4.1848, 1024MB, 767MB available, 2048 GFLOPS peak)
Mo 21 Apr 2014 13:55:58 CEST | | OpenCL: AMD/ATI GPU 0: AMD Radeon HD 7700 series (Capeverde) (driver version 1411.4 (VM), device version OpenCL 1.2 AMD-APP (1411.4), 1024MB, 767MB available, 2048 GFLOPS peak)
Mo 21 Apr 2014 13:55:58 CEST | | OpenCL CPU: AMD Opteron(tm) Processor 3280 (OpenCL driver vendor: Advanced Micro Devices, Inc., driver version 1411.4 (sse2,avx,fma4), device version OpenCL 1.2 AMD-APP (1411.4))
Musst Du noch das App-SDK 2.9 installieren:
http://developer.amd.com/tools-and-sdks/heterogeneous-computing/amd-accelerated-parallel-processing-app-sdk/downloads/
http://developer.amd.com/download/AMD_APP_SDK_Installation_Notes.pdf
Damit sollte dann zumindest mal eine GPU rechnen.
( Boinc Stopp / Start nicht vergessen )
Code:
tar -xvzf AMD-APP-SDK-v2.8-lnx64.tgz
sudo ./Install-AMD-APP.sh
Raspo
- Hamburg
- Oneplus 6 64GB
- Ryzen 3900X@65W
- Philips 436M6
- Samsung 960 Evo
- Win 10 64bit Pro
Okay, also mit den GPUs ist es unter Linux besser geworden aber nicht gut.
Pentathlon also nur ggf. CPU-Projekte unter Linux, wenn sie schneller sind...
heizzr
- Freiburg
- milkyway
- MSI B350M Mortar
- Boxed
- Vega 56
- Lian Li PC-A76wx
- Win 7 64bit
So schnell aufgeben gibt es nicht.
Ich hab heute parallel meinen Server mit Ubuntu 14.04 aufgesetzt, den neuesten ATI Beta-Treiber & im Anschluß das App-SDK 2.9 drauf, den Boincdienst kurz gestoppt, und jetzt läuft Einstein auf der GPU.
Das kriegen wir bei Dir auch hin, nur wo genau liegt jetzt Dein Problem?
Raspo
- Hamburg
- Oneplus 6 64GB
- Ryzen 3900X@65W
- Philips 436M6
- Samsung 960 Evo
- Win 10 64bit Pro
Hast schon recht, aber wenn ich nur eine Graka ansprechen kann, brauchen wir nicht weiter machen.
Dann ist Windows immer besser.
EselTreiber
- Hirschberg, BaWü
- Einstein@home
- arxtr: 3960X+RX550+3080 arx03: 1920X+1030GT arx02: Xeon 2697 v3 full Turbo arx04: 3900X+RX580
- HP ProBook 6460b
- AMD 3960X - 200W
- AsRock TRX40 Creator
- Watercool HK IV TR
- 4 x 16 GB G.Skill 3800 15-15-8-12-30
- RTX 3080
- Benq BL2710T, 2560x1440
- Samsung 251 512GB, Samsung 970 Evo plus 512GB, Samsung 830 256GB
- Western Digital Green 1.5 TB
- Onboardzeugs
- Fractal Define S
- Fractal Design Ion+ 660W
- Manjaro
- S.M.S.L. Tripath Class-D Amp, Lautsprecherbau.de BluesBox PC 15
Also ich habe ein System mit 2 AMD GraKas am Laufen gehabt unter Linux. Jedoch hatte ich oft Probleme damit. Zumindest mit unterschiedlichen Chipgenerationen. Hatte ich eine HD6970 und eine HD7770 drin, lief die 7770 problemlos, während die 6970 meist nach wenigen Minuten auf 99% Auslastung hing und trotzdem nichts gerechnet hat. Soweit meine Erfahrungen bei Einstein@home.
EselTreiber
- Hirschberg, BaWü
- Einstein@home
- HP ProBook 6460b
- AMD 3960X - 200W
- RTX 3080
- Onboardzeugs
- Fractal Define S
- Manjaro
Ein hübscher Leidensbericht. Was auch noch interessant sein könnte, ist die Möglichkeit des OpenCL-Betriebs ohne einen laufenden X-Server bzw angeschlossenen Monitor. Sodass man alles per SSH machen kann.
Da ist folgendes für Gnome (gdm) Interessant:
http://www.mayankdaga.com/running-opencl-applications-remotely-on-amd-gpus/
Für lightdm muss man das etwas modifizieren:
http://hiraku0n.blogspot.de/2012/09/remote-login-to-gpu-on-ubuntu-precise.html
€: Ich könnte mal heute Abend eine Schritt-für-Schritt-Anleitung fürs aktuelle Ubuntu schreiben.
Raspo
- Hamburg
- Oneplus 6 64GB
- Ryzen 3900X@65W
- Philips 436M6
- Samsung 960 Evo
- Win 10 64bit Pro
DAU-sichere Anleitungen sind immer willkommen.
TAL9000
- nähe Giessen
- OnBoard
- VERTI WM25
▼50 MBit
▲10 MBit
Ich weis, alt, aber aktuell auch am suchen...
Habe es schon hin bekommen aber was ich da in die Bash gehämmert habe war garantiert nicht alles sinnvoll
Würde mich über eine Noob feste Anleitung sehr freuen!
TAL9000
Sabroe SMC
- Castrop-Rauxel
- AMD Ryzen 9 7950X3D
- Asus TUF Gaming X670E Plus
- Noctua NH-D15 chromax.black
- irgendeins
- Razer BlackWidow Ultimate
- Zowie Gaming Mouse FK1
▼500 Mbit/s
▲25 Mbit/s
TAL9000
Haste den Thread gelesen?
http://www.planet3dnow.de/vbulletin...tart-bringen?p=5014010&viewfull=1#post5014010
Nvidia: http://www.linuxmintusers.de/index....eiber_installieren_(von_nvidia.de)_in_Mint_17
TAL9000
- nähe Giessen
- OnBoard
- VERTI WM25
▼50 MBit
▲10 MBit
hatte nicht funktioniert bei mir, dann aber aus ner anderen Ecke noch mehr eingetippt und auf gings, seit dem nicht mehr reproduziert können in ruhe, es hat immer die OpenCL Erkennung von Boinc versagt, CAL hat er immer schnell gefunden, des wegen es mit Sysmlinks auf die Libs und kopieren versucht ->
Bei mir tun sich als mehr baustellen auf, denke nach dem Penta senke ich mein DC erstmal auf das Minimum...
Sabroe SMC
- Castrop-Rauxel
- irgendeins
▼500 Mbit/s
▲25 Mbit/s
2 meiner System sind schon verkauft
