X und Radeon
Rhodanos
11.11.2001
3.090
3
/usr/local/karlsruhe
So, hab mein Debian neu drauf, KDE 3.1 ist installiert und die Gnome Libs draussen. Trotzdem krieg ich X nur mit den VESA Treibern ans laufen. Warum, wo ist der Fehler? Hier die Config :
Section "Files"
FontPath "unix/:7100" # local font server
# if the local font server has problems, we can fall back on these
FontPath "/usr/lib/X11/fonts/misc"
FontPath "/usr/lib/X11/fonts/cyrillic"
FontPath "/usr/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/Type1"
FontPath "/usr/lib/X11/fonts/Speedo"
FontPath "/usr/lib/X11/fonts/100dpi"
FontPath "/usr/lib/X11/fonts/75dpi"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "keyboard"
Option "CoreKeyboard"
Option "XkbRules" "xfree86"
Option "XkbModel" "pc105"
Option "XkbLayout" "de"
Option "XkbVariant" "nodeadkeys"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Device" "/dev/psaux"
Option "Protocol" "PS/2"
Option "Emulate3Buttons" "true"
Option "ZAxisMapping" "4 5"
EndSection
#Section "InputDevice"
# Identifier "Generic Mouse"
# Driver "mouse"
# Option "SendCoreEvents" "true"
# Option "Device" "/dev/input/mice"
# Option "Protocol" "ImPS/2"
# Option "Emulate3Buttons" "true"
# Option "ZAxisMapping" "4 5"
#EndSection
Section "Device"
Identifier "Radeon 8500"
Driver "radeon"
EndSection
Section "Monitor"
Identifier "Generic Monitor"
HorizSync 30-98
VertRefresh 50-160
Option "DPMS"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "Radeon 8500"
Monitor "Generic Monitor"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes "1024x768" "800x600" "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
# InputDevice "Generic Mouse"
EndSection
Section "DRI"
Mode 0666
EndSection
### END DEBCONF SECTION
Rhodanos
also ich weiss nicht obs auch ohne geht, aber in der Device Section hab ich immer die BusID stehen, bei ner Agp Karte ist die eigendlich immer "PCI:1:0:0"
also
BusID "PCI:1:0:0"
in die Device Section, was gibt denn eigentlich der Server für einen Fehler aus?
also
BusID "PCI:1:0:0"
Hat damit nichts zu tun. Debian woody hat default nur XFree4.1 dabei. Für die Radeon8500 ist aber mind. 4.2 erforderlich. Backports gibt es von Adrain Bunk auf
deb http://www.fs.tum.de/~bunk/debian woody/bunk-1 main contrib non-free
(das ist schon der komplette Eintrag für die sources.list)
puck
naja, weil er Kde3.1 benutzte bin ich davon ausgegangen er butzt, sarge oder sid :)
Den Eintrag hatte ich lange vorher schon gemacht ;) Man lernt dazu. Eigentlich müßte ich jetzt die 4.2er Version drauf haben. Wie kann ich das feststellen?
Rhodanos
Es gibt "offizielle" 3.1-Verionen für woody, direkt bei KDE. Damit hat woody nen aktuelleres KDE als sarge;)
ich benutz kein KDE und auch kein sarge ;D
dachte das nur :)
Hmm, ich hab nochmal nachgeschaut. Xfree ist in der Version 4.2 drauf, daran sollte es eigentlich nicht liegen. Sobald ich als Treiber Radeon oder auch nur ATI auswähle, ist es vorbei und nichts geht mehr. VESA ist so grausam langsam, hat evtl. noch jemand ne Idee?
Rhodanos
Was heißt "nichts geht mehr"? Was sagt das log dazu?
In der config fehlt noch die Modules-section, aber das dürfte kein Grund sein, daß der ATi-Treiber nicht geht.
puck
Was passiert mit dem ATi-Treiber, bleibt X hängen, oder landest du wieder auf der console. Wenn X hängen bleibt, kannst du es abschießen (Strg+Alt+Backspace)?
puck
Ich glaub ich hab ihn, den Fehler. Aus irgend einem Grund, der sich mir noch nicht so ganz erschließt, glaubt der ATi-Treiber bei dir, daß ein LCD angeschlossen ist. Ich sehe im Moment zwei Möglichkeiten da was zu drehen:
1.) Schieb mal nach
Section "Files"
# FontPath "unix/:7100" # local font server
FontPath "/usr/share/fonts/TrueType"
FontPath "/usr/lib/X11/fonts/CID"
EndSection
folgendes ein:
Section "Module"
Load "GLcore"
Load "bitmap"
Load "dbe"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "record"
Load "speedo"
Load "type1"
Load "vbe"
EndSection
2.) Melde dich nochmal, nach dem Versuch mit 1.). Der Treiber lief doch schonmal bei dir, oder? Ich will da ungern was erzwingen.
puck
Ja, der Treiber - ich hoffe es war der Radeon, und nicht der normale ATI - lief schon mal. Deswegen verstehe ich im Mom auch nicht, warum der rumzickt. Die Einstellungen sind wie vor der Neuinstallation. Werd ich dann machen, aber erst was essen. Schon mal in den anderen Thread geschaut? Ich glaub es immer noch nicht.
Rhodanos
So, X schmiert dabei wieder ab. Als Fehler kriege ich :
EE Radeon: no valid mode found for this DFP/LCD und
EE Screen(s) found, but no one have a usable configuration.
Rhodanos
Edit : Mal noch was zu X. Du hast imho gemeint, mit strg, alt + backspace krieg ich den abgeschossen, oder liege ich da falsch. Das Prob ist, dass ich jedes Mal nach Änderungen an der Config neu booten muss. Ich melde mich unter X ab, lande dann ja aber wieder im Anmeldebildschirm. Per strg, alt F1 zur Konsole, Dateien rumkopiert und dann ists rum. Will ich X per startx wieder aufrufen, geht nix, weil X noch läuft. Also reboot. Geht doch bestimmt auch einfacher, oder?
Rhodanos
Natürlich. Wenn ich nicht irre, hast du den kdm als displaymanager. Da gibt es das PullDown-Menu Menu. Darunter findest du die Optionen "Textkonsole" und "X neu starten". Als Tastenkürzel wären das Alt+K und Alt+X. Du kannst denn kdm auch ganz deaktivieren. Am besten nutzt du dazu das tool rcconf. Ist im gleichnamigen Paket. Da machst du einfach den * vor kdm weg und er startet nicht mehr.
So jetzt zurück zum X-Problem. Wenn er so nicht will, wird er halt gezwungen. Mach mal folgenden Änderung:
Section "Device"
Driver "radeon"
Option "CrtScreen"
EndSection
sprich die Option da noch einfügen. Dann sollte es funktionieren.
puck
Ich verstehe allerdings trotzdem nicht, warum X der Meinung ist, bei dir sein ein LCD angeschlossen. Es hatte ja vorher geklappt und bei mir läuft es auch ohne die Option.
puck
Nein, nicht beschleunigt. Nur in Software. Du kannst ja mal glxgears ausführen (aus der Konsole unter KDE). Da müßtest du so 200-300fps bekommen. Wenn du 3D Beschleunigung in Hardware haben willst, mußt du entweder auf XFree4.3 updaten oder den Treiber von ATi probieren.
puck
Damit läßt sich nicht wirklich was anfangen. Allerdings dürftest du im Moment auch keine Anwendungen haben, die auf 3D-Beschleunigung angewiesen sind, oder irre ich mich da?
puck
Da hast du vollkommen recht. Mir ist wirklich erstmal nur wichtig, meine gesamte Hardware ans Laufen zu bringen. Alleine der Drucker war ja schon Horror. Im Mom kämpfe ich gerade mit dem Scanner weiter. Ich glaube, ich schmeiss den ganzen sane Mist nochmal runter. Wer weiss, was ich da kompiliert hab.
Rhodanos
