- Foren
- Planet 3DNow! Community
- Metaprojekte ("Sammelprojekte")
- World Community Grid
Drug Search for Leishmaniasis (DSFL)
- Ersteller Ali
Ali
- Pattonville
- Querbeet
- WCG & SIMAP
- AMD Ryzen 9 5900X
- Asus rog strix B550
- 32 GB
- Radeon RX 560
- Dell S2719dgf
- WD SN 750 - 1 TB
- Seagate Barracuda 2 TB
- keine
- Fractal Design Define
- Be Quiet Pure Power
- Windows 10 x64
▼1000 MBit
▲50 MBit
Es gibt ein neues Unterprojekt bei WCG, es heisst Drug Search for Leishmaniasis (DSFL).
Es beschäftigt sich mit der Erforschung von Medikamenten für die Behandlung der Krankheit, welche durch Parasiten hervorgerufen wird. Das Projekt wird von der Universität Antioquia aus Medellin durchgeführt.
Link zum WCG Forumeinstrag
Dies sind die Badges zum Projekt.
Gruß Ali
Dear World Community Grid Members,
Welcome to the Drug Search for Leishmaniasis (DSFL) project!
Leishmaniasis is one of the most neglected tropical diseases in the world. Infections have been increasing with over two million people affected last year. To date, there are no available vaccines to prevent the disease, in spite of multiple research efforts.
We, the researchers at PECET (Program for the Study and Control of Tropical Diseases) at the University of Antioquia in Medellín, Colombia, are running DSFL on World Community Grid to search for chemical compounds which may lead to new drugs for treating this disease.
We are really looking forward to seeing the results of this project, and sharing the insights we get from it with you. As the project moves forward, we will be certain to keep you updated about our findings and publications in this forum.
We really appreciate that you are willing to donate your idle computing time to this ambitious project, which is pioneered in Latin America. If you have any question about the project please do not hesitate to contact us through this forum.
Thank you from the research team and the PECET Lab:
Carlos Muskus: member name: "carlos.muskus"
Rodrigo Ochoa: member name: "rodrigo ochoa"
Andres Florez: member name: "aflorez"
Work unit numbering is in this format:
DSFL_TTTTTTTT_BBBBBBB_WWWW
T=Target
B=Batch
W=Work unit number
The current number of targets is 5353 and there are 58 batches per a target (0-57). The number of work units in a batch can vary, but will likely be around 1000.
Gruß Ali
HGW
- in NRW
auf zum Badges
HGW
- in NRW
Mein Q8200 mit Linux x64 hat auch die beiden ersten durch gerechnet. Dafür hat er ca. 4:20h und 4:30h benötigt.
Q6600 und i7 920 (oc auf 3,0 GHz) brauchen so:
Q6600.....7.02.....101.1 / 95.5
Q6600.....6.41......96.8 / 109.1
Q6600.....7.10....106.9 / 107.1
Q6600.....6.00.....90.4 / 95.9 ( Q600 32Bit )
i7920......7.49.....54.8 / 152.8 ( 64Bit)
Ali
- Pattonville
- Querbeet
- WCG & SIMAP
- AMD Ryzen 9 5900X
- 32 GB
- Radeon RX 560
- Dell S2719dgf
- WD SN 750 - 1 TB
- keine
- Windows 10 x64
▼1000 MBit
▲50 MBit
Mein i7-860 braucht unter Windows 64bit auch so 6-7,5 Stunden pro WU. Mein kleiner Core2Duo braucht locker 8,5 Stunden hierfür. Dies entspricht zudem ziemlich genau den letzten Betas.
@Darkone: Wie hat dein Rechner dies so schnell geschafft bzw. was hast du für einen Rechner?
Gruß Ali
Gruß Ali
Tut mir leid, ich hatte mich missverständlich ausgedrückt. Ich meinte dass die WU die grad berechnet wird noch 1,5 h braucht bis zur Fertigstellung, er hatte aber schon 3 h dran geknabbert.
Im Moment ist eine WU fertig für dieses Projekt (muss noch hochgeladen werden). Diese brauchte 5 h und 10 Min.
aus den Stats...Drug Search for Leishmaniasis 1,628 2 0:000:10:51:17
Mein X4-945@3GHz braucht im Schnitt 5,05 Stunden und wirft pro WU 108 Granted credit ab (die ersten 11 sind validiert).
Macht also 0,00198 Credits per Second per GHz.
Der E350 knabbert schon seit 21 Stunden an einer WU, ist aber gleich fertig. Trotzdem gerade halb so viele CSG. Für den ist dieses Projekt wohl eher nicht so geeignet.
HGW
- in NRW
HGW
- in NRW
Den KickOff am 31.07. habe ich verschlafen und hänge somit etwas hinterher.
DSFL-WUs haben schon sehr unterschiedliche Laufzeiten.
DSFL_ 00000003_ 0000034_ 0630_ 0-- 8.90 h
DSFL_ 00000003_ 0000034_ 0142_ 0-- 5.75 h
DSFL_ 00000003_ 0000030_ 0669_ 1-- 6.95 h
DSFL_ 00000002_ 0000056_ 0625_ 1-- 4.67 h
DSFL_ 00000002_ 0000042_ 0361_ 0-- 4.52 h
Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz [Family 6 Model 42 Stepping 7]
OS: Microsoft Windows 7: Ultimate x86 Edition, Service Pack 1, (06.01.7601.00)
Memory: 3.49 GB physical, 6.97 GB virtual
Kann es sein, daß dem Server gerade die Arbeit ausgegangen ist?
Ich bekomme immer die Meldung
Edit: die haben das Projekt wohl derzeit gestoppt
http://www.worldcommunitygrid.org/forums/wcg/viewthread_thread,31690
05.09.2011 12:39:13 | World Community Grid | No work available for the applications you have selected. Please check your settings on the website.
Ishtel
- WCG, CPDN, Radioactive@Home, WUProp
- RyZen 7 1700, i5-2520M, RX 460
Das Problem ist bekannt und wurde gelöst. Beitag im WCG Forum
Bei mir sind gut 200 defekte Tasks angekommen...
Wer mehrere Rechner auf das Projekt angesetzt hat sollte auf jeden Fall die Anzahl der auf dem Rechner noch verfügbaren Tasks überprüfen. Bei mir wurden über zwölf Stunden lang keine Neuen heruntergeladen, Neue gab es nur durch händisches Eingreifen!
Ich hab nun wieder 2 neue Target5 bekommen.
HGW
- in NRW
0:051:21:00:33
Ali
- Pattonville
- Querbeet
- WCG & SIMAP
- AMD Ryzen 9 5900X
- 32 GB
- Radeon RX 560
- Dell S2719dgf
- WD SN 750 - 1 TB
- keine
- Windows 10 x64
▼1000 MBit
▲50 MBit
Da warens nur noch 3 Badges die zwischen Dir und dem
hier liegen.
Gruß Ali
Gruß Ali
HGW
- in NRW
0:091:16:33:49
HGW
- in NRW
good job!
ich krieg dich noch....!
mit sicherheit, bin ab dem 15.09. für 10 tage in urlaub
aber dann wieder volle pulle
HGW
- in NRW
1:000:17:46:29
super
soeben die maschinen wieder angeworfen
