ASRock A320M-DVS R4.0
- Ersteller pipin
Gelistet seit:
– Letztes Update:
- Name:
- ASRock A320M-DVS R4.0
- Hersteller:
- ASRock
- Formfaktor:
- mATX
- Sockel:
- AM4
- Chipsatz:
- AMD A320
- AGESA-Version:
- Combo-AM4v2Pi 1.2.0.7
- TDP:
- 105 W
- Lüfteranschlüsse:
- 3 (2 vierpolig)
- Speichergeschwindigkeit:
- DDR4-2667
- Speicherbänke:
- 2x DDR4
- Video-Ausgänge:
- VGA + DVI
- Integrierter Audio-Chip:
- Realtek ALC887
- Audio-Ausgänge:
- 7.1
- PCIe-Slots (2):
- PCIe 3.0/3.1 x16
- PCIe x1
- SATA-Anschlüsse:
- 4x SATA 6 Gbit/s
- M.2-Anschlüsse (M-Key):
- RAID-Modus:
- 0/1/10
- LAN-Anschlüsse:
- 1x 1Gb LAN
- Primärer LAN-Chip:
- Realtek RTL8111H
- USB-Anschlüsse außen:
- 2x USB 2.0
- USB-Anschlüsse innen:
- 4x USB 2.0
- Je nach Gusto
- AMD Ryzen 9 5900X
- ASRock B550
- 2x 16 GB DDR4 3200
- GeForce GTX 1650
- 27 Zoll Acer + 24 Zoll DELL
- Samsung 980 Pro 256 GB
- diverse
- Fractal Design R5
- Logitech Cordless Desktop
- Logitech G502
- Firefox, Vivaldi
- ▼250 MBit ▲40 MBit
Outlaw9876
- Ruhrpott
- HP Compaq nx6325
- AMD Ryzen 3 2200G
- Asus Prime A320M-K
- Cooler Master Masterliquid Lite 120 + Sharkoon 120 mm Lüfter Front
- AMD Radeon Vega 8
- 2 x 27 Zoll Philips 272S1AE
- Realtek ALC 887
- Sharkoon Rush Board
- Logitech M190
- Windows 10 Pro 64 Bit / Ubuntu 21.10 64 Bit
- Edge
- ▼190 MBit ▲40 MBit
Version | Date | Size | Update BIOS Under / How to Update | Description | Download | |
7.20 | 2022/5/11 | 10.55MB | Instant Flash | 1. Support Cezanne CPU 2. Update AMD AM4 AGESA Combo V2 PI 1.2.0.7 *This BIOS doesn't support Bristol Ridge CPU, do NOT update this BIOS if Bristol Ridge CPU is being used. **It requires to update BIOS to 7.00 before updating this version. *** User will not able to flash previous BIOS once upgrading to this BIOS version. | Global | China |
AMD AM4 Socket; 2 DIMMs, Supports DDR4 3200+(OC)<span style=color:red;>*</span>; 1 PCIe 3.0 x16, 1 PCIe 2.0 x1; Graphics Output : DVI-D, D-Sub; 7.1 CH HD Audio (Realtek ALC887/897 Audio Codec); 4 SATA3; 6 USB 3.1 Gen1 (2 Front, 4 Rear); Realtek Gigabit LAN<div class=Remark><span...
www.asrock.com
Outlaw9876
- Ruhrpott
- HP Compaq nx6325
- AMD Ryzen 3 2200G
- AMD Radeon Vega 8
- Realtek ALC 887
- Logitech M190
- Edge
7.40 | 2022/11/28 | 10.55MB | Instant Flash | Improve GPU compatibility for GeForce RTX 40 series. *This BIOS doesn't support Bristol Ridge CPU, do NOT update this BIOS if Bristol Ridge CPU is being used. **It requires to update BIOS to 7.00 before updating this version. *** User will not able to flash previous BIOS once upgrading to this BIOS version. | Global | China |
www.asrock.com
Wer kommt auf die Idee mit diesem Board eine RTX 40-Grafikkarte zu betreiben?
Outlaw9876
- Ruhrpott
- HP Compaq nx6325
- AMD Ryzen 3 2200G
- AMD Radeon Vega 8
- Realtek ALC 887
- Logitech M190
- Edge
10.08 [Beta] | 2024/1/31 | 10.66MB | Instant Flash | 1. Update AMD AM4 AGESA Combo V2 PI 1.2.0.B 2. Patch UEFI LogoFail vulnerabilities. *This BIOS doesn't support Bristol Ridge CPU, do NOT update this BIOS if Bristol Ridge CPU is being used. **It requires to update BIOS to 7.00 before updating this version. *** User will not able to flash previous BIOS once upgrading to this BIOS version. | Global | China |
AMD AM4 Socket<br />2 DIMMs, Supports DDR4 3200+(OC)<span style=color:red;>*</span><br />1 PCIe 3.0 x16, 1 PCIe 2.0 x1<br />Graphics Output : DVI-D, D-Sub<br />7.1 CH HD Audio (Realtek ALC887/897 Audio Codec)<br />4 SATA3<br />6 USB 3.1 Gen1 (2 Front, 4 Rear)<br />Realtek Gigabit LAN<div...
www.asrock.com
Zwar ein Beta-Bios, aber schön, dass das olle Board auch noch AGESA 1.2.0.B und das aktuelle Sicherheitsupdate bekommt.
Lauft bei mir mit nem Ryzen 7 1700X.
BIOS Versionen
7.40 (28.11.2022)Improve GPU compatibility for GeForce RTX 40 series.
7.20 (11.05.2022)1. Support Cezanne CPU
2. Update AMD AM4 AGESA Combo V2 PI 1.2.0.7 -
7.10 (05.01.2022)1. Support Renoir and Vermeer CPU.
2. Remove Bristol Ridge(AMD A-series/Athlon X4 series) CPU support. -
7.04 (26.11.2021)1. Support Renoir and Vermeer CPU.
7.00 (23.11.2021)Bridge BIOS for 7.04
4.00 (29.07.2020)1. Update AMD AGESA Combo-AM4 PI 1.0.0.6
2. Supports 3RD Gen AMD Ryzen XT series CPU
