Bei AM4 ist ECC eher eine Geschichte der Mainboardhersteller ob ssie es aktivieren oder nicht.
Aber es sind eh nur diese zwei Platienen übrig wenn man 10GBase-T + ECC anwählt....
Hier mal der Auszug von Asrock Homepage:
- 2 x Antenna Ports
- 1 x PS / 2 Mouse / Keyboard Port
- 1 x HDMI Port
- 1 x DisplayPort 1.4 Input
- 1 x Optical SPDIF Out Port
- 2 x USB 3.2 Gen2 Thunderbolt™ 3 Type-C Ports (40Gb / s for Thunderbolt™ protocol; 10 Gb / s for USB3.2 protocol) (Supports ESD Protection)
- 6 x USB 3.2 Gen1 Ports (Supports ESD Protection)*
- 2 x RJ-45 LAN Ports with LED (ACT / LINK LED and SPEED LED)
- 1 x BIOS Flashback Button
- HD Audio Jacks: Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone (Gold Audio Jacks)
*Ultra USB Power is supported on USB3_5_6 ports.
ACPI wake-up function is not supported on USB3_5_6, TB_1 and TB_2 ports.
Supports AMD AM4 Socket Ryzen™ 2000 and 3000 Series processors
Supports DDR4 4666+ (OC)
Intel® Wi-Fi 6 802.11ax (2.4Gbps) + BT 5.0
AQUANTIA 10G LAN, Intel® Gigabit LAN
3 PCIe 4.0 x16, 3 PCIe 2.0 x1
NVIDIA® NVLink™, Quad SLI™, AMD 3-Way CrossFireX™
7.1 CH HD Audio (Realtek ALC1220 Audio Codec)
Supports Supports DTS Connect
8 SATA3, 1 Hyper M.2 (PCIe Gen4 x4 & SATA3), 1 Hyper M.2 (PCIe Gen4 x4)
1 Front USB 3.2 Gen2 Type-C, 10 USB 3.2 Gen1 (4 Front, 6 Rear)
2 Intel® Thunderbolt™ 3 Type-C
>>> AMD Ryzen series CPUs (Matisse) support DDR4 4666+(OC) / 4400(OC) / 4300(OC) / 4266(OC) / 4200(OC) / 4133(OC) / 4000(OC) / 3866(OC) / 3800(OC) / 3733(OC) / 3600(OC) / 3466(OC) / 3200 / 2933 / 2667 / 2400 / 2133
ECC
Grüße, Don
