Linux, Marox G200 MMS und Mauszeiger
- Ersteller xastax
ich habe eine Matrox G200 MMS Karte (4 Monitore) unter Linux Red Hat 7.3 Laufen! Ich habe mir den neuesten Treiben von der Matrox Homepage runtergeladen und alle Einstellungen
vorgenommen.
Soweit alles OK, nur das der Mauszeiger nicht auf den anderen Monitoren angezeigt wird, nur auf dem ersten.
Sonst funktioniert alles bestens.
Woran kann es liegen das der Mauszeiger nicht angezeigt wird?
Danke für eure Antworten.
vorgenommen.
# File generated by anaconda.
Section "ServerLayout"
Identifier "Anaconda Configured"
Screen "Screen0" LeftOf "Screen1"
Screen "Screen1" LeftOf "Screen2"
Screen "Screen2" LeftOf "Screen3"
Screen "Screen3"
Option "Xinerama" "on"
InputDevice "Mouse0" "CorePointer"
InputDevice "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
# The location of the RGB database. Note, this is the name of the
# file minus the extension (like ".txt" or ".db"). There is normally
# no need to change the default.
RgbPath "/usr/X11R6/lib/X11/rgb"
# Multiple FontPath entries are allowed (they are concatenated together)
# By default, Red Hat 6.0 and later now use a font server independent of
# the X server to render fonts.
FontPath "unix/:7100"
EndSection
Section "Module"
Load "GLcore"
Load "dbe"
Load "extmod"
Load "fbdevhw"
Load "dri"
Load "glx"
Load "record"
Load "freetype"
Load "type1"
EndSection
Section "InputDevice"
Identifier "Keyboard0"
Driver "keyboard"
# Option "AutoRepeat" "500 5"
# when using XQUEUE, comment out the above line, and uncomment the
# following line
# Option "Protocol" "Xqueue"
# Specify which keyboard LEDs can be user-controlled (eg, with xset(1))
# Option "Xleds" "1 2 3"
# To disable the XKEYBOARD extension, uncomment XkbDisable.
# Option "XkbDisable"
# To customise the XKB settings to suit your keyboard, modify the
# lines below (which are the defaults). For example, for a non-U.S.
# keyboard, you will probably want to use:
# Option "XkbModel" "pc102"
# If you have a US Microsoft Natural keyboard, you can use:
# Option "XkbModel" "microsoft"
# Then to change the language, change the Layout setting.
# For example, a german layout can be obtained with:
# Option "XkbLayout" "de"
# or:
# Option "XkbVariant" "nodeadkeys"
# If you'd like to switch the positions of your capslock and
# control keys, use:
# Option "XkbOptions" "ctrl:nocaps"
Option "XkbRules" "xfree86"
#Option "XkbVariant" ""
#Option "XkbOptions" ""
EndSection
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "PS/2"
Option "Device" "/dev/psaux"
Option "ZAxisMapping" "4 5"
Option "Emulate3Buttons" "no"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Monitor Vendor"
ModelName "Monitor Model"
HorizSync 30-82
VertRefresh 50-160
Option "dpms"
# -- 1400x1050 --
# 1400x1050 @ 60Hz, 65.8 kHz hsync
Modeline "1400x1050" 129 1400 1464 1656 1960
1050 1051 1054 1100 +HSync +VSync
# 1400x1050 @ 70Hz, 76.8 kHz hsync
Modeline "1400x1050" 151 1400 1464 1656 1960
# 1400x1050 @ 75Hz, 82.3 kHz hsync
Modeline "1400x1050" 162 1400 1464 1656 1960
# 1400x1050 @ 85Hz, 93.2 kHz hsync
Modeline "1400x1050" 184 1400 1464 1656 1960
EndSection
Section "Monitor"
Identifier "Monitor1"
HorizSync 30-82
VertRefresh 50-160
Option "dpms"
# -- 1400x1050 --
EndSection
Section "Monitor"
Identifier "Monitor2"
HorizSync 30-82
VertRefresh 50-160
Option "dpms"
# -- 1400x1050 --
EndSection
Section "Monitor"
Identifier "Monitor3"
HorizSync 30-82
VertRefresh 50-160
Option "dpms"
# -- 1400x1050 --
EndSection
Section "Device"
# no known options
Identifier "Matrox Millennium G200_0"
Driver "mga"
VendorName "Matrox Millennium G200"
BoardName "Matrox Millennium G200"
Option "hw cursor" "off"
BusID "PCI:2:0:0"
EndSection
Section "Device"
# no known options
Identifier "Matrox Millennium G200_1"
Driver "mga"
BusID "PCI:2:4:0"
EndSection
Section "Device"
# no known options
Identifier "Matrox Millennium G200_2"
Driver "mga"
BusID "PCI:2:8:0"
EndSection
Section "Device"
# no known options
Identifier "Matrox Millennium G200_3"
Driver "mga"
BusID "PCI:2:12:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Matrox Millennium G200_0"
Monitor "Monitor0"
DefaultDepth 24
Subsection "Display"
Depth 24
Modes "1024x768" "1024x768"
EndSubsection
EndSection
Section "Screen"
Identifier "Screen1"
Device "Matrox Millennium G200_1"
Monitor "Monitor1"
DefaultDepth 24
Depth 24
EndSubsection
EndSection
Section "Screen"
Identifier "Screen2"
Device "Matrox Millennium G200_2"
Monitor "Monitor2"
DefaultDepth 24
Depth 24
EndSubsection
EndSection
Section "Screen"
Identifier "Screen3"
Device "Matrox Millennium G200_3"
Monitor "Monitor3"
DefaultDepth 24
Depth 24
EndSubsection
EndSection
Section "DRI"
Mode 0666
EndSection
Screen "Screen3"
EndSection
Section "Files"
EndSection
Section "Module"
Load "GLcore"
Load "dbe"
Load "extmod"
Load "fbdevhw"
Load "dri"
Load "glx"
Load "record"
Load "freetype"
Load "type1"
EndSection
Driver "keyboard"
# following line
# or:
EndSection
Identifier "Mouse0"
Driver "mouse"
EndSection
Section "Monitor"
HorizSync 30-82
VertRefresh 50-160
Option "dpms"
# -- 1400x1050 --
EndSection
Section "Monitor"
HorizSync 30-82
VertRefresh 50-160
Option "dpms"
# -- 1400x1050 --
EndSection
Section "Monitor"
HorizSync 30-82
VertRefresh 50-160
Option "dpms"
# -- 1400x1050 --
EndSection
Section "Monitor"
HorizSync 30-82
VertRefresh 50-160
Option "dpms"
# -- 1400x1050 --
EndSection
Section "Device"
# no known options
Driver "mga"
BusID "PCI:2:0:0"
EndSection
Section "Device"
# no known options
Driver "mga"
BusID "PCI:2:4:0"
EndSection
Section "Device"
# no known options
Driver "mga"
BusID "PCI:2:8:0"
EndSection
Section "Device"
# no known options
Driver "mga"
BusID "PCI:2:12:0"
EndSection
Section "Screen"
Monitor "Monitor0"
DefaultDepth 24
Depth 24
EndSubsection
EndSection
Section "Screen"
Monitor "Monitor1"
DefaultDepth 24
Depth 24
EndSubsection
EndSection
Section "Screen"
Monitor "Monitor2"
DefaultDepth 24
Depth 24
EndSubsection
EndSection
Section "Screen"
Monitor "Monitor3"
DefaultDepth 24
Depth 24
EndSubsection
EndSection
Section "DRI"
Mode 0666
EndSection
XFree86 Version 4.2.0 (Red Hat Linux release: 4.2.0-8) / X Window System
(protocol Version 11, revision 0, vendor release 6600)
Release Date: 23 January 2002
If the server is older than 6-12 months, or if your card is
newer than the above date, look for a newer version before
reporting problems. (See http://www.XFree86.Org/)
Build Operating System: Linux 2.4.17-0.13smp i686 [ELF]
Build Host: daffy.perf.redhat.com
Module Loader present
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/XFree86.0.log", Time: Mon Feb 3 10:51:51 2003
(==) Using config file: "/etc/X11/XF86Config-4"
(==) ServerLayout "Anaconda Configured"
(**) |-->Screen "Screen0" (0)
(**) | |-->Monitor "Monitor0"
(**) | |-->Device "Matrox Millennium G200_0"
(**) |-->Screen "Screen1" (1)
(**) | |-->Monitor "Monitor1"
(**) | |-->Device "Matrox Millennium G200_1"
(**) |-->Screen "Screen2" (2)
(**) | |-->Monitor "Monitor2"
(**) | |-->Device "Matrox Millennium G200_2"
(**) |-->Screen "Screen3" (3)
(**) | |-->Monitor "Monitor3"
(**) | |-->Device "Matrox Millennium G200_3"
(**) |-->Input Device "Mouse0"
(**) |-->Input Device "Keyboard0"
(**) Option "XkbRules" "xfree86"
(**) XKB: rules: "xfree86"
(**) Option "XkbModel" "pc102"
(**) XKB: model: "pc102"
(**) Option "XkbLayout" "de"
(**) XKB: layout: "de"
(==) Keyboard: CustomKeycode disabled
(**) FontPath set to "unix/:7100"
(**) RgbPath set to "/usr/X11R6/lib/X11/rgb"
(==) ModulePath set to "/usr/X11R6/lib/modules"
(**) Option "Xinerama" "on"
(**) Xinerama: enabled
(--) using VT number 7
(II) Open APM successful
(II) Module ABI versions:
XFree86 ANSI C Emulation: 0.1
XFree86 Video Driver: 0.5
XFree86 XInput driver : 0.3
XFree86 Server Extension : 0.1
XFree86 Font Renderer : 0.3
(II) Loader running on linux
(II) LoadModule: "bitmap"
(II) Loading /usr/X11R6/lib/modules/fonts/libbitmap.a
(II) Module bitmap: vendor="The XFree86 Project"
compiled for 4.2.0, module version = 1.0.0
Module class: XFree86 Font Renderer
ABI class: XFree86 Font Renderer, version 0.3
(II) Loading font Bitmap
(II) LoadModule: "pcidata"
(II) Loading /usr/X11R6/lib/modules/libpcidata.a
(II) Module pcidata: vendor="The XFree86 Project"
compiled for 4.2.0, module version = 0.1.0
ABI class: XFree86 Video Driver, version 0.5
(II) PCI: Probing config type using method 1
(II) PCI: Config type is 1
(II) PCI: stages = 0x03, oldVal1 = 0x80000058, mode1Res1 = 0x80000000
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 8086,7180 card 0000,0000 rev 03 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 8086,7181 card 0000,0000 rev 03 class 06,04,00 hdr 01
(II) PCI: 00:07:0: chip 8086,7110 card 0000,0000 rev 02 class 06,01,00 hdr 80
(II) PCI: 00:07:1: chip 8086,7111 card 0000,0000 rev 01 class 01,01,80 hdr 00
(II) PCI: 00:07:2: chip 8086,7112 card 0000,0000 rev 01 class 0c,03,00 hdr 00
(II) PCI: 00:07:3: chip 8086,7113 card 0000,0000 rev 02 class 06,80,00 hdr 00
(II) PCI: 00:09:0: chip 10b7,9055 card 10b7,9055 rev 24 class 02,00,00 hdr 00
(II) PCI: 00:0b:0: chip 8086,b152 card 0000,0000 rev 00 class 06,04,00 hdr 01
(II) PCI: 02:00:0: chip 102b,0521 card 102b,dbe3 rev 03 class 03,00,00 hdr 00
(II) PCI: 02:04:0: chip 102b,0521 card 102b,dbf9 rev 03 class 03,80,00 hdr 00
(II) PCI: 02:08:0: chip 102b,0521 card 102b,dbf9 rev 03 class 03,80,00 hdr 00
(II) PCI: 02:0c:0: chip 102b,0521 card 102b,dbf9 rev 03 class 03,80,00 hdr 00
(II) PCI: End of PCI scan
(II) LoadModule: "scanpci"
(II) Loading /usr/X11R6/lib/modules/libscanpci.a
(II) Module scanpci: vendor="The XFree86 Project"
(II) UnloadModule: "scanpci"
(II) Unloading /usr/X11R6/lib/modules/libscanpci.a
(II) Host-to-PCI bridge:
(II) PCI-to-ISA bridge:
(II) PCI-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (-1,0,0), BCTRL: 0x08 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0x00000000 - 0x0000ffff (0x10000) IX
(II) Bus 0 non-prefetchable memory range:
[0] -1 0x00000000 - 0xffffffff (0x0) MX
(II) Bus 0 prefetchable memory range:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x02 (VGA_EN is cleared)
(II) Bus 1 I/O range:
[0] -1 0x0000c000 - 0x0000cfff (0x1000) IX
(II) Bus 1 non-prefetchable memory range:
(II) Bus 1 prefetchable memory range:
(II) Bus -1: bridge is at (0:7:0), (0,-1,0), BCTRL: 0x08 (VGA_EN is set)
(II) Bus -1 I/O range:
(II) Bus -1 non-prefetchable memory range:
(II) Bus -1 prefetchable memory range:
(II) Bus 2: bridge is at (0:11:0), (0,2,2), BCTRL: 0x0e (VGA_EN is set)
(II) Bus 2 I/O range:
[0] -1 0x0000d000 - 0x0000d0ff (0x100) IX
[1] -1 0x0000d400 - 0x0000d4ff (0x100) IX
[2] -1 0x0000d800 - 0x0000d8ff (0x100) IX
[3] -1 0x0000dc00 - 0x0000dcff (0x100) IX
(II) Bus 2 non-prefetchable memory range:
[0] -1 0xd4000000 - 0xe3ffffff (0x10000000) MX
(II) Bus 2 prefetchable memory range:
[0] -1 0xe8000000 - 0xebffffff (0x4000000) MX
(--) PCI:*(2:0:0) Matrox MGA G200 AGP rev 3, Mem @ 0xe8000000/24, 0xd4000000/14, 0xd5000000/23
(--) PCI: (2:4:0) Matrox MGA G200 AGP rev 3, Mem @ 0xe9000000/24, 0xd7000000/14, 0xd8000000/23, BIOS @ 0xd9000000/16
(--) PCI: (2:8:0) Matrox MGA G200 AGP rev 3, Mem @ 0xea000000/24, 0xda000000/14, 0xdb000000/23, BIOS @ 0xdc000000/16
(--) PCI: (2:12:0) Matrox MGA G200 AGP rev 3, Mem @ 0xeb000000/24, 0xdd000000/14, 0xde000000/23, BIOS @ 0xdf000000/16
(II) Addressable bus resource ranges are
[1] -1 0x00000000 - 0x0000ffff (0x10000) IX
(II) OS-reported resource ranges:
[0] -1 0xffe00000 - 0xffffffff (0x200000) MX(B)
[1] -1 0x00100000 - 0x3fffffff (0x3ff00000) MXE(B)
[2] -1 0x000f0000 - 0x000fffff (0x10000) MX
[3] -1 0x000c0000 - 0x000effff (0x30000) MX
[4] -1 0x00000000 - 0x0009ffff (0xa0000) MX
[5] -1 0x0000ffff - 0x0000ffff (0x1) IX
[6] -1 0x00000000 - 0x000000ff (0x100) IX
(II) Active PCI resource ranges:
[0] -1 0xed000000 - 0xed00007f (0x80) MX
[1] -1 0xe4000000 - 0xe7ffffff (0x4000000) MX
[2] -1 0xdf000000 - 0xdf00ffff (0x10000) MX(B)
[3] -1 0xde000000 - 0xde7fffff (0x800000) MX(B)
[4] -1 0xdd000000 - 0xdd003fff (0x4000) MX(B)
[5] -1 0xeb000000 - 0xebffffff (0x1000000) MX(B)
[6] -1 0xdc000000 - 0xdc00ffff (0x10000) MX(B)
[7] -1 0xdb000000 - 0xdb7fffff (0x800000) MX(B)
[8] -1 0xda000000 - 0xda003fff (0x4000) MX(B)
[9] -1 0xea000000 - 0xeaffffff (0x1000000) MX(B)
[10] -1 0xd9000000 - 0xd900ffff (0x10000) MX(B)
[11] -1 0xd8000000 - 0xd87fffff (0x800000) MX(B)
[12] -1 0xd7000000 - 0xd7003fff (0x4000) MX(B)
[13] -1 0xe9000000 - 0xe9ffffff (0x1000000) MX(B)
[14] -1 0xd5000000 - 0xd57fffff (0x800000) MX(B)
[15] -1 0xd4000000 - 0xd4003fff (0x4000) MX(B)
[16] -1 0xe8000000 - 0xe8ffffff (0x1000000) MX(B)
[17] -1 0x0000e000 - 0x0000e07f (0x80) IX
[18] -1 0x0000e400 - 0x0000e41f (0x20) IX
[19] -1 0x0000f000 - 0x0000f00f (0x10) IX
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[5] -1 0xed000000 - 0xed00007f (0x80) MX
[6] -1 0xe4000000 - 0xe7ffffff (0x4000000) MX
[7] -1 0xdf000000 - 0xdf00ffff (0x10000) MX(B)
[8] -1 0xde000000 - 0xde7fffff (0x800000) MX(B)
[9] -1 0xdd000000 - 0xdd003fff (0x4000) MX(B)
[10] -1 0xeb000000 - 0xebffffff (0x1000000) MX(B)
[11] -1 0xdc000000 - 0xdc00ffff (0x10000) MX(B)
[12] -1 0xdb000000 - 0xdb7fffff (0x800000) MX(B)
[13] -1 0xda000000 - 0xda003fff (0x4000) MX(B)
[14] -1 0xea000000 - 0xeaffffff (0x1000000) MX(B)
[15] -1 0xd9000000 - 0xd900ffff (0x10000) MX(B)
[16] -1 0xd8000000 - 0xd87fffff (0x800000) MX(B)
[17] -1 0xd7000000 - 0xd7003fff (0x4000) MX(B)
[18] -1 0xe9000000 - 0xe9ffffff (0x1000000) MX(B)
[19] -1 0xd5000000 - 0xd57fffff (0x800000) MX(B)
[20] -1 0xd4000000 - 0xd4003fff (0x4000) MX(B)
[21] -1 0xe8000000 - 0xe8ffffff (0x1000000) MX(B)
[22] -1 0x0000ffff - 0x0000ffff (0x1) IX
[23] -1 0x00000000 - 0x000000ff (0x100) IX
[24] -1 0x0000e000 - 0x0000e07f (0x80) IX
[25] -1 0x0000e400 - 0x0000e41f (0x20) IX
[26] -1 0x0000f000 - 0x0000f00f (0x10) IX
(II) LoadModule: "GLcore"
(II) Loading /usr/X11R6/lib/modules/extensions/libGLcore.a
(II) Module GLcore: vendor="The XFree86 Project"
ABI class: XFree86 Server Extension, version 0.1
(II) LoadModule: "dbe"
(II) Loading /usr/X11R6/lib/modules/extensions/libdbe.a
(II) Module dbe: vendor="The XFree86 Project"
Module class: XFree86 Server Extension
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "extmod"
(II) Loading /usr/X11R6/lib/modules/extensions/libextmod.a
(II) Module extmod: vendor="The XFree86 Project"
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension FontCache
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) LoadModule: "fbdevhw"
(II) Loading /usr/X11R6/lib/modules/linux/libfbdevhw.a
(II) Module fbdevhw: vendor="The XFree86 Project"
compiled for 4.2.0, module version = 0.0.2
(II) LoadModule: "dri"
(II) Loading /usr/X11R6/lib/modules/extensions/libdri.a
(II) Module dri: vendor="The XFree86 Project"
(II) Loading sub module "drm"
(II) LoadModule: "drm"
(II) Loading /usr/X11R6/lib/modules/linux/libdrm.a
(II) Module drm: vendor="The XFree86 Project"
(II) Loading extension XFree86-DRI
(II) LoadModule: "glx"
(II) Loading /usr/X11R6/lib/modules/extensions/libglx.a
(II) Module glx: vendor="The XFree86 Project"
(II) Loading sub module "GLcore"
(II) Reloading /usr/X11R6/lib/modules/extensions/libGLcore.a
(II) Loading extension GLX
(II) LoadModule: "record"
(II) Loading /usr/X11R6/lib/modules/extensions/librecord.a
(II) Module record: vendor="The XFree86 Project"
compiled for 4.2.0, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "freetype"
(II) Loading /usr/X11R6/lib/modules/fonts/libfreetype.a
(II) Module freetype: vendor="The XFree86 Project"
compiled for 4.2.0, module version = 1.1.10
(II) Loading font FreeType
(II) LoadModule: "type1"
(II) Loading /usr/X11R6/lib/modules/fonts/libtype1.a
(II) Module type1: vendor="The XFree86 Project"
compiled for 4.2.0, module version = 1.0.1
(II) Loading font Type1
(II) Loading font CID
(II) LoadModule: "mga"
(II) Loading /usr/X11R6/lib/modules/drivers/mga_drv.o
(II) Module mga: vendor="The XFree86 Project"
compiled for 4.2.0, module version = 1.1.0
Module class: XFree86 Video Driver
(II) LoadModule: "mouse"
(II) Loading /usr/X11R6/lib/modules/input/mouse_drv.o
(II) Module mouse: vendor="The XFree86 Project"
Module class: XFree86 XInput Driver
ABI class: XFree86 XInput driver, version 0.3
(II) MGA: driver for Matrox chipsets: mga2064w, mga1064sg, mga2164w,
mga2164w AGP, mgag100, mgag100 PCI, mgag200, mgag200 PCI, mgag400,
mgag550
(II) Primary Device is: PCI 02:00:0
(--) Chipset mgag200 found
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
[22] 0 0x000a0000 - 0x000affff (0x10000) MS
[23] 0 0x000b0000 - 0x000b7fff (0x8000) MS
[24] 0 0x000b8000 - 0x000bffff (0x8000) MS
[25] 1 0x000a0000 - 0x000affff (0x10000) MS
[26] 1 0x000b0000 - 0x000b7fff (0x8000) MS
[27] 1 0x000b8000 - 0x000bffff (0x8000) MS
[28] 2 0x000a0000 - 0x000affff (0x10000) MS
[29] 2 0x000b0000 - 0x000b7fff (0x8000) MS
[30] 2 0x000b8000 - 0x000bffff (0x8000) MS
[31] 3 0x000a0000 - 0x000affff (0x10000) MS
[32] 3 0x000b0000 - 0x000b7fff (0x8000) MS
[33] 3 0x000b8000 - 0x000bffff (0x8000) MS
[34] -1 0x0000ffff - 0x0000ffff (0x1) IX
mgag550
