Download AMD Radeon Software Crimson ReLive Edition 17.1.1 Non-WHQL verfügbar.
- Ersteller eratte
User-News
Von eratte
Hinweis: Diese "User-News" wurde nicht von der Planet 3DNow! Redaktion veröffentlicht, sondern vom oben genannten Leser, der persönlich für den hier veröffentlichten Inhalt haftet.Release Notes & Download (mit APU Support)
Release Notes & Download (ohne APU Support)
Radeon Software Crimson ReLive Edition 17.1.1 Beta with APU Support Highlights
Support For
Resident Evil™ 7: Biohazard
Fixed Issues
Dishonored™2 may experience an application crash or hang on some Radeon R9 380 configurations.
Radeon ReLive may show an improper warning popup message when using Windows®7 basic themes.
AMD XConnect™ Technology configurations may experience a blue screen system hang when audio drivers load.
Solidworks™ will no longer terminate on unplug using AMD XConnect™ Technology configurations.
Some system configurations may experience a black screen after installing Radeon Software Crimson ReLive Editions 16.12.1 and later.
Display corruption or TDR may be experienced after applications wake up from a display timeout.
Paragon™ may experience flickering in Multi GPU with DirectX®11.
Radeon ReLive may crash or become unresponsive when toggling Multi GPU with Desktop Recording and/or Instant Replay enabled.
Known Issues
A small amount of apps may still experience issues with Borderless Fullscreen mode and AMD FreeSync™ technology if other applications or game launchers are running on the primary screen in the background.
Counter-Strike™: Global Offensive and World of Warcraft™ may experience flickering or performance issues the first time the game is launched on a system boot with AMD FreeSync™ technology enabled. Workarounds include exiting and restarting the application or task switching (alt+tab) in and out of the game to fix the issue.
Shadow Warrior 2™ may experience an application hang when launched with Multi GPU enabled.
Radeon RX 400 series products may experience scaling issues for some applications when using the display scaling feature.
Deus Ex: Mankind Divided™ may experience an application hang when running in Multi GPU with DirectX®12 and performing a task switch.
AMD Multi GPU configurations may experience a system hang or reboot during install when using tiled MST 4K or 5K displays.
Mouse cursor corruption may be intermittently experienced on Radeon RX 480.
Known Issues for Radeon ReLive
The XBOX™ DVR application may cause conflicts with Radeon ReLive, users are suggested to disable XBOX™ DVR if Radeon ReLive is experiencing issues.
Radeon ReLive may fail to install on AMD APU Family products or experience a system hang or failure to record when using the recording feature on AMD APU Family products.
Radeon ReLive may stop working after hot unplugging of a secondary display.
Battlefield™1 may experience UI flickering and/or performance drops when recording gameplay with Radeon ReLive on graphics products with 4GB or less of VRAM.
Radeon ReLive recordings or overlay may experience flicker when creating a single recording for many hours.
Radeon ReLive may experience minor graphical corruption for the first few recorded frames when launching UWP applications.
Radeon ReLive will not allow recording settings to change with Instant Replay enabled. A workaround is to disable Instant Replay and change settings then enable Instant Replay.
Vulkan™ applications may experience a game hang when using Radeon ReLive to record.
Radeon ReLive will not notify an end user of low disk space during recording.
Package Contents
The Radeon Software Crimson ReLive Edition 17.1.1 Beta with APU Support installation package contains the following:
Radeon Software Crimson ReLive Edition 17.1.1 Beta with APU Support Driver Version 16.50.2611
Radeon Product Compatibility
Radeon Software Crimson ReLive Edition 17.1.1 Beta with APU Support is compatible with the following AMD Radeon products.
Note that AMD Radeon™ R9 Fury, Radeon™ Pro Duo, and Radeon™ RX 400 Series graphics are only supported by Radeon Software Crimson ReLive Edition on Windows 7/8.1/10 64-bit.
Radeon Desktop Product Family Compatibility
Radeon™ RX 400 Series Graphics
AMD Radeon™ R7 300 Series Graphics
AMD Radeon™ Pro Duo
AMD Radeon™ R7 200 Series Graphics
AMD Radeon™ R9 Fury Series Graphics
AMD Radeon™ R5 300 Series Graphics
AMD Radeon™ R9 Nano Series Graphics
AMD Radeon™ R5 200 Series Graphics
AMD Radeon™ R9 300 Series Graphics
AMD Radeon™ R9 200 Series Graphics
AMD Radeon™ HD 8500 - HD 8900 Series Graphics
AMD Radeon™ HD 7700 - HD 7900 Series Graphics
Mobility Radeon™ Family Compatibility
Radeon Software Crimson ReLive Edition 17.1.1 Beta with APU Support is a notebook reference graphics driver with limited support for system vendor specific features.
Radeon Mobility Product Family Compatibility
AMD Radeon™ R9 M300 Series Graphics
AMD Radeon™ R7 M200 Series Graphics
AMD Radeon™ R7 M300 Series Graphics
AMD Radeon™ R5 M200 Series Graphics
AMD Radeon™ R5 M300 Series Graphics
AMD Radeon™ R9 M200 Series Graphics
AMD Radeon™ HD 8500M - HD 8900M Series Graphics
AMD Radeon™ HD 7700M - HD 7900M Series Graphics
AMD APU Product Family Compatibility
AMD APU products codenamed "Kaveri", "Godavari" and "Carrizo" are only supported by AMD Radeon Software Crimson Edition on Windows® 7 (32 & 64-bit), Windows® 8.1 (64-bit) and Windows® 10 (64-bit). AMD’s 7th Generation APU products Radeon™ Graphics are only supported by AMD Radeon Software Crimson Edition on Windows® 7 (32 & 64-bit) and Windows® 10 (64-bit).
AMD A-Series APUs with Radeon™ R4, R5, R6, or R7 Graphics
AMD A-Series APUs with Radeon™ R3, R4, R5, R6, R7, or R8 Graphics
AMD Pro A-Series APUs with Radeon™ R5 or R7 Graphics
AMD Pro A-Series APUs with Radeon™ R5, R6, or R7 Graphics
AMD Athlon™ Series APUs with Radeon™ R3 Graphics
AMD FX-Series APUs with Radeon™ R7 Graphics
AMD Sempron™ Series APUs with Radeon™ R3 Graphics
AMD E-Series APUs with Radeon™ R2 Graphics
AMD Radeon™ HD 8180 - HD 8400 Series Graphics
Compatible Operating Systems
Radeon Software Crimson ReLive Edition 17.1.1 Beta with APU Support is designed to support the following Microsoft® Windows® platforms. Operating System support may vary depending on your specific AMD Radeon product.
Windows® 10 (32 & 64-bit version)
Windows 8.1 (32 & 64-bit version)
Windows 7 (32 & 64-bit version with SP1 or higher)
Support For
Fixed Issues
Known Issues
Package Contents
AMD Radeon™ Pro Duo
maikrosoft
- germany
- AMD Ryzen 7 7800x 3d
- ASUS ROG STRIX B650-A Gaming
- Thermalright Peerless Assassin 120 SE ARGB white
- 2 x 16 GB Corsair Vengeance 5600MHz CL 36
- ASUS GeForce RTX 4060 Ti OC white
- LG UltraGear 27GP850-B
- Samsung 970 EVO Plus 2TB, Western Digital SN550, Crucial MX500 1TB m.2, Silicon Power Ace A55 1TB
- Soundblaster AE-5 PLUS - DT-990pro
- BeQuiet Silentbase 802
- Seasonic Core GM 650W
- Sharkoon SGK 60
- Gigabyte M3
- Windows 11 pro x64 / Manjaro
- AUKEY Large mousepad gaming xxl
WOT crashed nach wie vor. Ich könnt mich in den ... beissen dass ich damals nicht zu einer 1060 gegriffen habe.
Naja, aus Fehlern lernt man. das war meine letzte AMD Karte und auch ZEN, egal wie gut er wird, wird boykottiert.
Passiert das nur mit der ReLive Version oder auch mit dem Vorgänger schon?
maikrosoft
- germany
- Sharkoon SGK 60
- Gigabyte M3
Nur mit sämtlichen ReLive Treibern. Der 16.11.5 läuft wie Schmitts Katze
Auch wenn es ärgerlich ist dann kannst das doch gelassen abwarten bis das gefixed ist, hatte mal ähnliches mit einem nv-treiber und World of Warcraft.
Das WoT Problem scheint jeden zu betreffen.
maikrosoft
- germany
- Sharkoon SGK 60
- Gigabyte M3
Es kommen ja in neuen Treibern auch Fixes und Anpassungen für neue Spiele welche mit dem älteren Treiber eher mäßig laufen.
Ich verstehe AMD da nicht. Lange Zeit war das Image, ich will nicht sagen schlecht, ähmm "angekratzt".
Mit Polaris hat man endlich mal ne neue Architektur und auch in Sachen Effizienz etwas gemacht. ZEN sieht an und für sich recht viel versprechend aus, und dann versaut es sich AMD wieder selbst mir ihren Treibern. Im offi AMD Forum siehts auch nicht besser aus. Selbst der Bug das einige ältere Karten den Speicher nicht hochtakten, besteht seit dem ersten ReLive, wurde nicht gefixt.
mulle
- Asus Zenbook UX3430UA
- AMD Ryzen 7 1700
- ASUS B350 Prime Plus
- AMD Wraith Spire
- Sapphire HD 6450 passiv
- Eizo EV2455-BK
- Samsung NVME 960 EVO 500 GB
- Jonsbo U4
Bugs werden eben intern priorisiert. Es ist glaube ich bei AMD eine sichere Wette, dass so Sachen wie "Solidworks" und "Paragon" diese Runde halt mal wichtiger waren als WoT.Selbst der Bug das einige ältere Karten den Speicher nicht hochtakten, besteht seit dem ersten ReLive, wurde nicht gefixt.
Ggf. ist der Bug auch analysiert und erstmal in der Kategorie "Scheiße, dauert länger" gelandet. Oder schon gefixt und in der Verifikation.
Gerade *wegen* der neuen Releases schaukelt AMD gerade wohl eher keine Eier sondern jongliert viele Bälle.
Onkel_Dithmeyer
- Zlavti
- Universe@home
- Universe@home
- 4x8 GB @ 3000 MHz
- Radeon R9 Nano
- HP ZR30W & HP LP3065
- 2 TB ADATA
- LG
- Im Headset
- Xigmatek
- BeQuiet Dark Pro 9
- GSkill KM570
- GSkill MX780
- Ubuntu 20.04
- Firefox Version 94715469
- ▼100 Mbit ▲5 Mbit
Hast du den Bug schon an AMD gemeldet?
http://www.amd.com/report
maikrosoft
- germany
- Sharkoon SGK 60
- Gigabyte M3
Ja ich habe den Bug mit jedem ReLive Treiber gemeldet und auch das AMD Forum ist voll davon. Vielleicht hat das dortige Forum ja nu eine Alibifunktion und so wirklich interessiert es keinen was da abgeht.
Unbekannter Krieger
- 4x4 GiB Hynix DDR3-1866 ECC
- TSST SH-222AL
- Win8.x x64, Win7 x64
Erst vor Minuten las ich etwas in der Art:maikrosoft schrieb:WOT crashed nach wie vor. Ich könnt mich in den ... beissen dass ich damals nicht zu einer 1060 gegriffen habe.
hardwareluxx.de/index.php/news/software/treiber/41552-amd-und-nvidia-aktualisieren-ihre-treiber.html schrieb:Auch NVIDIA hat einen neuen Treiber veröffentlicht. NVIDIA hält sich mit den Informationen der Änderungen aber etwas zurück bzw. veröffentlicht keine derart ausführliche Beschreibung der Änderungen. Einzig die Behebung eines Fehlers, der dazu geführt hat, dass Battlefield 1 bei Kepler-Grafikkarten abstürzt und es hier zu Darstellungsfehlern bei allen Grafikkarten mit NVIDIA-GPU kommt, wird genannt. Außerdem soll es nicht mehr zu Blackscreens in DOTA 2 kommen.
hardwareluxx.de/community/f153/amd-und-nvidia-aktualisieren-ihre-treiber-1148403.html#post25215034 schrieb:BF1 ist seit Anfang Oktober draussen und nvidia hat es bis dato nicht hingekriegt die DX Crashes in Verbindung mit den Keplerkarten (GTX 6xx/7xx) in BF1 zu lösen. Bei dem letzten großen BF1 Patch sollten die Probleme gelöst eigentlich worden sein - Pustkuchen ein BF1 Mitspieler mit einer Keplerkarte der regelmässig auf Monte Grappa vom Server flog, hatte nch dem Patch eine weitere instabile Karte dazu bekommen mit DX11 Crash (Krieg im Ballsaal), der hatte dann verständlicher Weise die Schnauze voll und hat sich die RX480 geholt und kann jetzt in Ruhe zocken!
Das Ganze gibt es also bei beiden.
Spielst du mit Mods?
hardwareluxx.de/community/f153/amd-veroeffentlicht-die-radeon-software-crimson-relive-edition-17-1-1-a-1149286.html#post25235353 schrieb:Wie gesagt, es kann immer was sein. Ich denke aber das es auch an den installierten Programmen etc liegen. Bei WoT ist es auch fast immer ein MOD schuld. Das ist echt krass. Seit dem ich ohne MODs zocke, gibt es echt null Probleme.
Immerhin etwas. Brauchst du ReLive dringend?Maikrosoft schrieb:Der 16.11.5 läuft wie Schmitts Katze
Das ist wohl nicht mehr aktuell:Selbst der Bug das einige ältere Karten den Speicher nicht hochtakten, besteht seit dem ersten ReLive, wurde nicht gefixt.
http://www.hardwareluxx.de/community/f153/amd-veroeffentlicht-die-radeon-software-crimson-relive-edition-17-1-1-a-1149286.html#post25234757 schrieb:Bei mir wurde er behoben, der Ram ist jetzt ständig am Anschlag16.12.2 ist an sich ein super Treiber mit ordentlichem Perfomanceboost gewesen, wenn nicht der 150 Mhz Bug des Vram bestehen würde.
Anscheinend wurde dieser Bug weder behoben, noch registriert.... Schade.
maikrosoft
- germany
- Sharkoon SGK 60
- Gigabyte M3
Der Speicherbug ist leider immer noch aktuell: https://community.amd.com/thread/211054
WOT spiele ich ohne Mods. Das bei dem HWL User der RAM jetzt nicht mehr runter taktet ist immer noch meilenweit entfernt von einem funktionierendem Treiber.
Effe
- Im Havelland
- Einstein@Home
- WD Blue 1TB; WD Purple 3TB
- Win10 64bit
- Firefox X,; Chrome 10000
Ist das Problem bei WoT auf Polariskarten beschränkt? Ich hab gestern mit einer 380X und dem ReLive 17.1.1. drei Stunden lang WoT(Vanilla) gezockt ohne ein einziges Problem. Win10Pro
maikrosoft
- germany
- Sharkoon SGK 60
- Gigabyte M3
Ja, bei mir betrifft es Karten im Winter. Im WOT Forum gibt es aber auch Rückmeldungen zu anderen Karten.
Edit sagt: Ich konnte mit dem 16.12.2 auch 3 Stunden spielen ohne Crash. Am nächsten Tag kam er dann dafür gleich im 2. Gefecht.
Sightus
- Einige
In der Meldung und auch auf der AMD-Seite steht:
Wenn ich nun aber auf die AMD-Seite gehe und dort versuche die manuelle Treibersuche zu starten, dann gelange ich zu den Legacy-Treibern. Was stimmt denn nu?
EDIT: Vorher fälschlicherweise die R7 230 markiert.
AMD Radeon™ Pro Duo
maikrosoft
- germany
- Sharkoon SGK 60
- Gigabyte M3
Grade probiert, komme mit manueller Auswahl der R7 200er Serie zum 17.1.1
Sightus
- Einige
Ah, sorry. Ich habe beim Zitat einen Fehler gemacht; ich meine die
Oi!Olli
- HP Elitebook 8760W
- Ryzen R7 5800X3D
- Asus B 550 Strix F Wifi
- Acer Predator XB253QGP
- GH-22NS50
- Soundblaster Recon 3d
- Raijintek Zofos Evo Silent
Manche Fehler liegen auch eher auf Seiten der Entwickler. Hat ewig gedauert, bis STO wieder mit AA lief. Und das nach einem Patch von Cryptic, nicht von AMD.
maikrosoft
- germany
- Sharkoon SGK 60
- Gigabyte M3
Nachdem ich gestern wieder mal aus einem Gefecht geflogen bin (musste den Treiber nutzen da der AMD Support ein paar Daten benötigte) habe ich nun einen 24 Stunden Bann bekommen als "Strafe für wiederholtes vorzeitiges Verlassen das Gefechtes".
Langsam ist es nicht mehr feierlich was AMD da treibt.
Nosyboy
- Switzerland
- LENOVO Y520-15, Intel i7-7700HQ, W10-Home
- Ryzen 7 5700X / 7nm / 65W
- Sapphire Radeon RX5700 PULSE 8G
- Samsung C27FG70
- Pioneer BDR-209M
- on Board
- Chieftec Midi Tower
- Corsair RM550x
- Logitech G213
- WIN 10 Pro
- Opera / Edge
- ▼100 MBit ▲20 MBit
Hatte dieselben Probleme mit meiner 470er und wurde zum Glück von WoT (WG) nur verwarnt nach zwei mal Back To Desktop. Interessant war auch dass ich das Spiel nie mehr starten konnte bis ich den Rechner neu gebootet habe...Nachdem ich gestern wieder mal aus einem Gefecht geflogen bin (musste den Treiber nutzen da der AMD Support ein paar Daten benötigte) habe ich nun einen 24 Stunden Bann bekommen als "Strafe für wiederholtes vorzeitiges Verlassen das Gefechtes".
Auch mit Performance Probleme hatte ich zu kämpfen, oft schlechter als meine alte 360er die ich jetzt wieder eingebaut habe.
Mit der 360er null Probleme und stabile 60FPS.
Aber die Performance Probleme sind imo ein Problem der grottigen WoT Engine, bei Armored Warfare war alles gut und hatte auch keine Abstürze.
AMD ist da wohl nicht ganz alleine Schuld...
Da ich aber fast nur WoT spiele ging ich zurück zur 360er und die 470er schaut vom Regal aus zu.
maikrosoft
- germany
- Sharkoon SGK 60
- Gigabyte M3
Nosyboy
- Switzerland
- Samsung C27FG70
- Pioneer BDR-209M
- on Board
- Corsair RM550x
- Logitech G213
- WIN 10 Pro
- Opera / Edge
Ja, keine Ahnung was da gebremst hat. Habe immer noch den Framelimiter auf 60 FPS limitiert, aber eben die konnte er selbst auf mittlerer Auflösung nicht immer halten...
Solche Framedrops sind zwar ein bekanntes Problem wenn man Mods einsetzt (was ich auch tue), aber die waren um einiges stärker als bei der 360er.
Aber alles auf dem aktuellen Treiber, will eigentlich nicht mehr auf einen alten zurück.
Aber interessant ist es ja, dass mit anderen Games kaum Probleme auftraten, also muss es zwingendermassen auch mit dem Game zusammenhängen.
Ich finde man schiebt jeweils viel zu schnell die Schuld dem Hardwarehersteller zu.
skelletor
- Dresden
- einheimische Projekte
- Ryzen 7 5800X3D
- MSI X570-A Pro
- beQuiet DarkRock TF
- AMD Radeon 6900XT
- 1x 4TB WesternDigital Red
- Pioneer BluRay Brenner
- noname
- Seasonic X650 (80+ Gold)
- Swiftpoint Z
- Windows 10 Home 64bit
Ohje, grad den Treiber auf dem Laptop mit A12 APU installiert.
Jetzt habe ich den angeblich als fixed markierten "Blackscreen" Bug. Nach der Installation nur noch der Mauszeiger sichtbar, mehr nicht.
Kann mir jemand sagen, wie ich Windows10 ohne Treiber hochfahre, ohne dass ich was auf dem Monitor sehe (und es demzufolge auch nicht einstellen kann)?
skell.
skell.
Hat Windows 10 keinen abgesicherten Modus mehr?
skelletor
- Dresden
- Ryzen 7 5800X3D
- MSI X570-A Pro
- AMD Radeon 6900XT
- noname
- Swiftpoint Z
Doch, aber den kann man leider nicht mehr beim booten auslösen... nur noch vom bereits gestarteten System sagen, dass der nächste boot "safemode" sein soll.
Macht sich natürlich absolut super, wenn man nach dem booten nur noch einen schwarzen Bildschirm mit einem Mauszeiger sieht...
externer Monitor bringt übrigens auch nichts...
skell.
skell.
