Team Group Releases MP34 M.2 solid state drive (3000MB/s)
April 03, 2019, Taipei_ Tar­ge­ting to expand the capa­ci­ty of our con­su­mers’ sto­rage devices, Team Group today releases three new FLASH pro­ducts. They are the MP34 M.2 solid sta­te dri­ve with PCIe Gen3X4 high speed inter­face and the latest NVME1.3 pro­to­col, the ELITE A1 high-speed memo­ry card which is spe­ci­al­ly made for ANDROID devices and 4K video recor­ding, the C188 high-speed flash dri­ve with ele­gant design and up to 130MB/s of read/write speed. The­se pro­ducts allow con­su­mers to upgrade their PC or mobi­le devices at ease.
Today, Team Group releases the M.2 solid sta­te dri­ve MP34 that uses PCIe Gen3X4 high-speed inter­face and the latest NVMe1.3 pro­to­col. Con­nec­ting to the built-in con­trol­ler of the chip­set and pro­ces­sor through PCI‑e bus pro­vi­des trans­fer signal wit­hout any lag. The trans­fer per­for­mance is remar­kab­le. The trans­fer speed of MP34 is up to 3000MB/s, which is 5 times* hig­her than the SATA III inter­face. It sup­ports S.M.A.R.T and has built-in smart algo­rithm, Wear-Leve­ling tech­no­lo­gy and Error Cor­rec­tion Code. In addi­ti­on to bring the SSD to its maxi­mum per­for­mance and pro­long the ser­vice life, it also sup­ports both Intel and AMD plat­forms. Whe­ther it is instal­led on a desk­top or a lap­top, it will offer con­su­mer the finest and smoot­hest gam­ing experience.
The ELITE A1 high-speed memo­ry card for 4K belongs to UHS‑I Class3 (U3), which is spe­ci­al­ly made for ANDROID devices and tablets. The ran­dom read speed is up to 1500 IOPS, and the ran­dom wri­te speed is up to 500 IOPS. For sto­rage capa­ci­ty, the­re is 256GB available to choo­se from, which allows the appli­ca­ti­ons of mobi­le device to be exe­cu­ted at high speed and wit­hout worry­ing about the capa­ci­ty of instal­led appli­ca­ti­ons. The ELITE A1 high-speed memo­ry card sup­ports 4K Ultra-HD high qua­li­ty recor­ding capa­bi­li­ty, which allows con­su­mers record and cap­tu­re won­derful moments smooth­ly and easi­ly. In addi­ti­on to its stun­ning appearance, the ELITE A1 high-speed memo­ry card is prin­ted with eco-fri­end­ly inks to con­tri­bu­te in pre­ser­ving our planet.
The round and ele­gant C188 3.1 high-speed flash dri­ve has excel­lent tex­tu­re, and a per­fect com­bi­na­ti­on of indi­go color tone and pre­mi­um gol­den cha­rac­ter flash. The beve­led design of the C188 high-speed flash dri­ve has upgraded the over­all tex­tu­re by crea­ting a sleek hand­held fee­ling. The clas­sic design of Team Group’s pre­vious retrac­ta­ble flash dri­ves is con­tin­ued, but the per­for­mance and the trans­fer speed of the flash dri­ve is evol­ved to a total­ly dif­fe­rent level than the pre­vious ones. The C188 offers capa­ci­ties from 32GB to maxi­mum 256GB for con­su­mers to choo­se from accor­ding to their own pre­fe­rence. The read/write per­for­mance is up to 130MB/s, which can great­ly redu­ce the time for file acces­sing. The superb per­for­mance allows con­su­mers to back up their file at ease and tre­asu­re their memo­ry long into the future.
*Trans­mis­si­on speed will vary accor­ding to dif­fe­rent hard­ware / soft­ware con­di­ti­ons, the­r­e­fo­re the data can only used for basic reference.
Learn More
MP34https://www.teamgroupinc.com/en/product/mp34
ELITE A1https://www.teamgroupinc.com/en/product/elite-a1-u3-card
C188https://www.teamgroupinc.com/en/product/c188
Pho­tohttps://drive.google.com/open?id=1_JJ8Noh_sqKbWBaQRyWuEiLuM8ePsEkU
About TEAMGROUP
As a lea­ding pro­vi­der of memo­ry sto­rage pro­ducts and mobi­le appli­ca­ti­ons to the con­su­mer mar­ket, TEAMGROUP Inc is com­mit­ted to pro­vi­ding the best sto­rage, mul­ti­me­dia and data sha­ring solu­ti­ons. All TEAMGROUP’s memo­ry modu­le pro­ducts come with a life­time war­ran­ty, repair and repla­ce­ment ser­vices. TEAMGROUP also lis­ted com­pa­ny at stock exch­an­ge mar­ket in January,2019. In 2016, TEAMGROUP estab­lished T‑FORCE gam­ing series which inclu­ding all the gam­ing memo­ry modu­le. For more infor­ma­ti­on, plea­se visit the TEAMGROUP web­site at www.teamgroupinc.com or Follow
