ASROCK INDUSTRIAL ANNOUNCES THE WORLD’S FIRST AMD-POWERED NUC SOLUTION: iBOX-R1000
Global leader in Industrial & Embedded Computing first to market with NUC solution for AMD’s robust new Ryzen™ Embedded R1000 chip
Tai­pei, Tai­wan (April 16, 2019) ASRock Indus­tri­al Com­pu­ter, the world’s lea­der in Indus­tri­al PC mother­boards, is proud to announ­ce the iBOX-R1000, a turn-key rug­ged embedded PC built to be fle­xi­ble and adap­ta­ble to a wide ran­ge of indus­try appli­ca­ti­ons, inclu­ding AI edge com­pu­ting, visi­on appli­ca­ti­ons and indus­tri­al IoT solutions.
The iBOX-R1000 is the first AMD-powered NUC 4“x4” form fac­tor solu­ti­on in the world. It is a cost-effec­ti­ve and high-per­for­mance embedded, fan­less com­pu­ter for indus­tri­al appli­ca­ti­ons powered by the robust AMD RyzenTM Embedded R1000 SoC. It runs on Micro­soft Win­dows 10 and Linux ker­nel 4.18 and above.
The Ryzen Embedded R1000 SoC sup­ports dual chan­nel DDR4 2400MHz and also ECC memo­ry SO-DIMM up to 32GB. The­re are two ports for Dis­play­Po­rt 1.4 and one for HDMI 2.0 out­put that can dis­play three sepa­ra­te screens at the same time or be con­fi­gu­red to one lar­ge screen. In addi­ti­on, 4K video out­put is supported.
ASRock Industrial’s iBOX-R1000 comes in a rug­ge­dized, metal chas­sis and employs a 25W fan­less design for the toug­hest envi­ron­ments up to 50°C. It has two RJ45 Giga­bit Ether­net ports, one USB2.0 and three USB3.1 con­nec­tors, one COM port for RS-232/422/485 and a power jack for the 12V adap­ter (included). LEDs indi­ca­te power on/off and HDD activity.
Insi­de the housing, the­re is one M.2 (Key M) to sup­port SSD (2242 & 2260), one M.2 (Key E) 2230 for WiFi and Blue­tooth, and one 2.5″ HDD/SSD space.
“We are proud to be the first com­pa­ny in the world to design a NUC 4“x4” form fac­tor com­pu­ter with an AMD pro­ces­sor,” said James Lee, Gene­ral Mana­ger of ASRock Indus­tri­al. “Our exper­ti­se in desig­ning small form-fac­tor com­pu­ters com­bi­ned with the mul­ti­ple fea­tures of the AMD Ryzen Embedded R1000 crea­tes the per­fect pro­duct for appli­ca­ti­ons from Digi­tal Signage to Arca­de Gam­ing and Gambling, Kiosks, IoT Gate­way and Thin Cli­ent Terminals.”
“We’­re exci­ted to part­ner with ASRock Indus­tri­al to intro­du­ce the iBOX-R1000, the world’s first AMD based NUC 4“x4” form fac­tor com­pu­ter, built on the all-new AMD Ryzen Embedded R1000 SoC,” said Ste­phen Turn­bull, direc­tor of pro­duct manage­ment and busi­ness deve­lo­p­ment, Embedded Solu­ti­ons, AMD. “Lever­aging the high-per­for­mance of Ryzen Embedded R1000 and AMD’s full suite of embedded solu­ti­ons, we look for­ward to our con­tin­ued col­la­bo­ra­ti­on with ASRock Industrial.”
For more pro­duct infor­ma­ti­on go to:
https://www.asrockind.com/overview.asp?Model=iBOX-R1000
https://www.asrockind.com/overview.asp?Model=NUC-R1000
ABOUT ASROCK INDUSTRIAL
ASRock Indus­tri­al Com­pu­ter was estab­lished as an inde­pen­dent com­pa­ny in July 2018, focu­sing on the fields of mother­boards, edge com­pu­ters and came­ras, and other pro­ducts for the manu­fac­tu­ring, busi­ness and retail indus­tries. It is the world’s lea­der in Indus­tri­al PC mother­boards, with cus­to­mers loca­ted around the glo­be. Pre­vious­ly, it had been a busi­ness unit of ASRock Inc. (est. 2002) which was set up in 2011.
By beco­ming an inde­pen­dent com­pa­ny ASRock Indus­tri­al can devo­te all its resour­ces to B2B acti­vi­ties. Our pro­ducts ser­ve the Com­mer­ce, Auto­ma­ti­on, Robot, Enter­tain­ment and Secu­ri­ty indus­tries. With a core R&D design team of almost 65% of total staff, ASRock Indus­tri­al has the resour­ces to deve­lop relia­ble, lea­ding-edge pro­ducts for your busi­ness needs. All pro­ducts can be bought off-the shelf or cus­to­mi­zed to the demands of OEMs/ODMs.
