AMD Launches World’s First 7nm Professional PC Workstation Graphics Card for 3D Designers, Architects and Engineers
— AMD Rade­on™ Pro W5700 gra­phics card harnes­ses high-per­for­mance AMD RDNA archi­tec­tu­re,
indus­try-lea­ding pro­cess tech­no­lo­gy and enter­pri­se-gra­de soft­ware to help pro­fes­sio­nals increase
pro­duc­ti­vi­ty, impro­ve pro­duct qua­li­ty and acce­le­ra­te time-to-market —
— AMD RDNA archi­tec­tu­re deli­vers up to 25 per­cent hig­her per­for­mance-per-clock 1 and up to 41 per­cent
hig­her avera­ge per­for­mance-per-watt 2 than the pre­vious-gene­ra­ti­on AMD archi­tec­tu­re to power
deman­ding 3D design, real-time visua­liza­ti­on and VR workloads —
San­ta Cla­ra, Calif. — Novem­ber 19, 2019 — AMD (NASDAQ: AMD) today announ­ced the AMD
Rade­on™ Pro W5700, the world’s first 7nm pro­fes­sio­nal PC work­sta­tion gra­phics card. It deli­vers new
levels of per­for­mance and advan­ced fea­tures that enable 3D desi­gners, archi­tects and engi­neers to
visua­li­ze, review and inter­act with their designs in real time, dra­ma­ti­cal­ly acce­le­ra­ting decis­i­on-making
pro­ces­ses and pro­duct deve­lo­p­ment cycles.
The AMD Rade­on Pro W5700 work­sta­tion gra­phics card fea­tures the high-per­for­mance, ener­gy-
effi­ci­ent AMD RDNA archi­tec­tu­re and sta­te-of-the-art GDDR6 memo­ry to hand­le lar­ge models and
data­sets, and is the first PC work­sta­tion gra­phics card to sup­port high-band­width PCIe® 4.0 tech­no­lo­gy.
It is ide­al for pro­fes­sio­nals who push per­for­mance bey­ond tra­di­tio­nal 3D design by gene­ra­ting
pho­to­rea­li­stic ren­ders of their con­cepts and revie­w­ing vir­tu­al pro­to­ty­pes of their designs in vir­tu­al
rea­li­ty (VR) environments.
“Today’s pro­fes­sio­nals need high-per­for­mance pro­fes­sio­nal gra­phics hard­ware to bet­ter inter­act
with their pro­duct con­cepts and make more infor­med decis­i­ons soo­ner in the design pro­cess,” said Scott
Her­kel­man, cor­po­ra­te vice pre­si­dent and gene­ral mana­ger, Rade­on Tech­no­lo­gies Group at AMD. “We
desi­gned the AMD Rade­on Pro W5700 to deli­ver signi­fi­cant per­for­mance gains in top design and manu­fac­tu­ring appli­ca­ti­ons. Archi­tects, desi­gners and engi­neers now have the hor­se­power to dri­ve deman­ding real-time and VR expe­ri­en­ces, enab­ling a bet­ter and fas­ter design crea­ti­on process.”
Key capa­bi­li­ties and fea­tures of the AMD Rade­on Pro W5700 gra­phics card include:
• High-Per­for­mance AMD RDNA Archi­tec­tu­re – Fea­tures a rede­si­gned geo­me­try engi­ne and
com­pu­te units, deli­ve­ring up to 25 per­cent hig­her per­for­mance-per-clock 1 and up to 41
per­cent hig­her avera­ge per­for­mance-per-watt 2 than the pre­vious-gene­ra­ti­on Gra­phics Core
Next (GCN) architecture.
• Excep­tio­nal Power Effi­ci­en­cy – AMD Rade­on™ Pro Soft­ware for Enterprise’s intel­li­gent
power opti­miza­ti­on, cou­pled with the power-effi­ci­ent AMD RDNA archi­tec­tu­re and 7nm
pro­cess tech­no­lo­gy, enables the Rade­on Pro W5700 gra­phics card to pro­vi­de up to 18
per­cent bet­ter sys­tem effi­ci­en­cy than the com­pe­ti­ti­ve pro­duct 3 .
• Acce­le­ra­ted CPU/GPU Mul­ti­tas­king – Pro­vi­des out­stan­ding mul­ti­tas­king per­for­mance even
in the most deman­ding situa­tions, such as con­ti­nuing to model while ren­de­ring a
visua­liza­ti­on in the back­ground, pro­vi­ding up to 5.6X the appli­ca­ti­on work­flow per­for­mance
with CPU load than the com­pe­ti­ti­on in the SPECview­perf® 13 bench­mark 4 .
• Pro­fes­sio­nal-gra­de Soft­ware – AMD Rade­on Pro Soft­ware for Enter­pri­se deli­vers
pro­fes­sio­nal-gra­de qua­li­ty, con­ti­nuous per­for­mance impro­ve­ments and robust secu­ri­ty as
well as indus­try-lea­ding fea­tures, inclu­ding AMD Remo­te Work­sta­tion 5 that allows
pro­fes­sio­nals to work vir­tual­ly from any­whe­re with fea­ture and per­for­mance pari­ty with the
work­sta­tion GPU on their desk 6 .
• Inno­va­ti­ve VR Soft­ware Fea­tures – AMD Rade­on™ ReLi­ve for VR enables pro­fes­sio­nals using
AMD Rade­on Pro W5700 gra­phics cards to wire­less­ly visua­li­ze their crea­ti­ons with VR-
capa­ble appli­ca­ti­ons and sel­ect stan­da­lo­ne VR head­sets, such as the HTC VIVE Focus™ Plus 7 .
• High-band­width PCIe® 4.0 – The AMD Rade­on Pro W5700 is the first PC work­sta­tion
gra­phics card to sup­port PCIe 4.0, deli­ve­ring dou­ble the band­width of PCIe® 3.0 to enable
smooth per­for­mance for GPU-inten­si­ve applications.
• Pro­fes­sio­nal Appli­ca­ti­on Cer­ti­fi­ca­ti­on – Opti­mi­zed and cer­ti­fied with lea­ding Design and
Manu­fac­tu­ring and Archi­tec­tu­re, Engi­nee­ring and Con­s­truc­tion appli­ca­ti­ons to deli­ver the
sta­bi­li­ty and relia­bi­li­ty requi­red by work­sta­tion pro­fes­sio­nals. The list of Rade­on Pro
Soft­ware cer­ti­fied ISV appli­ca­ti­ons can be found here.
• High-speed USB‑C® – The AMD Rade­on™ Pro W5700 is the first PC work­sta­tion gra­phics
card to include a USB‑C® con­nec­tor, sup­port­ing a gro­wing sel­ec­tion of USB‑C® based
moni­tors and head-moun­ted dis­plays (HMD).
Com­pu­te
Units
TFLOPS
(FP32)
GDDR6
Memo­ry
Band­width
Memo­ry
Inter­face
Dis­play
Out­puts
Rade­on™ Pro
W5700
graphics
36 Up to 8.89 8GB Up to
448 GB/s
256-bit 6
AMD Rade­on Pro W5700 gra­phics card is expec­ted to available start­ing today for USD $799 SEP from
the fol­lo­wing retail­ers, inclu­ding:
• North Ame­ri­ca – B&H Pho­to and Newegg
• EMEA – Elm­tec, Schnei­der and Tarox
• Asia Paci­fic – JD.com and Mwave
The AMD Rade­on Pro W5700 gra­phics card will be demons­tra­ted in the AMD booth (#AE310) at
Auto­desk Uni­ver­si­ty 2019, Novem­ber 19 to 21 in Las Vegas, Nevada.
Sup­port­ing Resour­ces
• Learn more about AMD Rade­on™ Pro W5700 gra­phics card here
• Beco­me a fan of AMD on Face­book
• Fol­low AMD on Twit­ter
• Fol­low Rade­on™ Pro gra­phics on Twitter
About AMD
For 50 years AMD has dri­ven inno­va­ti­on in high-per­for­mance com­pu­ting, gra­phics and visua­liza­ti­on
tech­no­lo­gies ― the buil­ding blocks for gam­ing, immersi­ve plat­forms and the dat­a­cen­ter. Hundreds of mil­li­ons of con­su­mers, lea­ding For­tu­ne 500 busi­nesses and cut­ting-edge sci­en­ti­fic rese­arch faci­li­ties
around the world rely on AMD tech­no­lo­gy dai­ly to impro­ve how they live, work and play. AMD
employees around the world are focu­sed on buil­ding gre­at pro­ducts that push the boun­da­ries of what is
pos­si­ble. For more infor­ma­ti­on about how AMD is enab­ling today and inspi­ring tomor­row, visit the AMD
(NASDAQ: AMD) web­site, blog, Face­book and Twit­ter pages.
©2019 Advan­ced Micro Devices, Inc. All rights reser­ved. AMD, the AMD Arrow logo, Rade­on, and com­bi­na­ti­ons the­reof are trade­marks of
Advan­ced Micro Devices, Inc. . Auto­desk and the Auto­desk logo are regis­tered trade­marks or trade­marks of Auto­desk, Inc., and/or its
sub­si­dia­ries and/or affi­lia­tes in the USA and/or other count­ries. PCIe is a regis­tered trade­mark of PCI-SIG Cor­po­ra­ti­on. USB Type‑C® and USB‑C®
are regis­tered trade­marks of the USB Imple­ment­ers Forum. Other pro­duct names used in this publi­ca­ti­on are for iden­ti­fi­ca­ti­on pur­po­ses only
and may be trade­marks of their respec­ti­ve companies.
1 RDNA pro­vi­des up to 1.25x hig­her per­for­mance per clock over GCN. Test­ing done by AMD per­for­mance labs 5/23/19, show­ing a geo­me­an of
1.25x per/clock across 30 dif­fe­rent games @ 4K Ultra, 4xAA set­tings. Per­for­mance may vary based on use of latest dri­vers. RX-327
2 The AMD RDNA archi­tec­tu­re deli­vers up to 41% hig­her avera­ge per­for­mance per watt than the pre­vious AMD GCN archi­tec­tu­re when tes­ted
with the SPECview­perf® 13 bench­mark sw-04 view­set, creo-02 view­set, 3ds­max-06 view­set, Ens­cape “Man­si­on” demo, Unity inter­nal
auto­mo­ti­ve bench­mark, and the Unity VR demo “Lon­don Office”. Test­ing as of Octo­ber 25, 2019 by AMD Per­for­mance Labs on a pro­duc­tion
sys­tem com­pri­sed of an Intel® Xeon® W‑2125, 32GB DDR4 RAM, Win­dows® 10 Pro for Work­sta­tions, 64-bit, Sys­tem BIOS 1.11.1, AMD Rade­on™
Pro W5700 gra­phics powered by the RDNA archi­tec­tu­re, AMD Rade­on™ Pro Soft­ware for Enter­pri­se 19.Q4 ver­sus AMD Rade­on™ Pro WX 8200
gra­phics card powered by the GCN archi­tec­tu­re. Metric: Cal­cu­la­te per­for­mance per watt with bench­mark appli­ca­ti­on score divi­ded by GPU
wat­ta­ge, and then avera­ge across a varie­ty of bench­mark appli­ca­ti­ons. AMD Rade­on™ Pro W5700 gra­phics power TDP: 190W. AMD Rade­on™
Pro WX8200 gra­phics power TDP: 230W. Note: TDP of the AMD Rade­on™ Pro W5700 was adjus­ted to 190W to reflect actu­al TDP for gra­phics,
and not include TDP for USB (the WX 8200 does not have USB) for pari­ty. Bench­mark Appli­ca­ti­on: SPECview­perf 13 snx-03. AMD Rade­on™ Pro
W5700 score: 342.49. AMD Rade­on™ Pro WX8200 score: 297.47. Bench­mark Appli­ca­ti­on: SPECview­perf 13 creo-02. AMD Rade­on™ Pro W5700
score: 219.99. AMD Rade­on™ Pro WX8200 score: 196.49. Bench­mark Appli­ca­ti­on: SPECview­perf 13 3ds­max-06. AMD Rade­on™ Pro W5700
score: 181.98. AMD Rade­on™ Pro WX8200 score: 161.34. Addi­tio­nal infor­ma­ti­on about the SPEC bench­marks can be found at
www.spec.org/gwpg. SPEC® and SPECview­perf® are regis­tered trade­marks of the Stan­dard Per­for­mance Eva­lua­ti­on Cor­po­ra­ti­on. RPW-262
3 The same com­pu­ter equip­ped with AMD Rade­on™ Pro Soft­ware for Enter­pri­se 19.Q4 with Rade­on™ Pro W5700 con­su­mes up to 18% less
power in SOLIDWORKS® solid model­ling work­flows com­pared to the NVIDIA Qua­dro® dri­ver 440.97 with NVIDIA Qua­dro RTX™ 4000. Test­ing
con­duc­ted by AMD Per­for­mance Labs as of Octo­ber 24th 2019 on AMD Rade­on™ Pro Soft­ware for Enter­pri­se 19.Q4 with Rade­on™ Pro W5700
and NVIDIA Qua­dro® dri­ver 440.97 with NVIDIA Qua­dro RTX™ 4000, on a test sys­tem com­pri­sing an Intel® Core™ i9-9900K, 32 GB 2133 MHz
DDR4 RAM, MSI Z370‑A Pro mother­board with BIOS ver­si­on 7B48v2A, 512 GB Intel 760p SSD, and Win­dows 10 May 2019 Update. Power was
mea­su­red using the avera­ge of second-by-second value rea­douts from a Kill A Watt P3 P3IP4400 watt­me­ter over a 30 second time­span spent in
a SOLIDWORKS® 2019 solid model­ling work­flow. Results may vary. RPS-110
4 The AMD Rade­on™ Pro W5700 gra­phics card when using AMD Rade­on™ Pro Soft­ware for Enter­pri­se 19.Q4 pro­vi­des up to 5.6x the appli­ca­ti­on
work­flow per­for­mance while mul­ti­tas­king in the SPECview­perf® 13 sw-04 SW2012_shaded bench­mark when com­pared to the NVIDIA Qua­dro
RTX™ 4000 gra­phics card using the NVIDIA Qua­dro® Opti­mal Dri­ver for Enter­pri­se (ODE) R430 U4 (431.02). Test­ing as of Octo­ber 25, 2019 by
AMD Per­for­mance Labs on pro­duc­tion sys­tem com­pri­sed of an Intel® Xeon® W‑2125, 32GB DDR4 RAM, Win­dows® 10 Pro for Work­sta­tions, 64-
bit, Sys­tem BIOS 1.11.1, AMD Rade­on™ Pro W5700, AMD Rade­on™ Pro Soft­ware for Enter­pri­se 19.Q4/NVIDIA Qua­dro RTX™ 4000, NVIDIA
Qua­dro® Opti­mal Dri­ver for Enter­pri­se (ODE) R430 U4 (431.02). Bench­mark appli­ca­ti­on and deri­ved metric cal­cu­la­ti­on: ran the SPECview­perf®
13 bench­mark sw-04 SW2012_shaded test with the Coro­na Ren­de­rer 1.3 CPU bench­mark run­ning simul­ta­neous­ly to gene­ra­te the appli­ca­ti­on
work­flow per­for­mance with mul­ti­tas­king. Cal­cu­la­ted the per­for­mance when mul­ti­tas­king as a per­cen­ta­ge then cal­cu­la­ted the ratio bet­ween the
two per­cen­ta­ges. AMD RADEON™ PRO W5700 RESULTS: AMD Rade­on™ Pro W5700 with SPECview­perf® 13 sw-04 SW2012_shaded test results
with the Coro­na Ren­de­rer 1.3 CPU bench­mark run­ning simul­ta­neous­ly: AMD Rade­on™ Pro W5700 SPECview­perf® 13 sw-04 SW2012_shaded
test results: 1075.51 FPS. AMD Rade­on™ Pro W5700 with SPECview­perf® 13 sw-04 SW2012_shaded test results with the Coro­na Ren­de­rer 1.3
CPU bench­mark run­ning simul­ta­neous­ly: 957.07 FPS. 88.99% of the work­flow per­for­mance com­pared to the per­for­mance when not
mul­ti­tas­king on the AMD Rade­on™ Pro W5700 gra­phics card. NVIDIA QUADRO RTX™ 4000 RESULTS: NVIDIA Qua­dro RTX™ 4000 with
SPECview­perf® 13 sw-04 SW2012_shaded test results with the Coro­na Ren­de­rer 1.3 CPU bench­mark run­ning in the back­ground: NVIDIA Qua­dro
RTX™ 4000 SPECview­perf® 13 sw-04 SW2012_shaded test results: 868.09 FPS. NVIDIA Qua­dro RTX™ 4000 with SPECview­perf® 13 sw-04
SW2012_shaded test with the Coro­na Ren­de­rer 1.3 CPU bench­mark run­ning in the back­ground: 138.66 FPS. 15.97% of the work­flow
per­for­mance com­pared to the per­for­mance when not mul­ti­tas­king on the NVIDIA Qua­dro RTX™ 4000 gra­phics card. Results may vary.
Addi­tio­nal infor­ma­ti­on about the SPEC bench­marks can be found at www.spec.org/gwpg. SPEC® and SPECview­perf® are regis­tered trade­marks
of the Stan­dard Per­for­mance Eva­lua­ti­on Cor­po­ra­ti­on. RPW-264
5 Com­pa­ti­ble with AMD Rade­on™ Pro WX 3200, WX 4100, WX 5100, WX 7100, WX 8200, WX 9100 and W5700 GPUs. Remo­te Work­sta­tion
func­tion­a­li­ty requi­res AMD Rade­on™ Pro Soft­ware for Enter­pri­se dri­ver 18.Q4 or newer plus purcha­se and instal­la­ti­on of Citrix Vir­tu­al Apps &
Desk­tops™ or Micro­soft® Remo­te Desk­top Ser­vices. RPS-50
6 Rade­on™ Pro Soft­ware for Enter­pri­se 19.Q2 with AMD Remo­te Work­sta­tion deli­vers com­pa­ra­ble per­for­mance on SPECview­perf® 13 3ds­max-
06 when com­pared local (non-remo­ted) per­for­mance. Test­ing con­duc­ted by AMD labs as of April 22nd, 2019 on a test sys­tem com­pri­sing of
Intel® Core i5 8400 CPU, MSI Z370‑A PRO mother­board, ADATA XPG Z1 16 GB DDR4 RAM, Sam­sung 860 EVO 250GB SSD, Win­dows® 10 Pro
Octo­ber 2018 Update with a Rade­oRa­de­on™ Pro Soft­ware for Enter­pri­se 19.Q2 with AMD Remo­te Work­sta­tion deli­vers com­pa­ra­ble
per­for­mance on SPECview­perf® 13 3ds­max-06 when com­pared local (non-remo­ted) per­for­mance. Test­ing con­duc­ted by AMD labs as of April
22nd, 2019 on a test sys­tem com­pri­sing of Intel® Core i5 8400 CPU, MSI Z370‑A PRO mother­board, ADATA XPG Z1 16 GB DDR4 RAM, Sam­sung
860 EVO 250GB SSD, Win­dows® 10 Pro Octo­ber 2018 Update with a Rade­on™ Pro WX 4100 gra­phics card using Rade­on™ Pro Soft­ware for
Enter­pri­se 19.Q2. Test was con­duc­ted using run­ning bench­mark the appli­ca­ti­on SPECview­perf® 13 bench­mark for its “3ds­max-06” view­set
sub­test. Rade­on Pro Soft­ware Adre­na­lin 2019 Edi­ti­on for Enter­pri­se 19.Q2 with Rade­on™ Pro Remo­te Work­sta­tion: 50.22. 19.Q2 run local­ly:
51.36 resul­ting in only up to a 2% drop. The results are the avera­ge of 3 ite­ra­ti­ons. The AMD Remo­te Work­sta­tion solu­ti­on was imple­men­ted
using the Citrix® Xen­Desk­top® 7.18 appli­ca­ti­on on an HP ZBook 17 G5 Cli­ent. Per­for­mance Dif­fe­ren­ti­al: 51.36–50.22 = ~2.0% per­for­mance drop
with the AMD Remo­te Work­sta­tion solu­ti­on on Rade­on™ Pro Soft­ware for Enter­pri­se 19.Q2 ver­sus run­ning local­ly. Addi­tio­nal infor­ma­ti­on
about the SPEC bench­marks can be found at www.spec.org/gwpg. RPS-53 n™ Pro WX 4100 gra­phics card using Rade­on™ Pro Soft­ware for
7 Rade­on™ ReLi­ve for VR for work­sta­tion wire­less VR use requi­res HTC VIVE Focus™ Plus head­set. For VR con­nec­ti­vi­ty, an 802.11ac 5 GHz rou­ter
or access point is requi­red. Com­pa­ti­ble with AMD Rade­on™ VR Rea­dy Crea­tor pro­ducts (learn more at
https://www.amd.com/en/technologies/vr-ready-creator). Sup­ports: Win­dows® 10. RPS-108
