BIOSTAR ANNOUNCES THE LATEST B550MX/E PRO and B550MH/E PRO MOTHERBOARDS
BEST AMD MOTHERBOARDS FOR BUSINESS AND CASUAL USE
April 20th, 2021, Tai­pei, Tai­wan — BIOSTAR, a lea­ding manu­fac­tu­rer of mother­boards, gra­phics cards, and sto­rage devices today, announ­ces the latest B550MX/E PRO and B550MH/E PRO motherboards.
B550MX/E PRO
  B550MH/E PRO
Built on AMD’s B550 sin­gle chip archi­tec­tu­re, the latest B550 series mother­boards are desi­gned to sup­port AMD Ryzen 3rd Gen (Matisse/Renoir) and 4th Gen (Ver­meer) processors.
Ide­al for busi­ness and casu­al use, the new B550 series mother­boards from BIOSTAR are packed with all the latest essen­ti­als for a long-las­ting user experience.
B550MX/E PRO
   B550MH/E PRO
Both new mother­boards come with the capa­bi­li­ty to sup­port up to 128Gb of DDR4 fast-paced memo­ry with an over­clo­cking capa­bi­li­ty of 4933+ OC.
PCIe 4.0 and PCIe M.2 4.0 pro­vi­de excel­lent con­nec­ti­vi­ty for gra­phics and sto­rage expan­si­on for all occa­si­ons with BIOSTAR’s pro­prie­ta­ry Digi­tal PWM tech­no­lo­gy pro­vi­ding safe sta­ble power manage­ment across all components.
When it comes to rear I/O the new B550MX/E PRO mother­board has all the bells and whist­les. From 6 USB ports con­sis­ting of 4 x USB 3.2 (Gen1) ports and 2 x USB 2.0 ports to a sin­gle 1 x PS/2 Keyboard/Mouse port, the B550MX/E PRO mother­board is desi­gned to be extre­me­ly user friendly.
Fur­ther­mo­re, 2 x WiFi Anten­na ports with the capa­bi­li­ty to run WiFi 6 and a sin­gle LAN port powered by Real­tek RTL8111H chip­set are rea­di­ly available in the mother­board for fas­ter inter­net connectivity.
The B550MX/E PRO mother­board comes with a sin­gle dis­play port, a sin­gle VGA out port as well as an HDMI 2.1 port capa­ble of sup­port­ing up to 4K, vivid, crys­tal clear images. This tog­e­ther with the 3 audio ports powered by the ALC897 chip­set is capa­ble of pro­vi­ding the users with an extre­me­ly immersi­ve audio-visu­al experience.
The B550MH/E PRO mother­board also comes with all the essen­ti­als expec­ted from a mother­board of its class. With 6 USB ports in the con­fi­gu­ra­ti­on of 4 x USB 3.2 (Gen1) ports, 2 x USB 2.0 ports as well as a sin­gle 1 x PS/2 Keyboard/Mouse port for user pre­fe­rence simi­lar to its counterpart.
Simi­lar to the B550MX/E PRO mother­board, the B550MH/E PRO mother­board also comes with 2 x WiFi Anten­na ports with the capa­bi­li­ty to run WiFi 6 and a sin­gle LAN port powered by Real­tek RTL8111H chipset.
For gra­phics out­put, the B550MH/E PRO mother­board is equip­ped with a sin­gle VGA out port as well as an HDMI 2.1 port capa­ble of sup­port­ing up to 4K dis­play out­put for an immersi­ve, unhin­de­red user expe­ri­ence and is enhan­ced by the 3 audio ports powered by the ALC897 chip­set is capa­ble of pro­vi­ding 7.1 Chan­nels, High Defi­ni­ti­on Audio for that thril­ling enter­tain­ment experience.
B550MX/E PRO
  B550MH/E PRO
In Con­clu­si­on, the new B550MX/E PRO and B550MH/E PRO mother­boards from BIOSTAR are extre­me­ly effi­ci­ent for what they offer. With AMD’s out­stan­ding per­for­mance cou­pled with BIOSTAR’s world-class pro­duct qua­li­ty and tech­no­lo­gy, the­se two mother­boards are the best choice for users loo­king to build their next office work­sta­tion or even a home enter­tain­ment system.
Key Fea­tures
Digi­tal PWM
  • Increa­ses sys­tem efficiency
  • Has fas­ter tran­si­ent performance
  • Deli­vers sta­ble power and reliability
PCIe 4.0
  • Sup­ports a 16GT/s bit rate
  • Main­ta­ins back­ward compatibility
  • It’s 2X band­width than PCIe 3.0
PCIe M.2 4.0
  • Deli­vers lower latency
  • Deli­vers the hig­hest band­width 64Gb/s
  • It’s 2 times fas­ter than PCIe M.2 3.0
Debug LED
  • Informs you on the sta­tus of your board or hardware
  • Helps you iden­ti­fy any issues going with your board or hardware
WiFi 6 (No Wifi 6 card included)
  • Impro­ves net­work efficiency
  • Pro­vi­des a wider ran­ge to increase net­work capacity
Spec table:
  B550MX/E PRO B550MH/E PRO
Chip­set AMD B550 AMD B550
CPU SUPPORT Socket AM4 sup­port AMD Ryzen 3rd Gen (Matisse/ Renoir) and Ryzen 4th Gen
(Vermeer/ Future) processors
Sup­port for future AMD Ryzen pro­ces­sors with BIOS update
*Plea­se refer to www.biostar.com.tw for CPU sup­port list.
MEMORY 4th Gen AMD Ryzen Pro­ces­sors (Ver­meer CPUs/ Future APUs):
Sup­ports Dual Chan­nel DDR4 4400+(OC)/ 4000(OC)/ 3800(OC)/ 3600(OC)/ 3200/ 2933/ 2667/ 2400/ 2133
3rd Gen AMD Ryzen Pro­ces­sors (Matis­se CPUs):
3rd Gen AMD Ryzen with Rade­on Gra­phics Pro­ces­sors (Renoir APUs):
Sup­ports Dual Chan­nel DDR4 4933+(OC)/ 4800(OC)/ 4600(OC)/ 4400(OC)/ 4000(OC)/ 3800(OC)/ 3600(OC)/ 3200/ 2933/ 2667/ 2400/ 2133
4 x DDR4 DIMM Memo­ry Slots, Max. Sup­ports up to 128 GB Memory
Each DIMM sup­ports non-ECC and ECC Un-buf­fe­r­ed 8/ 16/ 32 GB DDR4 module
*Plea­se refer to www.biostar.com.tw for Memo­ry sup­port list.
INTEGRATED VIDEO By CPU model
Sup­ports DX12
Sup­ports HDCP
By CPU model
Sup­ports DX12
Sup­ports HDCP
STORAGE – Total sup­ports 2 x M.2 socket and 4 x SATA III (6Gb/s) ports
4 x SATA III Con­nec­tors (6Gb/s): Sup­ports AHCI & RAID 0, 1, 10
1 x M.2 (M Key) Socket (M2_PCIEG4_64G_SATA):
Sup­ports M.2 Type 2242/ 2260/ 2280 SSD module
Sup­ports PCIe 4.0 x4 (64Gb/s)/ 3.0 x4 (32Gb/s) — NVMe/ AHCI & SATA III (6.0Gb/s) SSD
1 x M.2 (M Key) Socket (M2_PCIEG3_32G_SATA):
Sup­ports PCIe 3.0 x4 (32Gb/s) — NVMe/ AHCI & SATA III (6.0Gb/s) SSD
*M.2 (M Key) Socket (M2_PCIEG4_64G_SATA): The band­width is depen­ded on CPU. Sup­ports PCIe 4.0 x4 (64Gb/s) speed, which depends only on Ryzen 3rd Gen Matis­se and 4th Gen Ver­meer CPUs.
LAN Real­tek RTL8111H
10/ 100/ 1000 Mb/s auto nego­tia­ti­on, Half / Full duplex capability
Real­tek RTL8111H
CODEC ALC897
7.1 Chan­nels, High Defi­ni­ti­on Audio, Hi-Fi (Front)
ALC897
USB 6 x USB 3.2 (Gen1) ports (4 on rear I/Os and 2 via inter­nal headers)
6 x USB 2.0 ports (2 on rear I/Os and 4 via inter­nal headers)
EXPANSION SLOT 1 x PCIe 4.0/ 3.0 x16 Slot (PCIEG4X16):
Sup­ports PCIe 3.0 x16/ 4.0 x16 mode with AMD Ryzen processors.
Sup­ports PCIe 3.0 x16 mode AMD Ryzen with Rade­on Vega Gra­phics processors.
1 x PCIe 3.0 x16 Slot (PCIEG3X4): Sup­ports x4 mode
1 x PCIe 3.0 x1 Slot (PCIEG3X1)
*Accor­ding to dif­fe­rent CPUs will have dif­fe­rent speeds.
*PCIe 4.0 speed only for AMD Ryzen 3rd Gen Matis­se and 4th Gen Ver­meer CPUs.
*When using PCIe x1 slot (PCIEG3X1), PCIe x16 slot (PCIEG3X4) will be adjus­ted to x2 lanes.
REAR I/O 2 x WIFI Anten­na Ports
1 x PS/2 Key­board / Mouse
1 x DVI‑D Port
1 x VGA Port
1 x HDMI Port
1 x LAN port
4 x USB 3.2 (Gen1) Ports
2 x USB 2.0 Ports
3 x Audio Jack
1 x VGA Port
1 x HDMI Port
1 x LAN port
2 x USB 2.0 Ports
3 x Audio Jack
INTERNAL I/O 4 x SATA III (6.0Gb/s) Connectors
1 x M.2 (E Key) Socket: Sup­ports 2230 type Wi-Fi & Blue­tooth module
2 x USB 2.0 Hea­ders (each hea­der sup­ports 2 USB 2.0 ports)
1 x USB 3.2 (Gen1) Hea­der (each hea­der sup­ports 2 USB 3.2 (Gen1) ports)
1 x 8‑Pin Power Connector
1 x 24-Pin Power Connector
1 x CPU Fan Connector
2 x Sys­tem Fan Connectors
1 x Front Panel Header
1 x Front Audio Header
1 x Inter­nal Ste­reo Spea­k­er Header
1 x Clear CMOS Header
1 x S/PDIF out Connector
1 x COM Port Header
1 x TPM Header
1 x SYSTEM Sta­tus LED
*M.2 (E key) WiFi card is not provided
1 x COM Port Header
1 x TPM Header
H/W MONITORING CPU / Sys­tem Tem­pe­ra­tu­re Monitoring
CPU / Sys­tem Fan Monitoring
Smart / Manu­al CPU Fan Control
Sys­tem Vol­ta­ge Monitoring
DIMENSION Micro-ATX Form Fac­tor: 24.4 cm x 24.4 cm Micro-ATX Form Fac­tor: 24.4 cm x 24.4 cm
OS SUPPORT Win­dows 10(64bit)
*BIOSTAR reser­ves the right to add or remo­ve sup­port for any OS with or wit­hout notice.
Win­dows 10(64bit)
ACCESSORIES 2 x SATA Cables
1 x I/O Shield
1 x Ful­ly Set­up Dri­ver CD
1 x Quick Guide
1 x WiFi anten­na accessories
2 x SATA Cables
1 x I/O Shield
1 x Quick Guide
Read more about B550MX/E PRO and B550MH/E PRO here:
B550MX/E PRO: https://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=1011
B550MH/E PRO: (coming soon)
Con­nect with Us
Face­book: www.facebook.com/BiostarHQ
Twit­ter: https://twitter.com/BIOSTAR_Global
Insta­gram: www.instagram.com/biostarofficial
Lin­ke­din: https://bit.ly/3eJvF6I
You­Tube: www.youtube.com/user/BiostarTaiwan
Avai­la­bi­li­ty: http://www.biostar.com.tw/app/en/wheretobuy/index.php
BIOSTAR VIP Care: https://store.biostar.com.tw/customer
ABOUT BIOSTAR
BIOSTAR, is a pro­fes­sio­nal brand dedi­ca­ted to the pro­duc­tion of mother­boards, gam­ing mother­boards, SSD, gra­phics cards, indus­tri­al com­pu­ting sys­tems, IoT, cryp­to mining equip­ment, health­ca­re solu­ti­ons and motor start bat­tery. Sin­ce its estab­lish­ment in 1986, BIOSTAR has beco­me a major mother­board sup­pli­er in the IT indus­try. In order to pur­sue the best qua­li­ty and aes­the­tic design, BIOSTAR has inves­ted hea­vi­ly in ID design, equip­ment, glo­bal mar­ke­ting rese­arch as well as R&D. With a con­stant empha­sis on qua­li­ty, BIOSTAR always seeks to impro­ve bey­ond bet­ter and race to the future.
