Striving for Perfection — GIGABYTE Launches Extreme AORUS Gaming Desktops Powered by AMD
Mul­ti­ple veri­fi­ca­ti­ons and tuning pro­vi­de a per­fect match of cool, quiet, and powerful performance
Tai­pei, Tai­wan, May 4th, 2021 – GIGABYTE TECHNOLOGY Co. Ltd, a lea­ding manu­fac­tu­rer of mother­boards and gra­phics cards, today pre­sen­ted two gam­ing sys­tems of AMD X570 plat­form with AORUS MODEL X and AMD B550 plat­form with mini sys­tem AORUS MODEL S, which adopt the top-notch com­pon­ents and mate­ri­als for extre­me per­for­mance. Enhan­ced by the strict veri­fi­ca­ti­on and lea­ding tech­no­lo­gy, GIGABYTE pro­vi­des the PC sys­tem of extre­me per­for­mance with opti­mi­zed heat dis­si­pa­ti­on and acou­stic con­trol. The sys­tem main­ta­ins cool and quiet even under the full ope­ra­ti­on, which balan­ce the high per­for­mance and low tem­pe­ra­tu­re to keep the sys­tem acou­stic under 40dB wit­hout thrott­ling. Fur­ther­mo­re, the three-year war­ran­ty of full sys­tem offers an ease and com­pre­hen­si­ve ser­vice for users.
“When tack­ling the uplift of PC per­for­mance, mul­ti-core, high fre­quen­cy, and copious sto­rage beco­me a must to the pre­mi­um PC plat­form, as well as how to make the best com­pon­ents matrix to pro­vi­de the opti­mi­zed per­for­mance with relia­bi­li­ty turns into more ine­vi­ta­ble.“ indi­ca­ted by Eddie Lin, Vice Pre­si­dent of the GIGABYTE Chan­nel Solu­ti­ons. “The new AORUS sys­tem is well-tem­pe­red by mul­ti­ple veri­fi­ca­ti­on and tuning of GIGABYTE’s R&D team, which pro­vi­de a per­fect match of cool, quiet, and powerful per­for­mance with com­pa­ti­bi­li­ty and three-year who­le sys­tem warranty.
AORUS MODEL X and AORUS MODEL S are built with AMD R9 5900X pro­ces­sor and NVIDIA RTX 3080 VGA card which are almost unvia­ble in the mar­ket. Choo­sing from various RAM con­fi­gu­ra­ti­on veri­fied by GIGABYTE’s RD team, the­se two builds go for total 32GB memo­ry, which MODEL X with DDR4 3600 MHz 8GB*4 and MODEL S with DDR4 3600 MHz 16GB*2. The sto­rage of 1TB PCIe Gen4 M.2 SSD and 2TB NVME M.2 SSD pro­vi­de suf­fi­ci­ent sto­rage capa­ci­ty and performance.
AORUS MODEL X
Your gam­ing sys­tem for extre­me performance
AORUS MODEL X sports tem­pe­red chas­sis with high­ly effec­ti­ve ther­mal dis­si­pa­ti­on design, the con­cea­led inta­ke exhi­bits the opti­mi­zed heat dis­si­pa­ti­on with sty­lish aes­the­tics and per­forms lower than 40dB acou­stic (as in libra­ry) while run­ning 3D Game. The acces­sio­nal cables are well-sett­led in the chas­sis to pro­vi­de pre­mi­um sca­la­bi­li­ty, and the thoughtful design of plug-and play SSD fur­ther enable a simp­le expan­da­bili­ty wit­hout exhaus­ted cable arran­ge­ment and scre­wing. Two opti­ons of metal­lic and trans­pa­rent side panel offer a distinc­ti­ve look, and inte­gra­ted VGA bra­cket shroud pres­ents a neat and attrac­ti­ve showcase.
AORUS MODEL S
Small but powerful! The quie­test mini sys­tem with exclu­si­ve ther­mal dis­si­pa­ti­on technology
AORUS MODEL S boasts exclu­si­ve All-in-one ther­mal design which can signi­fi­cant­ly impro­ve ther­mal dis­si­pa­ti­on by maxi­mi­zing the usable space on the ther­mal fin within the chas­sis. The con­cea­led inta­ke exhi­bits the opti­mi­zed heat dis­si­pa­ti­on with sty­lish aes­the­tics. The CPU tem­pe­ra­tu­re can be remain­ed in a healt­hy sta­te under run­ning the 3A games while con­trol­ling the acou­stic below 36dB (quie­ter than the libra­ry), which deli­ver a smooth and sta­ble gam­ing expe­ri­ence. As a 14L sys­tem fea­turing with powerful ther­mal dis­si­pa­ti­on, the quie­test ope­ra­ti­on, and pre­mi­um per­for­mance, AORUS MODEL S beco­mes the first choice of mini sys­tem for gamers.
Pro­duct specification:
Mar­ke­ting Name AORUS MODEL X AORUS MODEL S
Plat­form X570 B550
CPU AMD R9 5900X AMD R9 5900X
RAM DDR4 32GB @3600 MHz RGB DDR4 32GB @3600 MHz
VGA RTX 3080 RTX 3080
PSU 850W 750W
STORAGE1 M.2 2280 Gen4 1TB M.2 2280 Gen4 1TB
STORAGE2 M.2 2280 NVMe 2TB M.2 2280 NVMe 2TB
For more pro­duct infor­ma­ti­on, plea­se refer to the pro­duct web­site on:
AORUS MODEL X: https://www.gigabyte.com/Desktop-PC/AORUS-MODEL-X-AMD#kf
AORUS MODEL S: https://www.gigabyte.com/Desktop-PC/AORUS-MODEL-S-AMD#kf
For more infor­ma­ti­on and news on GIGABYTE pro­ducts, plea­se visit: http://www.gigabyte.com
