Das Hardware-Diagnoseprogramm HWiNFO64 (und auch das 32-Bit-Pendant HWiNFO32) von REALiX wartet mit vielen Funktionen der Kategorien Hardware- und System-Information auf. Für CPU und GPU werden unter anderem Taktraten, Temperaturen und Spannungen angezeigt und auf Wunsch auch mitgeloggt.
Die neue Version v5.92 unterstützt unter anderem die AMD Radeon RX 590 Grafikkarten und enthält verbesserten Support für Vega 12 und Vega 20.
Changes in HWiNFO32 & HWiNFO64 v5.92 — Released on: Nov-21–2018:
Added support of Aquacomputer Quadro.
Added monitoring of additional UPS models.
Fixed Vcore and other voltage monitoring on MSIMEGZ390ACE.
Added recognition of several NVIDIARTX 2070 card models.
Added workaround for ASUSROGSTRIXB450/X470 boards with buggy WMI implementation.
Fixed monitoring of GPU usage on AMD Polaris series with later drivers.
Added support of Aquacomputer D5 Next.
Improved drive enumeration for AMD StoreMI.
Added preliminary support of Intel Comet Lake.
Enhanced sensor monitoring on GIGABYTEB450 series mainboards.
Reduced memory usage.
Enhanced support of AMD Vega12 and Vega20.
Enhanced sensor monitoring on ASUSPRIMEX299-DELUXEII and WSZ390PRO.
Added reporting of SMU Firmware Version for later AMD GPUs.
Added AMD Radeon RX 590.
Added monitoring of Renesas ISL69138VRM controller.
Enhanced sensor monitoring on ASUSSTRIXB450‑E GAMING.
Die v5.93–3590 Beta vom 5.12.2018 bietet folgende Ergänzungen:
Enhanced sensor monitoring on GIGABYTEH370 series mainboards.
Fixed sensor monitoring on GIGABYTEZ390 M GAMING.
Added monitoring of VRM temperature on some ASUSMAXIMUSXIHERO/CODE/FORMULA mainboards.
Added monitoring of external fans on ASUSROGSTRIXGTX 1080.
Enhanced sensor monitoring on ASRock X399 Phantom Gaming 6.
Added monitoring of overclocking voltage offsets on later Intel CPUs.
Improved identification of drives connected to some Silicon Image SATA/RAID controllers.
Enhanced sensor monitoring on GIGABYTEB360 and H310 series mainboards.
Added reporting of AVX2 turbo limit ratios for Kaby Lake and Coffee Lake.
