Die Open-Source-Software WinSCP von Martin Prikryl ist ein SFTP‑, FTP‑, WebDAV- und S3-Client für Windows, der auch das alte SCP-Protokoll unterstützt. Die Freeware bietet einen geschützten Daten- und Dateitransfer zwischen verschiedenen Rechnern und ermöglicht die Nutzung verschlüsselter “Tunnel”.
Release Notes der Version 5.13.7
===== 5.13.7 ((2018–01-08)) =====
Translation updated: Simplified Chinese.
Back-propagated some improvements and fixes from 5.14–5.14.3 beta releases:
Suspending workaround 1644 for a bug in Windows 10 version 1803 (April 2018 update), fixed in version 1809 (October 2018 update), that caused drag&drop downloads to Windows Explorer end in a wrong folder.
Use remembered private key passphrase in generated script/code. 1688
Bug fix: Remembered private key passphrase is not passed to PuTTY. 1708
Bug fix: Failure when canceling connection attempt started from command-line. 1710
Bug fix: The last file transfer before creating a remote directory during synchronization is not reported with .NET assembly. 1715
Neben der Version 5.13.7 ist auch die 5.14.3 RC verfügbar.
===== 5.14.3 RC ((2018–01-09)) =====
Control labels do not show keyboard accelerator cue, until Alt key is pressed.
Bug fix: Mouse range selection does not start from the file focused by an incremental search. 1714
Bug fix: Incremental search in Explorer-selection mode does not select the found file. 1713
Bug fix: Properties dialog shows “1 file/folder”, instead of a name, even when a single entry was selected only.
Bug fix: When an ancestor directory cannot be read, its child files and subdirectories are incorrectly assumed to be encrypted. 1716
