MSI REVEALS RADEON™ RX 5500 XT GAMING/MECH SERIES GRAPHICS CARDS
[Tai­pei, Tai­wan] Decem­ber 12th, 2019. As the world’s most popu­lar GAMING gra­phics card ven­dor, MSI is proud to intro­du­ce its full line up of gra­phics cards based on the new AMD Rade­on™ RX 5500 XT series with remar­kab­le per­for­mance. Fur­nis­hed with the new AMD RDNA gam­ing archi­tec­tu­re — Effi­ci­ent­ly ener­ge­tic, RDNA archi­tec­tu­re was desi­gned to deli­ver incre­di­ble per­for­mance, sca­la­bi­li­ty and power effi­ci­en­cy. Built on the 7nm Fin­FET pro­cess and deli­ve­ring hig­her per­for­mance-per-watt com­pared to the pre­vious archi­tec­tu­re, the Rade­on™ RX 5500 XT Series will be available as GAMING and MECH.
RADEON™ RX 5500 XT GAMING SERIES – PLAY HARD, STAY SILENT
The­se NAVI-powered GAMING cards fea­ture the new MSI exclu­si­ve Inno­va­ti­ve Power Allo­ca­ti­on Tech­no­lo­gy. This tech­no­lo­gy ensu­res that the card will draw its power from the power sup­p­ly rather than the PCIe slot on the mother­board, resul­ting in a clea­ner power signal and pre­ven­ting any issues with the motherboard.
As the lea­der of coo­ling among all gra­phics cards, we know that the most chal­len­ging part of pro­du­cing a gra­phics card is per­fect­ly balan­cing both heat and noi­se when coo­ling a high-per­for­mance GPU. This is whe­re MSI has focu­sed its efforts on the GAMING series for the past years and the MSI Rade­on™ RX 5500 XT GAMING series deli­ver on this promise.
No pre­mi­um gra­phics card is com­ple­te wit­hout a back­p­la­te – after all, for most peo­p­le it’s the first thing you see when pee­ring into your case. Bols­te­ring the GAMING series with dura­ble and pre­mi­um mate­ri­als, the metal back­p­la­te not only pro­vi­des aes­the­ti­cal value but also streng­thens the struc­tu­re of the gra­phics card to pre­vent the PCB from ben­ding and pro­vi­des pro­tec­tion. Bes­i­des toug­hening the card, the back­p­la­te also helps to pas­si­ve­ly cool the card. Using ther­mal pads to trans­fer the heat and holes to increase air­flow and dissipation.
Empowe­ring MSI Mys­tic Light, RGB allows for more dyna­mic light­ing that cap­ti­va­tes gamers and onloo­kers. You can easi­ly cus­to­mi­ze and con­trol the RGB lights by using the exclu­si­ve Dra­gon Cen­ter soft­ware. Using Mys­tic Light, you can syn­chro­ni­ze the RGB light­ing of your MSI GAMING gra­phics card with other third-par­ty pro­ducts.
RADEON™ RX 5500 XT MECH SERIES – ARM YOURSELF FOR THE FINAL BLOW
The Rade­on™ RX 5500 XT MECH series is the upgraded ver­si­on of the popu­lar VENTUS design. MECH fea­tures a stee­ly gray color in the front of the shroud to signi­fy the solid cha­rac­te­ristics of the giant batt­le suits. Using the pre­mi­um TORX FAN 3.0 helps to ensu­re excel­lent ther­mal per­for­mance while redu­cing noi­se as well. MECH is an excel­lent all-round choice for gamers expec­ting a solid experience.
MSI AFTERBURNER
MSI Afterbur­ner is the world’s most reco­gni­zed and wide­ly used gra­phics card Over­clo­cking soft­ware. It gives you full con­trol of your gra­phics card and enables you to moni­tor your system’s key metrics in real-time.
Afterbur­ner gives you a free per­for­mance boost for a smooth in-game expe­ri­ence thanks to hig­her FPS.
MSI DRAGON CENTER
MSI Dra­gon Cen­ter is a brand-new soft­ware plat­form with the goal to inte­gra­te all MSI soft­ware for com­pon­ents, desk­top sys­tems and peri­pherals. The all-new soft­ware fea­tures Gam­ing Mode, which instant­ly opti­mi­zes your hard­ware for the best gam­ing expe­ri­ence inclu­ding SSD, moni­tor and net­work set­tings. This bud­ding new soft­ware plat­form will con­ti­nue to impro­ve and evol­ve, inclu­ding more uni­que func­tion­a­li­ties and bene­fits for MSI users.
AVAILABILITY
The new MSI Rade­on™ RX 5500 XT GAMING/ MECH series cards are expec­ted to be available start­ing 12th Decem­ber 2019.
PRODUCT SPECIFICATIONS
MSI Radeon™ RX 5500 XT GAMING Series
* ‘Game Clock’ is the expec­ted GPU clock when run­ning typi­cal gam­ing appli­ca­ti­ons, set to typi­cal TGP (Total Gra­phics Power). Actu­al indi­vi­du­al game clock results may vary.
MSI Radeon™ RX 5500 XT MECH Series
MSI GAMING: https://www.msi.com/
MSI Face­book: https://www.facebook.com/MSIGaming
MSI Insta­gram: https://www.instagram.com/msigaming/
MSI You­Tube: https://www.youtube.com/user/MSIGamingGlobal
MSI Twit­ter: https://twitter.com/msitweets/
