ASRock Launches AMD X300TM-ITX Thin Mini-ITX Motherboard with a Type‑C Port
TAIPEI, Taiwan, May 27, 2021 – The leading global motherboard, graphics card, and small form factor PC manufacturer, ASRock, proudly announces the new Thin Mini-ITX form factor motherboard for AMD’s Ryzen platform, X300TM-ITX. ASRock brand new X300TM-ITX supports AMD latest Ryzen™ 4000 Series APU and up to 64 GB of DDR4-3200MHz SO-DIMM memory, bringing uncompromised performance. This motherboard has an onboard Type‑C USB 3.2 Gen1 port built on the rear i/o for charging devices and to deliver up to 5 Gbps data transfer rates.
ASRock X300TM-ITX provides a COM port, two HDMI ports which can drive displays up to 4K 60Hz, a second HDMI located on the side of PCB is an internal port. One LVDS connector for LCD controllers is also present. The storage capability is comprised of a single SATA connector and a single M.2 2280 slot. On the rear there are three USB 3.2 Gen1 Type‑A ports, with two internal USB 2.0 headers for expansion. For connectivity, X300TM-ITX equipps a M.2 Key‑E slot for Wi-Fi module and a single Gigabit Ethernet port.
ASRock X300TM-ITX motherboard is compatible with All-in-One PC, mini ITX, and regular Thin Mini ITX chassis, purchase this motherboard to build your office or compact home theater PC.
For more product information, please check:
https://www.asrock.com/MB/AMD/X300TM-ITX/index.asp
