MEN and Deutsche Bahn — a Box PC for Precise Positioning
- AMD Embedded G‑Series APU
- Interface for GPS, UMTS/GSM
- Odometer
- -40° C to +85°C operating temperature
- EN 50155 compliant
Nuremberg, Germany — January 17, 2014. MEN’s family of modular and robust box PCs is growing steadily and is in many cases a compact and cost-efficient alternative for applications which, until now, have been implemented using industrial PCs. The latest project of Deutsche Bahn and MEN, for example, uses a box PC for precisely positioning a train.
Exact Positioning for Efficient Track Usage
The box PC controls all functions required for the exact positioning of a train on the railway network of Deutsche Bahn.
For this, the box PC, which is equipped with two antennas, receives GPS data sent from several satellites and forwards them to the control center via UMTS, where the position and the current speed are calculated. Due to differentiated GPS, a location accuracy of less than 3 m can be provided, which means that the exact track can be determined. Equipped with an odometer, the system supports dead reckoning functionality which ensures that the exact position of a vehicle can be identified, even if the satellite signal is interrupted, for example while driving through a tunnel.
The exact positioning down to the track offers crucial advantages regarding track utilization, waiting times and power consumption. This way, a faster train can overtake a slower one between stations without danger, trains can be more quickly coupled in switch yards using suitable software, or the train speed can be adapted to the landscape.
The system can also retroactively be equipped with up to four PCI Express® MiniCards, each with dual-SIM, different I/O interfaces such as CAN or RS232/RS485/RS422 using SA-Adapters, or an additional hard disk.
The box PC is a customer-specific version of the BL50W, which is available as a standard product. The BL50W is based on the T48N AMD Embedded G‑Series APU, and equipped with four PCI Express® Mini Card slots with 8 SIM card slots as well as a GPS interface. Additionally it offers two DisplayPorts, two Gigabit Ethernet channels via robust M12 connectors, two USB 2.0 and five slots for serial I/O or CAN bus, as well as a number of universal inputs and relay outputs.
The BL50W is designed for fanless operation in the extended operating temperature range of ‑40 to +85°C, and developed in compliance with EN 50155 for use in railway applications. The standard BL50W also complies with the requirements for E‑marking according to ISO 7637–2 for automotive applications. As the I/O part and the CPU part are implemented on two separate PCBs inside the box PC, the system can be easily and cost-effectively adapted to the customer’s wishes.
MEN Mikro Elektronik – Profile and Mission
Embedded Solutions — Rugged Computer Boards and Systems for Harsh, Mobile and Mission-Critical Environments
Since its founding in 1982, MEN Mikro Elektronik has focused on innovation, reliability and flexibility to develop and produce standard and custom computing solutions that employ the highest technology levels. The company — with more than 250 employees worldwide — provides a robust offering of highly reliable embedded COTS boards and devices widely used in extreme environmental conditions found in industrial and safety-critical applications.
MEN Mikro Elektronik’s product offering comprises a huge selection of:
- CompactPCI® / PlusIO, CompactPCI® Serial and VMEbus boards and 19″ systems
- Standardized computer-on-modules with carrier board development support
- Standardized mezzanine I/O cards to complete system functionality
- Ethernet and fieldbus network interfaces, switches, routers and gateways
- Scalable box PCs and panel PCs with easy adaptation capabilities
- Safe computers certifiable up to SIL 4 and DAL‑A
For individual requirements, starting with development through design-in and beyond, MEN provides its customers with advice and support as well as with system design, configuration and environmental qualification in accordance with industry standards.
The company’s core competencies encompass x86 and RISC processor architectures, development rules for safe applications, analog I/O design, FPGA technology and Windows®, Linux and real-time operating systems. Additional expertise includes RAMS and obsolescence management as well as the development of computing hardware for operation in harsh and extreme environmental conditions.
MEN Mikro Elektronik’s computer solutions are used in harsh mission- and safety-critical environments found in the transportation (rail, road, air, sea) and industrial (automation, power & energy, medical) markets.
The company is certified to ISO 9001, ISO 14001 (environment), EN 9100 (aerospace) and IRIS (railway) quality management systems, provides systems according to ISO 7637–2 (road traffic) requirements and is a member of several industry associations, consortiums and alliances, including VITA and PICMG.
