Samsung Electronics Starts Production of EUV-Based 7nm LPP Process
Samsung’s new 7LPP allows up to 40% increase in area effi­ci­en­cy with 20% hig­her per­for­mance or 50% lower power con­sump­ti­on, resul­ting in bet­ter yields with signi­fi­cant­ly fewer layers
SEOUL, South Korea–(BUSINESS WIRE)–Sam­sung Elec­tro­nics Co., Ltd., a world lea­der in advan­ced semi­con­duc­tor tech­no­lo­gy, today announ­ced that it has com­ple­ted all pro­cess tech­no­lo­gy deve­lo­p­ment and has star­ted wafer pro­duc­tion of its revo­lu­tio­na­ry pro­cess node, 7LPP, the 7‑nanometer (nm) LPP (Low Power Plus) with extre­me ultra­vio­let (EUV) litho­gra­phy tech­no­lo­gy. The intro­duc­tion of 7LPP is a clear demons­tra­ti­on of Sam­sung Foundry’s tech­no­lo­gy road­map evo­lu­ti­on and pro­vi­des cus­to­mers with a defi­ni­te path to 3nm.
The com­mer­cia­liza­ti­on of its newest pro­cess node, 7LPP gives cus­to­mers the abili­ty to build a full ran­ge of exci­ting new pro­ducts that will push the boun­da­ries of appli­ca­ti­ons such as 5G, Arti­fi­ci­al Intel­li­gence, Enter­pri­se and Hypers­ca­le Dat­a­cen­ter, IoT, Auto­mo­ti­ve, and Networking.
“With the intro­duc­tion of its EUV pro­cess node, Sam­sung has led a quiet revo­lu­ti­on in the semi­con­duc­tor indus­try,” said Char­lie Bae, exe­cu­ti­ve vice pre­si­dent of foundry sales and mar­ke­ting team at Sam­sung Elec­tro­nics. “This fun­da­men­tal shift in how wafers are manu­fac­tu­red gives our cus­to­mers the oppor­tu­ni­ty to signi­fi­cant­ly impro­ve their pro­ducts’ time to mar­ket with supe­ri­or through­put, redu­ced lay­ers, and bet­ter yields. We’re con­fi­dent that 7LPP will be an opti­mal choice not only for mobi­le and HPC, but also for a wide ran­ge of cut­ting-edge applications.”
The Cha­rac­te­ristics and Bene­fits of EUV Technology
EUV uses 13.5nm wave­length light to expo­se sili­con wafers as oppo­sed to con­ven­tio­nal argon fluo­ri­de (ArF) immersi­on tech­no­lo­gies that are only able to achie­ve 193nm wave­lengths and requi­re expen­si­ve mul­ti-pat­ter­ning mask sets. EUV enables the use of a sin­gle mask to crea­te a sili­con wafer lay­er whe­re ArF can requi­re up to 4 masks to crea­te that same lay­er. Con­se­quent­ly Samsung’s 7LPP pro­cess can redu­ce the total num­ber of masks by about 20% com­pared to non-EUV pro­cess, enab­ling cus­to­mers to save time and cost.
The EUV litho­gra­phy impro­ve­ments also deli­ver increased per­for­mance, lower power and smal­ler area while impro­ving design pro­duc­ti­vi­ty by redu­cing mul­ti-pat­ter­ning com­ple­xi­ty. Com­pared to its 10nm Fin­FET pre­de­ces­sors, Samsung’s 7LPP tech­no­lo­gy not only great­ly redu­ces the pro­cess com­ple­xi­ty with fewer lay­ers and bet­ter yields, but also deli­vers up to a 40% increase in area effi­ci­en­cy with 20% hig­her per­for­mance or up to 50% lower power consumption.
The Road to EUV Technology
Sin­ce Samsung’s rese­arch and deve­lo­p­ment in EUV began in the 2000s, the com­pa­ny has made out­stan­ding pro­gress through col­la­bo­ra­ti­ve part­ner­ships with indus­try-lea­ding tool pro­vi­ders to design and install com­ple­te­ly new equip­ment in its manu­fac­tu­ring faci­li­ties to ensu­re the sta­bi­li­ty of EUV wafers. The initi­al EUV pro­duc­tion has star­ted in Samsung’s S3 Fab in Hwa­se­ong, Korea.
By 2020, Sam­sung expects to secu­re addi­tio­nal capa­ci­ty with a new EUV line for cus­to­mers who need high-volu­me manu­fac­tu­ring for next-gene­ra­ti­on chip designs. As an EUV pio­neer, Sam­sung has also deve­lo­ped pro­prie­ta­ry capa­bi­li­ties such as a uni­que mask inspec­tion tool that per­forms ear­ly defect detec­tion in EUV masks, allo­wing tho­se defects to be eli­mi­na­ted ear­ly in the manu­fac­tu­ring cycle.
“Com­mer­cia­liza­ti­on of EUV tech­no­lo­gy is a revo­lu­ti­on for the semi­con­duc­tor indus­try and will have a huge impact on our ever­y­day lives,” said Peter Jenk­ins, vice pre­si­dent of cor­po­ra­te mar­ke­ting at ASML. “It is our gre­at plea­su­re to col­la­bo­ra­te with Sam­sung and other lea­ding chip makers on this fun­da­men­tal shift in semi­con­duc­tor pro­cess manufacturing.”
7nm LPP EUV Ecosystem
The Sam­sung Advan­ced Foundry Eco­sys­tem™ is also ful­ly pre­pared for the intro­duc­tion of 7LPP with EUV. Eco­sys­tem part­ners across the indus­try will be pro­vi­ding Foun­da­ti­on and Advan­ced IP, Advan­ced Pack­a­ging, and Ser­vices to ful­ly enable Sam­sung cus­to­mers to deve­lop their pro­ducts on this new plat­form. From high-per­for­mance and high-den­si­ty stan­dard cells to HBM2/2e memo­ry inter­faces and 112G Ser­Des inter­faces, SAFE™ is rea­dy to help cus­to­mers imple­ment their designs on 7LPP.
Fol­lo­wing its US, Chi­na, Korea, and Japan events, Sam­sung will hold the year’s final Foundry Forum on Octo­ber 18, in Munich, Ger­ma­ny for Euro­pean cus­to­mers and part­ners. For more infor­ma­ti­on about Sam­sung Foundry, plea­se visit https://www.samsungfoundry.com
About Sam­sung Elec­tro­nics Co., Ltd.
Sam­sung inspi­res the world and shapes the future with trans­for­ma­ti­ve ide­as and tech­no­lo­gies. The com­pa­ny is rede­fi­ning the worlds of TVs, smart­phones, weara­ble devices, tablets, digi­tal appli­ances, net­work sys­tems, and memo­ry, sys­tem LSI, foundry and LED solu­ti­ons. For the latest news, plea­se visit the Sam­sung News­room at http://news.samsung.com.
