Matrox to Develop Embedded Graphics Cards with NVIDIA, Solutions Purpose-Built for Next-Generation Video Walls
Matrox to leverage industry-renowned NVIDIA Quadro embedded GPU architecture to enable the development of best-in-class graphics cards
MONTREAL — Janu­ary 22, 2020 — Matrox® today announ­ced a col­la­bo­ra­ti­on with NVIDIA for the deve­lo­p­ment of a new ran­ge of mul­ti-dis­play embedded gra­phics cards pur­po­se-built for high-den­si­ty video walls. Lever­aging NVIDIA’s indus­try-renow­ned GPU tech­no­lo­gy, Matrox will design gra­phics inno­va­tions powered by a cus­tom-built Qua­dro® embedded GPU to acce­le­ra­te gra­phics-inten­si­ve video wall appli­ca­ti­ons in com­mer­cial and 24/7 cri­ti­cal environments.
Matrox is thril­led to work along­side NVIDIA, the lea­der in GPU com­pu­ting, to bring to mar­ket a new stan­dard of high-den­si­ty video walls,” said David Chiap­pi­ni, exe­cu­ti­ve vice pre­si­dent of rese­arch and deve­lo­p­ment at Matrox. “This col­la­bo­ra­ti­on is yet ano­ther exam­p­le of our com­mit­ment to expan­ding our video wall port­fo­lio while cus­to­mers con­ti­nue to bene­fit from our gra­phics exper­ti­se, world-class engi­nee­ring, dedi­ca­ted tech­ni­cal sup­port, and long pro­duct life cycles.”
Matrox is a lea­der in crea­ting gra­phics-rich video walls that make an instant real-world impact with cus­to­mers,” said Scott Fitz­pa­trick, vice pre­si­dent of Qua­dro Pro­duct Mar­ke­ting at NVIDIA. “The excep­tio­nal video play­back per­for­mance, relia­bi­li­ty, and lon­ge­vi­ty of the NVIDIA archi­tec­tu­re makes it an ide­al plat­form for the GPUs Matrox is deve­lo­ping for next-gene­ra­ti­on video walls.”
The new series of sin­gle-slot gra­phics cards based on the NVIDIA Qua­dro embedded GPUs will power up to four syn­chro­ni­zed 4K dis­plays per card, while OEMs, sys­tem inte­gra­tors, and AV instal­lers can com­bi­ne mul­ti­ple cards to dri­ve up to 16 dis­plays from one sys­tem. HDCP is also sup­port­ed for the play­back of pro­tec­ted con­tent across the video wall. In addi­ti­on, the robust and field-pro­ven Matrox Power­Desk desk­top manage­ment soft­ware pro­vi­des users with a com­pre­hen­si­ve set of advan­ced tools to easi­ly con­fi­gu­re and cus­to­mi­ze mul­ti-dis­play setups.
About Matrox Graphics Inc.
Matrox Gra­phics is a glo­bal manu­fac­tu­rer of relia­ble, high-qua­li­ty ASICs, boards, appli­ances, and soft­ware. Backed by in-house design exper­ti­se and dedi­ca­ted cus­to­mer sup­port, Matrox pro­ducts deli­ver stel­lar cap­tu­re, exten­si­on, dis­tri­bu­ti­on, and dis­play. Engi­nee­ring high-qua­li­ty pro­ducts sin­ce 1976, Matrox tech­no­lo­gy is trus­ted by pro­fes­sio­nals and part­ners world­wi­de. Matrox is a pri­va­te­ly held com­pa­ny head­quar­te­red in Mont­re­al, Cana­da. For more infor­ma­ti­on, visit www.matrox.com.
Matrox Media Contact:
Matrox Media Relations
Tel: +1 (514) 822‑6000
www.matrox.com
Matrox and Matrox pro­duct names are regis­tered trade­marks and/or trade­marks of Matrox Elec­tro­nic Sys­tems, Ltd. and/or Matrox Gra­phics Inc. in Cana­da and/or other count­ries. All other com­pa­ny and pro­duct names are regis­tered trade­marks and/or trade­marks of their respec­ti­ve owners.
