WinSCP 5.13.6 und WinSCP 5.14.1 Beta
Die Open-Source-Software WinSCP von Martin Prikryl ist ein SFTP‑, FTP‑, WebDAV- und S3-Client für Windows, der auch das alte SCP-Protokoll unterstützt. Die Freeware bietet einen geschützten Daten- und Dateitransfer zwischen verschiedenen Rechnern und ermöglicht die Nutzung verschlüsselter “Tunnel”.
Release Notes der Version 5.13.6
===== [[5.13.6]] 5.13.6 (hotfix) ((2018–12-12)) =====
* Back-propagated some improvements and fixes from 5.14.2 beta release:
* Bug fix: Failure when canceling session reconnect. [[bug>1684]]
* Bug fix: Crash on start while loading local file icons. [[bug>1709]]
Neben der Version 5.13.6 ist auch die 5.14.1 Beta verfügbar.
===== [[5.14.1]] 5.14.1 beta ((2018–10-26)) =====
* Support OpenSSH AES-256-CTR-encrypted keys. PuTTYgen updated to the latest development snapshot of PuTTY (2018–10-22.1806b71). [[bug>1692]]
* Allow connecting to Amazon S3 using non-default endpoints. [[bug>1695]]
* With parallel background transfers, it is not possible to disable size calculation, which effectively prevented parallel transfers from working. [[bug>1691]]
* Low logging level implemented also for S3 and partly for WebDAV protocols. [[bug>1637]]
* Optionally consider exit code 1 an error when executing a shell command on a server. [[bug>1694]]
* Middle mouse click closes session without activating its tab.
* Choosing right color for background of calculated checksum on Properties dialog.
* Bug fix: Failure when closing the main window with a colored session. [[bug>1693]]
* Bug fix: Confirmation of copy&paste transfers between panels was incorrectly controlled by drag&drop confirmation preference option.
* Bug fix: Background transfer settings are not preserved. [[bug>1690]]
* Bug fix: Resolving file move from synchronization checklist, invoked from command-line, closes a connection.
* Bug fix: Generated code included redundant ”PortNumber” raw settings settings setter for all sessions not using port 22.
Downloads:
Weitere Links:
