Mellanox Ethernet and InfiniBand Solutions Deliver Breakthrough Performance for AMD EPYC™ 7002 Processor Based Data Centers
The Combination of Mellanox’s Smart Interconnect Acceleration Engines, PCI Express 4.0 and AMD’s Innovative CPU Architecture Provides the Foundation for Next Generation Compute and Storage Infrastructures
SUNNYVALE Calif. and YOKNEAM Isra­el – August 7, 2019 Mel­lan­ox® Tech­no­lo­gies, Ltd. (NASDAQ: MLNX), a lea­ding sup­pli­er of high-per­for­mance, end-to-end smart inter­con­nect solu­ti­ons for data cen­ter ser­vers and sto­rage sys­tems, today announ­ced that Mel­lan­ox Ether­net and Infi­ni­Band Con­nectX® smart adap­ter solu­ti­ons are opti­mi­zed to pro­vi­de breakth­rough per­for­mance and sca­la­bi­li­ty for the new AMD EPYC™ 7002 Series pro­ces­sor-based com­pu­te and sto­rage infra­struc­tures. Lever­aging the 2nd Gen AMD EPYC™ pro­ces­sors’ sup­port of PCI Express 4.0, inno­va­ti­ve archi­tec­tu­re, and four times peak FLOPS per-socket per­for­mance over the AMD EPYC 7001 series processor1, mutu­al cus­to­mers can maxi­mi­ze their data cen­ter return-on-investment.
The com­bi­na­ti­on of Mel­lan­ox 25, 50, 100 and 200 Giga­bit Ether­net and HDR 200 Giga­bit Infi­ni­Band adap­ters, and PCI Express 4.0 sup­port in the second-gene­ra­ti­on AMD EPYC pro­ces­sor, pro­vi­des high-per­for­mance com­pu­ting, arti­fi­ci­al intel­li­gence, cloud and enter­pri­se data cen­ters the high data band­width they need for the most com­pu­te and sto­rage deman­ding appli­ca­ti­ons,” said Micha­el Kagan, Chief Tech­no­lo­gy Offi­cer at Mel­lan­ox Tech­no­lo­gies. “By lever­aging our smart acce­le­ra­ti­on engi­nes for In-Net­work Com­pu­ting, vir­tua­liza­ti­on, sto­rage and secu­ri­ty, our part­ners and cus­to­mers can maxi­mi­ze the per­for­mance capa­bi­li­ties of the new second gene­ra­ti­on EPYC™ pro­ces­sors-based platforms.”
With unmat­ched PCI Express 4.0 con­nec­ti­vi­ty, the AMD EPYC™ 7002 pro­ces­sor plat­form is also ide­al for advan­ced ser­ver based sto­rage solu­ti­ons. The lar­ge num­ber of PCI Express 4.0 lanes enables direct con­nec­ti­vi­ty to 24 NVMe sto­rage dri­ves plus Mel­lan­ox Con­nectX 100 and 200 giga­bit per second adap­ters and achie­ve full I/O throughout.
Dri­ven by AMD’s histo­ry of dat­a­cen­ter inno­va­ti­on, inclu­ding 7nm pro­cess tech­no­lo­gy, the first x86 sup­pli­er to sup­port PCIe 4.0, and embedded secu­ri­ty fea­tures, the second gene­ra­ti­on AMD EPYC Pro­ces­sors set a new stan­dard for the modern dat­a­cen­ter,” said Scott Aylor, cor­po­ra­te vice pre­si­dent and gene­ral mana­ger, Dat­a­cen­ter Solu­ti­ons Group at AMD. “We’re exci­ted and thank­ful to have our part­ners, like Mel­lan­ox, sup­port­ing the launch of the second gene­ra­ti­on AMD EPYC pro­ces­sor. Working tog­e­ther we can enable our cus­to­mers to trans­form their data cen­ter ope­ra­ti­ons and deli­ver the breakth­rough per­for­mance they need.”
Sup­port­ing Resour­ces:
About Mel­lan­ox
Mel­lan­ox Tech­no­lo­gies (NASDAQMLNX) is a lea­ding sup­pli­er of end-to-end Ether­net and Infi­ni­Band smart inter­con­nect solu­ti­ons and ser­vices for ser­vers and sto­rage. Mel­lan­ox inter­con­nect solu­ti­ons increase data cen­ter effi­ci­en­cy by pro­vi­ding the hig­hest through­put and lowest laten­cy, deli­ve­ring data fas­ter to appli­ca­ti­ons, unlo­cking sys­tem per­for­mance and impro­ving data secu­ri­ty. Mel­lan­ox offers a choice of fast inter­con­nect pro­ducts: adap­ters, swit­ches, soft­ware and sili­con that acce­le­ra­te appli­ca­ti­on per­for­mance and maxi­mi­ze busi­ness results for a wide ran­ge of mar­kets inclu­ding cloud and hypers­ca­le, high per­for­mance com­pu­ting, arti­fi­ci­al intel­li­gence, enter­pri­se data cen­ters, cyber secu­ri­ty, sto­rage, finan­cial ser­vices and more. More infor­ma­ti­on is available at: http://www.mellanox.com
Note: Mel­lan­ox, Con­nectX are a regis­tered trade­mark of Mel­lan­ox Tech­no­lo­gies, Ltd. All other trade­marks are pro­per­ty of their respec­ti­ve owners.
AMD, the AMD Arrow logo, EPYC and com­bi­na­ti­ons the­reof are trade­marks of Advan­ced Micro Devices, Inc. Other pro­duct names used in this publi­ca­ti­on are for iden­ti­fi­ca­ti­on pur­po­ses only and may be trade­marks of their respec­ti­ve companies.
