Broadcom Announces Industry-First Portfolio of PCIe 4.0 Ethernet Adapters and Fibre Channel HBAs Supporting AMD EPYC™ 7002 Series Processor
Com­pa­ny Brings the World’s Fas­test and Most-Secu­re Ether­net Net­wor­king and Fib­re Chan­nel to AMD EPYC™ 7002 Series Pro­ces­sor-Based Systems
SAN JOSE, Calif., Aug. 08, 2019 (GLOBE NEWSWIRE) — Broad­com Inc. (NASDAQ: AVGO) today announ­ced that NetX­tre­me® E‑Series Ether­net adap­ters and Emulex® LPe35000-series HBAs now deli­ver the fas­test net­wor­king per­for­mance with the AMD EPYC™ 7002 Series Pro­ces­sor-based sys­tems- the world’s first x86 data cen­ter CPU, sup­port­ing PCIe 4.0®. The 200GbE NetX­tre­me E‑series and Gen 7 32GFC LPe35000-series are the world’s first port­fo­lio of Ether­net adap­ters and Fib­re Chan­nel HBAs with sup­port for PCIe 4.0.
PCIe 4.0 will dou­ble the band­width per lane to pro­vi­de signi­fi­cant I/O per­for­mance bene­fits for sto­rage and Ether­net net­wor­king, NVMe deploy­ments and AI appli­ca­ti­ons. AMD and Broad­com have work­ed clo­se­ly to bring solu­ti­ons to mar­ket that fea­ture embedded secu­ri­ty and sili­con root of trust on Thor™ 200G Ether­net con­trol­lers and XE601™ Fib­re Chan­nel con­trol­lers to make the­se the most secu­re solu­ti­ons in the industry.
Thor and AMD EPYC 7002 Series Pro­ces­sors pro­vi­de the best per­forming and most secu­re Ether­net con­nec­ti­vi­ty and com­pu­te plat­form in the indus­try,” said Ed Red­mond, seni­or vice pre­si­dent and gene­ral mana­ger, Com­pu­te and Con­nec­ti­vi­ty Divi­si­on, Broad­com. “Thor, with 200GbE band­width and sili­con root of trust, run­ning on AMD PCIe 4.0 plat­forms, enable the indus­try to achie­ve grea­ter levels of per­for­mance and secu­ri­ty for hypers­ca­le and enter­pri­se data centers.”
The Emulex® LPe35000 HBA with PCIe 4.0 and NVMe over Fib­re Chan­nel dou­bles mis­si­on-cri­ti­cal workload band­width, while cut­ting host CPU uti­liza­ti­on in half,” said Jeff Hoo­gen­boom, gene­ral mana­ger, Emulex Con­nec­ti­vi­ty Divi­si­on, Broad­com. “We are exci­ted to work with AMD and our OEM cus­to­mers to deli­ver the fas­test, most secu­re Fib­re Chan­nel HBAs for enter­pri­se workloads.”
Dri­ven by AMD’s histo­ry of dat­a­cen­ter inno­va­ti­on, inclu­ding 7nm pro­cess tech­no­lo­gy, embedded secu­ri­ty fea­tures and the world’s first x86 sup­pli­er to sup­port PCIe 4.0, the AMD EPYC 7002 Series Pro­ces­sors set a new stan­dard for the modern dat­a­cen­ter,” said Scott Aylor, cor­po­ra­te vice pre­si­dent and gene­ral mana­ger, Dat­a­cen­ter Solu­ti­ons Group, AMD. “Tog­e­ther, the­se inno­va­tions tru­ly deli­ver the breakth­rough per­for­mance cus­to­mers demand.”
Broad­com is now sam­pling Thor-based dual-port 100GbE and sin­gle-port 100GbE OCP 3.0, OCP 2.0, and PCIe NIC adap­ters to qua­li­fied cus­to­mers. Plea­se cont­act your local Broad­com sales repre­sen­ta­ti­ve for samples and pricing.
Broad­com is now ship­ping sin­gle, dual and quad-port Emulex Gen 7 LPe35000-series HBAs through its OEM part­ners. The Dell-bran­ded dual-port Gen 7 LPe35002 is available from Dell. The Leno­vo-bran­ded sin­gle and dual port Gen 7 LPe35000-series HBAs are available from Leno­vo.
Fur­ther infor­ma­ti­on on the AMD EPYC 7002 Series Pro­ces­sors can be found online at: https://www.amd.com/en/processors/epyc-7002-series
About Broad­com
Broad­com Inc. (NASDAQ: AVGO) is a glo­bal tech­no­lo­gy lea­der that designs, deve­lo­ps and sup­pli­es a broad ran­ge of semi­con­duc­tor and infra­struc­tu­re soft­ware solu­ti­ons. Broadcom’s cate­go­ry-lea­ding pro­duct port­fo­lio ser­ves cri­ti­cal mar­kets inclu­ding data cen­ter, net­wor­king, enter­pri­se soft­ware, broad­band, wire­less, sto­rage and indus­tri­al. Our solu­ti­ons include data cen­ter net­wor­king and sto­rage, enter­pri­se and main­frame soft­ware focu­sed on auto­ma­ti­on, moni­to­ring and secu­ri­ty, smart­phone com­pon­ents, tele­coms and fac­to­ry auto­ma­ti­on. For more infor­ma­ti­on go to www.broadcom.com.
Broad­com, the pul­se logo, Emulex, NetX­tre­me and con­nec­ting ever­y­thing are among the trade­marks of Broad­com. The term “Broad­com” refers to Broad­com Inc., and/or its sub­si­dia­ries. AMD, the AMD Arrow logo, EPYC and com­bi­na­ti­ons the­reof are trade­marks of Advan­ced Micro Devices, Inc. Other pro­duct names used in this publi­ca­ti­on are for iden­ti­fi­ca­ti­on pur­po­ses only and may be trade­marks of their respec­ti­ve companies.
