One Stop Systems Now Offering AMD EPYC 7002 Series Processor based Systems to Customers for ‘AI on the Fly’ Edge Appliances
ESCONDIDO, Calif. and SANTA CLARA, Calif., August 7, 2019 – One Stop Sys­tems, Inc. (Nasdaq: OSS),the lea­ding pro­vi­der of spe­cia­li­zed high per­for­mance com­pu­ting solu­ti­ons for mis­si­on cri­ti­cal edge appli­ca­ti­ons, today unvei­led its com­pre­hen­si­ve port­fo­lio of PCIe Gen 4 expan­si­on buil­ding blocks sup­port­ing ser­vers based on AMD’s new­ly released EPYC™ 7002 Gene­ra­ti­on Processor.
AMD EPYC 7002 Series Pro­ces­sors power the most deman­ding workloads with breakth­rough CPU per­for­mance. Its intro­duc­tion heralds the mar­ket tran­si­ti­on to PCIe Gen 4 sys­tem inter­con­nect, doubling the per­for­mance over PCIe Gen 3‑based systems.
OSS PCIe Gen 4 expan­si­on plat­forms, in com­bi­na­ti­on with the­se ser­vers, allow unpar­al­le­led sca­la­bi­li­ty for mul­ti-GPU com­pu­te engi­nes, NVMe-based data acqui­si­ti­on and high-speed sto­rage subsystems—all inte­gral ele­ments of AI on the Fly™ edge appli­ances. OSS AI on the Fly edge appli­ances bring dat­a­cen­ter AI capa­bi­li­ties to the edge for auto­no­mous vehic­le, mili­ta­ry, aero­space, medi­cal, media and enter­tain­ment applications.
Given the high num­ber of available PCIe Gen 4 lanes pro­vi­ded by the EPYC 7002 Gene­ra­ti­on Pro­ces­sor AI on the Fly appli­ances can be sca­led using mul­ti­ple OSS expan­si­on chas­sis, and com­bi­ne PCIe Gen 4 data acqui­si­ti­on, data sto­rage and data pro­ces­sing ele­ments. The­se fle­xi­ble solu­ti­ons pro­vi­de the high band­width and low laten­cy data trans­port nee­ded to dra­ma­ti­cal­ly sca­le AI per­for­mance at the edge, which is cri­ti­cal to deman­ding appli­ca­ti­ons like auto­no­mous vehic­les and per­so­na­li­zed medicine.
“Dri­ven by AMD’s histo­ry of inno­va­ti­on, inclu­ding 7nm pro­cess tech­no­lo­gy, first x86 sup­pli­er to sup­port PCIe Gen 4, and embedded secu­ri­ty pro­tec­tion, the AMD EPYC 7002 Series Pro­ces­sors set a new stan­dard for per­for­mance,” said Scott Aylor, cor­po­ra­te vice pre­si­dent and gene­ral mana­ger, Dat­a­cen­ter Solu­ti­ons Group, AMD. “Tog­e­ther, the­se inno­va­tions deli­ver the breakth­rough per­for­mance cus­to­mers need.”
Ste­ve Coo­per, CEO of OSS, com­men­ted: “OSS has always been com­mit­ted to pro­vi­ding our cus­to­mers with access to the latest high per­for­mance tech­no­lo­gy they need to address their mis­si­on cri­ti­cal appli­ca­ti­ons. We are plea­sed to work with AMD to lead the mar­ket tran­si­ti­on to PCIe Gen 4 by deli­ve­ring fle­xi­ble and sca­lable expan­si­on plat­forms com­ple­men­ta­ry to AMD EPYC 7002 based servers.”
Visi­tors to Flash Memo­ry Sum­mit can view the OSS/AMD PCIe Gen 4 demons­tra­ti­ons in OSS booth #119. Cus­to­mers can order PCIe Gen 4 solu­ti­ons from the company’s high­ly-trai­ned sales engi­neers at sales@onestopsystems.com.
About One Stop Systems
OSS uti­li­zes the power of PCI Express, the latest GPU acce­le­ra­tors and NVMe sto­rage to build award-win­ning sys­tems, inclu­ding many indus­try firsts, for OEMs and govern­ment cus­to­mers. The com­pa­ny enables AI on the Fly™ by brin­ging AI dat­a­cen­ter per­for­mance to ‘the edge’ and on mobi­le plat­forms, and by addres­sing the enti­re AI work­flow, from high speed data acqui­si­ti­on to deep lear­ning, trai­ning and infe­rence. OSS pro­ducts are available direct­ly or through glo­bal dis­tri­bu­tors. For more infor­ma­ti­on, visit www.onestopsystems.com.
One Stop Sys­tems, Inc. (OSS) designs and manu­fac­tures inno­va­ti­ve spe­cia­li­zed high-per­for­mance com­pu­ting buil­ding blocks and plat­forms for OEMs that pro­vi­de sys­tems to sci­en­tists, engi­neers, crea­tors and other pro­fes­sio­nals who push the boun­da­ries of their indus­tries. The­se spe­cia­li­zed plat­forms include cus­to­mi­zed ser­vers, com­pu­te acce­le­ra­tors, flash sto­rage arrays, expan­si­on sys­tems and sto­rage soft­ware. The pro­ducts are used for deep lear­ning, AI, defen­se, finan­ce and enter­tain­ment appli­ca­ti­ons. OSS uti­li­zes the power of PCI Express, the latest GPU acce­le­ra­tors and NVMe flash cards to build award-win­ning sys­tems, inclu­ding many indus­try firsts, for OEMs and govern­ment cus­to­mers. The company’s inno­va­ti­ve hard­ware and Ion Acce­le­ra­tor Soft­ware offers excep­tio­nal per­for­mance and unpar­al­le­led sca­la­bi­li­ty. OSS pro­ducts are available direct­ly or through glo­bal dis­tri­bu­tors. For more infor­ma­ti­on, go to www.onestopsystems.com.
For­ward-Loo­king Statements
One Stop Sys­tems cau­ti­ons you that state­ments in this press release that are not a descrip­ti­on of his­to­ri­cal facts are for­ward-loo­king state­ments. The­se state­ments are based on the company’s cur­rent beliefs and expec­ta­ti­ons. Actu­al results may dif­fer from tho­se set forth in this press release due to the risk and uncer­tain­ties inher­ent in our busi­ness, inclu­ding, wit­hout limi­ta­ti­on: the ope­ra­ti­on, sca­la­bi­li­ty and doubling of per­for­mance of OSS Gen4 pro­ducts with ser­vers, the num­ber of items deli­ver­ed to cus­to­mers and the fit­ness of pro­ducts for any appli­ca­ti­on; and other risks descri­bed in our pri­or press releases and in our filings with the Secu­ri­ties and Exch­an­ge Com­mis­si­on (SEC), inclu­ding under the hea­ding “Risk Fac­tors” in our Annu­al Report on Form 10‑K and any sub­se­quent filings with the SEC. You are cau­tio­ned not to place undue reli­ance on the­se for­ward-loo­king state­ments, which speak only as of the date hereof, and we under­ta­ke no obli­ga­ti­on to revi­se or update this press release to reflect events or cir­cum­s­tances after the date hereof. All for­ward-loo­king state­ments are qua­li­fied in their enti­re­ty by this cau­tio­na­ry state­ment, which is made under the safe har­bor pro­vi­si­ons of the Pri­va­te Secu­ri­ties Liti­ga­ti­on Reform Act of 1995.
