Der “DRAM Calculator for Ryzen” hilft beim Übertakten des Arbeitsspeichers auf Plattformen mit AMDs Ryzen-Prozessoren, indem auf Basis der Daten des eingesetzten Arbeitsspeichers Vorschläge für die Einstellungen der Timings gemacht werden. Seit der Version 1.6.0.1 werden Prozessoren auf Basis von AMDs Zen 2 und Mainboards mit X570-Chipsatz unterstützt.
Changelog:
v1.6.1 (August 27th, 2019)
NEW. Graph of random access to caches and DRAM. Please note, that the testing process may take several minutes.
NEW. FreezKiller — software that will make your frame rate as smooth as possible without sacrificing performance. New iteration of cleaning Standby caches without jerking. Just click the “Start” button, minimize the application and launch your game.
NEW. Samsung b‑die , Hynix CJR and Micron E‑die presets. Particular attention was paid to memory, which is based on Micron E‑die chips.
Updated Memtestmode, the application will automatically configure all the parameters individually for your system in 1 click (just select MEMbench mode -> Memtest).
Improved support for 4 DIMMs.
Overclocking potential DRAM received an update (tab “Advanced”).
Correction MEMbench algorithms. In some cases, you will get better results.
Included libraries for improved compatibility with some versions of Windows.
