AMD Grafiktreiber — Radeon Software Adrenalin 2020 Edition 21.2.3 für Ryzen 5000U Mobile
Nach­dem AMD eigent­lich seit der Ver­si­on 19.2.3 die Mobil­pro­zes­so­ren mit inte­grier­ter Vega-Gra­fik mit den Trei­bern der Rade­on Soft­ware Adre­na­lin unter­stützt, hat man nun einen Trei­ber spe­zi­ell für die Ryzen 5000 Mobi­le Pro­zes­so­ren (“Cezan­ne” bzw. “Luci­en­ne”) der U‑Serie herausgebracht.
Support For
  • Lap­tops uti­li­zing AMD RyzenTM Mobi­le 5000 Series processors.
Important Notes
  • AMD Ryzen™ Mobi­le Pro­ces­sors with Rade­on™ Gra­phics FAQ for Rade­on Soft­ware Adre­na­lin 2020 Edi­ti­on can be found here.
Package Contents
The Rade­on Soft­ware Adre­na­lin 2020 Edi­ti­on 21.2.3 instal­la­ti­on packa­ge con­ta­ins the following:
  • Rade­on Soft­ware Adre­na­lin 2020 Edi­ti­on 21.2.3 Dri­ver Ver­si­on 20.45.35.03 (Win­dows Dri­ver Store Ver­si­on 27.20.14535.3005).
Radeon Product Compatibility
Rade­on Soft­ware Adre­na­lin 2020 Edi­ti­on for Ryzen Mobi­le 5000 Series Pro­ces­sors is com­pa­ti­ble with the fol­lo­wing AMD Rade­on products.
AMD Processors with Radeon Graphics Product Compatibility
Important Note for Lap­top and All-In-One (AIO) PCs
AMD recom­mends OEM-pro­vi­ded dri­vers which are cus­to­mi­zed and vali­da­ted for their sys­tem-spe­ci­fic fea­tures and opti­miza­ti­ons.
If you expe­ri­ence issues using the Rade­on™ Soft­ware Adre­na­lin Edi­ti­on dri­ver packa­ge down­loa­ded from AMD.com, plea­se install the OEM-pro­vi­ded dri­vers for full sup­port and compatibility.
AMD Ryzen™ 3 5400U with AMD Rade­on™ Graphics
AMD Ryzen™ 5 5600U with AMD Rade­on™ Graphics
AMD Ryzen™ 7 5800U with AMD Rade­on™ Graphics
AMD Ryzen™ 3 5300U with AMD Rade­on™ Graphics
AMD Ryzen™ 5 5500U with AMD Rade­on™ Graphics
AMD Ryzen™ 7 5700U with AMD Rade­on™ Graphics
Compatible Operating Systems
Rade­on Soft­ware Adre­na­lin 2020 Edi­ti­on for Ryzen Mobi­le 5000 Series Pro­ces­sors is desi­gned to sup­port the fol­lo­wing Micro­soft® Win­dows® plat­forms. Ope­ra­ting Sys­tem sup­port may vary depen­ding on your spe­ci­fic AMD Rade­on product..
  • Win­dows® 10 64-bit version
Down­load: Rade­on Soft­ware Adre­na­lin 2020
Ver­si­on: 21.2.3
Datei­grö­ße Win­dows 10: 457,55 MiB
Ver­öf­fent­licht am: 25.02.2021
Betriebs­sys­tem: Win­dows 10
Lizenz: pro­prie­tär
Web­sei­te
