MSI unveils custom Radeon RX 6700 XT graphics cards
[Taipei, Taiwan] As a leading brand in True Gaming hardware, MSI is proud to announce a new graphics card line-up based on the AMD Radeon™ RX 6700 XT GPU, uniting the latest in graphics technology, high-performance circuit board design and advanced cooling.
GROUND-BREAKING AMD RDNA™ 2 GAMING ARCHITECTURE
• AMD Smart Access Memory – Unlocks higher performance when pairing AMD Radeon™ RX 6000 Series graphics cards with AMD Ryzen™ 5000 or select Ryzen 3000 Series Desktop Processors and AMD 500-series motherboards. Providing AMD Ryzen processors with access to high-speed GDDR6 graphics memory can deliver a significant performance uplift.
• DirectX® Raytracing (DXR) – Adding a high performance, fixed-function Ray Accelerator engine to each compute unit, AMD RDNA 2‑based graphics cards are optimized to deliver real-time lighting, shadow and reflection realism with DXR. When paired with AMD FidelityFX, which enables hybrid rendering, developers can combine rasterized and ray-traced effects to ensure an optimal combination of image quality and performance.
GAMING series
MECH Series
MSI AFTERBURNER
MSI DRAGON CENTER
AVAILABILITY
Specifications
| Model Name | Radeon RX 6700 XT GAMING X 12G | Radeon RX 6700 XT MECH 2X 12G OC | Radeon RX 6700 XT 12G |
| GPU | AMD Radeon RX 6700 XT | AMD Radeon RX 6700 XT | AMD Radeon RX 6700 XT |
| Interface | PCI Express x16 Gen 4 | PCI Express x16 Gen 4 | PCI Express x16 Gen 4 |
| Stream Processors | 2560 | 2560 | 2560 |
| Core Clocks | TBD | TBD | TBD |
| Memory | 12GB GDDR6 | 12GB GDDR6 | 12GB GDDR6 |
| Memory Speed | 16Gbps | 16Gbps | 16Gbps |
| Memory Bus | 192-bit | 192-bit | 192-bit |
| Outputs | DisplayPort x 3 (v1.4) / HDMI x 1 (Supports 4K@120Hz/8K@60Hz and VRR as specified in HDMI 2.1) | DisplayPort x 3 (v1.4) / HDMI x 1 (Supports 4K@120Hz/8K@60Hz and VRR as specified in HDMI 2.1) | DisplayPort x 3 (v1.4) / HDMI x 1 (Supports 4K@120Hz/8K@60Hz and VRR as specified in HDMI 2.1) |
| Power Consumption | TBD | TBD | TBD |
| Power Connectors | 8‑pin x2 | 8‑pin x2 | 8‑pin x1 / 6‑pin x1 |
| Card Dimensions | 279 x 131 x 58 mm | 247 x 131 x 51 mm | 267 x 110 x 40 mm |
| Weight (Card / Package) | 1179 g / 1764 g | 921 g / 1393 g | 908 g / 1374 g |
2. Smart Access Memory technology enablement requires an AMD Radeon 6000 series GPU, Ryzen 5000 or 3000 series CPU (excluding Ryzen 5 3400G and Ryzen 3 3200G) and an AMD 500 series motherboard with the latest BIOS update. BIOS requires support for AGESA 1.1.0.0 or higher. Download latest BIOS from vendor website. For additional information and system requirements, see https://www.amd.com/en/technologies/smart-access-memory. GD-178.
3.For additional information, see https://www.amd.com/en/technologies/radeon-software-fidelityfx. GD-172
