FreeCommander XE 2019 Build 790
Der in der 32-Bit-Version kostenlose FreeCommander ist eine leicht bedienbare Alternative zum Standard-Dateimanager von Windows. Das Programm hilft bei der täglichen Arbeit mit Windows und bietet unter anderem Zweifenstertechnik (optional auch ein Fenster) mit wahlweise vertikaler oder horizontaler Teilung, Registerkarten (Tabs) für einen schnellen Ordnerwechsel, eine Favoritenliste für Programme und Ordner und optionale Baumansicht in jedem Fenster.
Changes_790
20.12.2018
— Bug fix: “Check for updates” drop list items are duplicated after changing of the language http://www.forum.freecommander.com/viewtopic.php?f=7&t=8428
— Bug fix: Possible exception if editing viewer settings from general settings dialog
— Bug fix: Search dialog — “Attribute/Timestamp…” dialog can not be opened
— Bug fix: Full path is showed for “Network shortcut” http://forum.freecommander.com/viewtopic.php?f=19&t=8432
— Bug fix: Define toolbar items dialog — dialog is opened for the false item if the list of toolbar items was scrolled. http://forum.freecommander.com/viewtopic.php?f=7&t=8496
— Bug fix: Drive buttons in toolbar have no icons on program start
— Bug fix: If the Explorer option “Hide extensions for known types” is active, then files can not be deleted from the desktop (FC Method).
— Bug fix: Command line does not work if current tab is ::Computer http://forum.freecommander.com/viewtopic.php?f=7&t=8518#p27282
— Bug fix: Unpacking multiple archive files at once — if the destination path is empty, the folder of the first file will always be used as destination. http://forum.freecommander.com/viewtopic.php?f=6&t=8515
— Bug fix: Viewer — searching in hex mode does not work for properly
— Bug fix: “Make folder/file list..” dialog — selected predefined filter is ignored
— Bug fix: Auto save settings broken
— Bug fix: Rename on smartphons broken for current Windows 10
— Bug fix: Some tab icons are not displayed correctly http://forum.freecommander.com/viewtopic.php?f=7&t=8545
— Bug fix: Refresh of ‘Network’ goes to ‘Desktop’ http://forum.freecommander.com/viewtopic.php?f=7&t=8530
— Bug fix: Zip naming issue http://forum.freecommander.com/viewtopic.php?f=7&t=8596
— Bug fix: Search function — size filter is ignored sometimes https://freecommander.com/forum/viewtopic.php?f=7&t=8650
— Bug fix: View of the PDF files does not work for some installed PDF programs
— Bug fix: Quick filter — exclude multiple extensions does not work https://freecommander.com/forum/viewtopic.php?f=7&t=8654
— Bug fix: Building of the zip file name broken https://freecommander.com/forum/viewtopic.php?f=7&t=8662
— Bug fix: Internal viewer — the option “Enable adjust orientation” does not work correctly if “Show Exif” is switched on/off
— Bug fix: Main menu disappear if defined as “Show menu as toolbar” https://freecommander.com/forum/viewtopic.php?f=18&t=8715
— Bug fix: Queue button is always default for pack operation
— Bug fix: Compare folders — takes a long time if there are several thousand files in folders.
— Bug fix: Tree view is not updated when deleting a folder in the file list via context menu.
— Bug fix: Quick starter — In order to search with quick filter first focus must be set in the field. That was not necessary in the old version.
— Bug fix: Automatic views — few minor bugs fixed https://freecommander.com/forum/viewtopic.php?f=7&t=8838
— Bug fix: Different behavior of selected items when deleting with the Windows method https://freecommander.com/forum/viewtopic.php?f=19&p=28073#p28073
— Bug fix: Exception on program start if thumbnail view is active in one pane
— Bug fix: Exception on drives reload if drive button was added to toolbar
— Bug fix: Rename with slow double click does not work if the option “Hot track only” is active
— Bug fix: Sorting on shell columns does not work properly
— Bug fix: Searching for the hex string does not work properly (viewer and search dialog)
— Bug fix: Option “Keep expanded nodes per Tab” broken
— Bug fix: RAR files created on Android can not be extracted
— Bug fix: Column profiles — added Windows column can get wrong title
— Bug fix: Message “The system cannot find the path specified” can be showed twice https://freecommander.com/forum/viewtopic.php?f=7&t=9004
— Bug fix: Drive icons may be not correctly displayed in toolbars https://freecommander.com/forum/viewtopic.php?f=7&p=28430#p28430
— Bug fix: Copy&paste in the tree does not refresh the tree
— Bug fix: An internal error in the thumbnail display may slow down the display, especially from the network.
— Bug fix: Multi rename option “Activate profiles combo box first” is broken https://freecommander.com/forum/viewtopic.php?f=7&t=9025
— Bug fix: Plain View does not remember selection after switching to another tab
— Bug fix: Quick filter does not see some country-specific uppercase letters https://freecommander.com/forum/viewtopic.php?f=19&t=9022
— Bug fix: Drag&drop operation fails if it was started from plain view and some country-specific letters exist in the file name
— Bug fix: Color schemes saving is broken https://freecommander.com/forum/viewtopic.php?f=7&t=9054
— Bug fix: Folder synchronize (with compare by content) may stops after comparing the very last file
— Bug fix: File/folder selection is lost when cancel delete operation (NC-Selection and “Use Freecommander” for delete)
— Bug fix: Screenshot in systems with multiple monitors and different resolutions is faulty.
— Bug fix: The file name extension is always showed in lower case letters, if it is in the separated column.
— Bug fix: Desktop folder is not refreshing after delete operation (if defined as “Use Windows”) https://freecommander.com/forum/viewtopic.php?f=7&t=9113
— Bug fix: Unpack archive zip file into “Program files” folder is broken
— Changed: “Color schema” changed to “Color scheme”
— Changed: Hotkeys (Ctrl+Up, Ctrl+Down) for changing search result splitter changed to Alt+Down, Alt+Up http://www.forum.freecommander.com/viewtopic.php?f=7&t=8446
— Changed: Handling of the favorites LNK files changed. Now target path will be handled.
— Changed: The drop-down menu for the Desktop button in the toolbar has been changed. Now no submenus are loaded. This avoids delays in starting of the program.
— Changed: Quick starter repository files now saved in UTF8 format
— Changed: Tab caption — UNC-paths are displayed with “1:” instead of the server name https://freecommander.com/forum/viewtopic.php?f=7&t=7244
— Changed: Freecommander.ini option “ThumbsNoClipCaption” can be defined now in the settings dialog: “Draw caption without clipping”
— Changed: Delete/Copy/Move with the option “Use Windows”: the message “The operation was canceled by user” is no more showed
— Implemented: New option in copy dialog “Use last overwrite options”
— Implemented: New drag&drop option “Start dragging on label or icon only”
— Implemented: Option for search dialog to define in the section [fcSearchForm] of the file FreeCommander.find.ini: OpenLocationChangeShortcut=1 if the shortcut should be changed from Ctrl+Space to Alt+Space
— Implemented: New action added “Collapse all nodes, except selected node, in the tree view”
— Implemented: NOT operator for quick filter: \~
— Implemented: Multirename — pattern for parent folder (level 1 to 9) added
— Implemented: “Customize action toolbars” dialog — quick filter added
— Implemented: Column profile definition — new option added: ‘All subfolder levels for columns: Files, Items, Folders’
— Implemented: Internal viewer — basic functions for image editing added
— Implemented: Favorite tools — if folder is defined as favorite tool, than parameters %RightDir%, %LeftDir%, %InactivDir% can be used if you want to open the folder not in the active pane
— Implemented: Quick filter popup menu — new item added: Clear edit field
— Implemented: Quick filter — click on quick filter button with pressed CTRL key: edit field will be cleared
— Implemented: Quick starter — context menu for the line added
— Implemented: Version checker form — frequency of checking can be set here too
— Implemented: Quick filter field — select all with Ctrl+A is now possible https://freecommander.com/forum/viewtopic.php?f=7&t=8612
— Implemented: New action added “Copy name without extension as text”
— Implemented: Delete operation (Windows) non blocking now
— Implemented: Viewer settings — ignore list added
— Implemented: Action for reverse quick filter added
— Implemented: Layout option “Ignore main window size and position” now is defined per layout and not global https://freecommander.com/forum/viewtopic.php?f=18&t=8369
— Implemented: “Settings — Shell menu” new option added “Apply to: Current user, All users”
— Implemented: Quick starter — quick filter field use the settings color now
— Implemented: New action added — Close duplicate Tabs
— Implemented: “Define favorite toolbars” dialog — “Duplicate” function added; Drag&drop for moving to another toolbar
— Implemented: Quick starter settings — item colors by file type
— Implemented: Quick starter — in “Repository -> Reorganize” function you will be asked, if non existing elements should be removed.
— Implemented: Switch view mode automatically on folder change — “Settings -> Column profiles/Automatic views”
— Implemented: If the favorite tree option “Full row select” is active, the double click (or click) will also work if the mouse is not over the name
— Implemented: Currently we can switch to the desired drive with Shift+drive-letter. If no root folder is active after switching, then using again Shift+drive-letter will switch to the root folder.
— Implemented: Quick starter settings — selection color added
— Implemented: Main menu items added “Edit -> Save selection” and “Edit -> Restore selection”
— Implemented: When navigating in the folder history (Alt + Left, Alt + Right), non-existent folders are ignored.
— Implemented: Searching duplicates
— Implemented: Multirename — new options for case processing “Upper first letter following any of defined characters:”, “Keep current case”
— Implemented: Possibility to define text label in the favorite toolbar
— Implemented: Search dialog — new option added “Open first profile on start”
— Implemented: Viewer — new option for images added “Show frames” (in the context menu of the picture)
— Implemented: Quick filter option now available in the settings dialog “Also use for folder names”
Download:
