Der “DRAM Calculator for Ryzen” hilft beim Übertakten des Arbeitsspeichers auf Plattformen mit AMDs Ryzen-Prozessoren, indem auf Basis der Daten des eingesetzten Arbeitsspeichers Vorschläge für die Einstellungen der Timings gemacht werden.
v1.5.0.5 (May 7th, 2019)
Fixed crash when you click “save settings” on Main tab
Fixed error in the names (RRDS / RRDL), tab MEMbench
Updated information in the tab “About”
Fixed AFR save preset (3200–3333mhz)
v1.5.0 (May 7th, 2019)
Main Changes
Added feature to compare current system timings with recommended ones. Turns on with the button “Compare timings”.
Added the ability to select the topology of the motherboard. Sheet box with the name “Topology”. The meaning of this undertaking is a more accurate prediction of procODT / RTT settings. Of course, the function is not perfect and with each update of the calculator the prediction accuracy will increase.
Partially cleaned the “Main” tab of information that is not used and clutters the user interface. This is a small advance towards the ease of use of this application.
SOC voltage prediction blocks have undergone significant changes for each generation of Ryzen processors.
Another recommendation is temporarily added to the CAD_BUS block.
Recycling of most presets for each type of memory. The reason is simple — new bios make new adjustments.
Block “Misc items” received new prediction algorithms. In particular, the GDM prediction.
Improved support for system configurations consisting of 4 DIMMs.
Improved algorithm for calculating profiles “Debug”.
Corrections of sudden crash programs in the calculations.
Fixed a problem when during the import of the html profile the memory type was automatically switched to Samsung b‑die mode.
Added button link to system setup guide using Ryzen DRAM Calculator. This button is located in the “Help” tab.
Updated information in the “About” tab and added feedback to me via Twitter.
Key features of MEMbench
Support for processors with 1 to 32 threads (temporary restrictions) .
Error within 0.5%.
Automatic determination of the number of threads in the system.
Unified rating for desktop and HEDT processors (AMD and Intel).
Qualitatively implemented multi-threading.
Thanks to the HCI 6 kernel (freeware), this product is free for the end user. I also want to note that this version is not modified (does not contain hacks).
Complete absence of the influence of the processor frequency on the benchmark result.
The result is affected by each timing (picture with themes, see below).
Ability to work in the mode of ordinary memory check with a fixed delayed stop at a certain stage and this stage is determined by you.
Four presets for benching “Easy mode”, “Default mode”, “Custom mode” and “Memtest”.
Easy mode is designed specifically for systems with a small amount of installed RAM.
Easy to use benchmark, you need to select only MEMbench mode and click “Run”.
Provision of full-fledged system information for the Ryzen processors (for Intel, the timing-determining block is not yet connected).
Ability to save two own results for further comparison.
Display information in the chart.
A window-table with information about the current state of benching or memory checking.
“Screenshot” Button
All possible protection against situations of low memory in the system.
