AMD Chipsatz-Treiber Adrenalin Edition 1.07.29 für Ryzen 3000
Mit der Adrenalin Edition 1.07.29 des Chipsatz-Treibers bietet AMD eine spezielle Version für die neuen Ryzen-Prozessoren der dritten Generation (“Matisse”) mit einem aktualisierten “AMD Ryzen Balanced” Energiesparplan, der einige aktuelle Probleme lösen soll.
Ein Changelog liegt nicht vor, aber in einem Blogeintrag erklärt AMD die Änderungen. Der Treiber liegt auch bislang nicht im normalen Supportbereich vor, sondern wurde nur über diesen Blogeintrag verlinkt.
We diagnosed and resolved the issue causing software monitoring tools to report high voltages and clockspeeds at the desktop with 3rd Gen AMD Ryzen Processors and the Windows® 10 May 2019 Update. Our analysis indicates that certain pieces of popular software, which are widely considered to be “low CPU load” applications, frequently make indirect requests for the highest performance and power state from the processor.Third Gen Ryzen is designed to be extremely responsive to requests for higher performance, and this has led to some of the anomalous behavior observed with high voltages and clockspeeds in monitoring utilities. Our solution is to adjust the AMD Ryzen Balanced power plan to address these cases under light loads, without changing the processor’s ability to respond to sustained workloads like games and content creation.
The solution is immediately available for download in a new chipset driver (version 1.07.29), including an updated AMD Ryzen Balanced power plan that delivers the fix. Users of previous generation AMD Ryzen™ Products do not need this plan, and the chipset driver installer will not provide it.
So you can see these changes in action, AMD Ryzen Master is also updated with new voltage and temperature reporting methodologies that more realistically demonstrate CPU behavior. Version 2.0.1.1233 (or later) reflects these changes and is now available for download as well.
Chipset Driver 1.07.29 also contains a beta workaround that resolves Destiny 2 application launch issues. This will ensure Destiny 2 players can immediately get back into the game.
Download: | AMD Chipsatz-Treiber Adrenalin Edition |
Version: | 1.7.29 |
Dateigröße | 50,82 MiB |
Veröffentlicht am: | 29.07.2019 |
Betriebssystem: | Windows 7/10 |
Lizenz: | - |
Webseite | AMD |
