Supermicro Now Offering AMD EPYC™ 7002 Series Processor-based Systems to Customers Who Want to Transform Their Data Centers
New Super­mi­cro H12 A+ Ser­vers Set World Record Bench­marks and Deli­ver Supe­ri­or Per­for­mance with AMD EPYC™ 7002 Series Processors
SAN JOSE, Calif., August 7, 2019 — Super Micro Com­pu­ter, Inc. (SMCI), a glo­bal lea­der in enter­pri­se com­pu­ting, sto­rage, net­wor­king solu­ti­ons, and green com­pu­ting tech­no­lo­gy, today laun­ched its first fami­ly of new H12 gene­ra­ti­on A+ Ser­vers opti­mi­zed to deli­ver a new level of inte­gra­ti­on and supe­ri­or per­for­mance for modern dat­a­cen­ters with AMD EPYC™ 7002 Series Processors.
Supermicro’s new H12 A+ ser­vers with the 2nd Gen AMD EPYC™ pro­ces­sors are expec­ted to deli­ver up to two times the per­for­mancei with dou­ble the core count com­pared to 1st Gen AMD EPYC™ pro­ces­sor-based sys­tems. With the­se new A+ Ser­vers, cus­to­mers can also expect impro­ved GPU acce­le­ra­tor per­for­mance as well as up to four times the peak FLOPS per socket.ii
Super­mi­cro deli­ver­ed world-record per­for­mance bench­marks on its new H12 A+ Ser­vers for both TPCx-IoT, and TPC-DS cate­go­ries. For TPCx-IoT, per­for­mance of 472200.88 IoTps was estab­lished on Supermicro’s H12 Twin­Pro™ 2U 4‑node ser­ver whe­re fas­ter IoT gate­way data ana­ly­tics are cri­ti­cal for the coming explo­si­on of IoT device num­bers. This is espe­ci­al­ly with the mas­si­ve band­width increase enab­led by 5G net­works. A new world record for TPC-DS was achie­ved using a Super­mi­cro H12 A+ BigT­win sys­tem. This ser­ver deli­vers the hig­hest per­for­mance and lowest per­for­mance per dol­lar for a 10TB data­ba­se with 64% hig­her Qph­DS through­put (Com­po­si­te Query per Hour Metric) and $0.05 savings per Qph­DS over the pre­vious world record holders.
“Supermicro’s indus­try-lea­ding H12 A+ ser­vers lever­aging AMD’s EPYC 7002 series pro­ces­sors pro­vi­de an ide­al com­bi­na­ti­on of fea­tures for modern data cen­ters inclu­ding robust vir­tua­liza­ti­on per­for­mance, up to 64 high-per­for­mance cores per socket, a maxi­mum of 128 threads per socket, and onboard disk con­trol­lers to miti­ga­te memo­ry access bot­t­len­ecks,” said Ismail Sayee­dud­din, Cor­po­ra­te Vice Pre­si­dent, Sales and Busi­ness Ope­ra­ti­ons. “Supermicro’s H12 A+ ser­vers are available in mul­ti­ple opti­mi­zed con­fi­gu­ra­ti­ons and sto­rage den­si­ties to address cus­to­mer requirements.”
“We’re exci­ted and thank­ful to have our part­ners sup­port­ing the launch of AMD EPYC 7002 Series Pro­ces­sors,” said Scott Aylor, cor­po­ra­te vice pre­si­dent and gene­ral mana­ger, Dat­a­cen­ter Solu­ti­ons Group, AMD. “Their EPYC based solu­ti­ons are poi­sed to deli­ver a new stan­dard for modern dat­a­cen­ter cus­to­mers. With twice the cores, breakth­rough per­for­mance and embedded secu­ri­ty fea­tures, all deli­ver­ed by a lea­der­ship archi­tec­tu­re, cus­to­mers can trans­form their dat­a­cen­ter ope­ra­ti­ons at the pace of their business.”
Fur­ther­mo­re, the­se new Super­mi­cro A+ Ser­vers offer increased data cen­ter agi­li­ty and respon­si­ve­ness with a com­pre­hen­si­ve and balan­ced fea­ture set of I/O, memo­ry, and secu­ri­ty capa­bi­li­ties. As the first gene­ra­ti­on of sys­tems with PCI‑E® 4.0 sup­port, the­se A+ Ser­vers fea­ture a lar­ge memo­ry foot­print of up to four tera­bytes (4TB) per socket run­ning fast DDR4 memo­ry up to 3200MHz.
Super­mi­cro offers an indus­try-lea­ding port­fo­lio of AMD EPYC™ based sys­tems and Ser­ver Buil­ding Block Solu­ti­ons®. From sin­gle-socket main­stream and WIO ser­vers to high-end Ultra ser­ver sys­tems and mul­ti-node sys­tems, inclu­ding BigT­win™ and Twin­Pro™, Super­mi­cro enables cus­to­mers to build appli­ca­ti­on-opti­mi­zed solu­ti­ons with a multi­tu­de of con­fi­gu­ra­ti­on possibilities.
The­se new 2nd Gen AMD EPYC™ pro­ces­sors are also socket com­pa­ti­ble with Super­mi­cro H11 gene­ra­ti­on sys­tems (drop-in sup­port for board rev 2.x). This pro­vi­des new and exis­ting cus­to­mers on the H11 gen sys­tems a fast upgrade track when PCI‑E® 4.0 sup­port is not a neces­si­ty. Exis­ting Super­mi­cro H11 solu­ti­ons are still uni­que­ly com­pe­ti­ti­ve in the mar­ket as they can sup­port up to DDR4-3200MHz memo­ry.iii
For com­ple­te infor­ma­ti­on on Super­mi­cro pro­ducts, visit www.supermicro.com.
Fol­low Super­mi­cro on Face­book and Twit­ter to recei­ve their latest news and announcements.
About Super Micro Com­pu­ter, Inc. (NASDAQ: SMCI)
Super­mi­cro (NASDAQ: SMCI), the lea­ding inno­va­tor in high-per­for­mance, high-effi­ci­en­cy ser­ver tech­no­lo­gy is a pre­mier pro­vi­der of advan­ced ser­ver Buil­ding Block Solu­ti­ons® for Data Cen­ter, Cloud Com­pu­ting, Enter­pri­se IT, Hadoop/Big Data, HPC and Embedded Sys­tems world­wi­de. Super­mi­cro is com­mit­ted to pro­tec­ting the envi­ron­ment through its “We Keep IT Green®” initia­ti­ve and pro­vi­des cus­to­mers with the most ener­gy-effi­ci­ent, envi­ron­men­tal­ly-fri­end­ly solu­ti­ons available on the market.
Super­mi­cro, Buil­ding Block Solu­ti­ons and We Keep IT Green are trade­marks and/or regis­tered trade­marks of Super Micro Com­pu­ter, Inc.
All other brands, names and trade­marks are the pro­per­ty of their respec­ti­ve owners.
Media Cont­act:
Greg Kaufman
pr@supermicro.com
SMCI‑F
i Pro­jec­tions as of July 3, 2019 for AMD EPYC pro­ces­sors using com­pu­ter mode­ling of pre­pro­duc­tion parts and SPE­Cra­te® 2017_int_base inter­nal test­ing results. Results may vary with pro­duc­tion sili­con test­ing. EPYC 7601 results as of June 2019 http://spec.org/cpu2017/results/res2019q2/cpu2017-20190411–11817.pdf. SPEC®, SPE­Cra­te® and SPEC CPU® are regis­tered trade­marks of the Stan­dard Per­for­mance Eva­lua­ti­on Cor­po­ra­ti­on. See www.spec.org for more infor­ma­ti­on. ROM-23
ii Esti­ma­ted gene­ra­tio­nal increase based upon AMD inter­nal design spe­ci­fi­ca­ti­ons for “Zen 2” com­pared to “Zen”. “Zen 2” has 2X the core den­si­ty of “Zen”, and when mul­ti­pli­ed by 2X peak FLOPs per core, at the same fre­quen­cy, results in 4X the FLOPs in through­put. Actu­al results with pro­duc­tion sili­con may vary.
iii Some sup­port­ed fea­tures and func­tion­a­li­ty of second gene­ra­ti­on AMD EPYC™ pro­ces­sors (code­na­med “Rome”) requi­re a BIOS update from your ser­ver manu­fac­tu­rer when used with a mother­board desi­gned for the first gene­ra­ti­on AMD EPYC 7000 series pro­ces­sor. A mother­board desi­gned for “Rome” pro­ces­sors is requi­red to enable all available func­tion­a­li­ty. ROM-06
