AMD Radeon Pro Software Enterprise Edition 19.Q4 für Linux
Nachdem AMD im Februar den Radeon Pro Software Enterprise 19.Q1-Treiber, im Mai den Radeon Pro Software Enterprise 19.Q2-Treiber und im August den Radeon Pro Software Enterprise Edition 19.Q3-Treiber vorgestellt hat, folgt nun pünktlich drei Monate später der Radeon Pro Software Enterprise Edition 19.Q4-Treiber.
Release Notes:
Fixed Issues
- Display issue with hot plug/unplug on Emulated display is now fixed.
- Pyroopencltest.hip Test may not pass in OpenCL mode on AMD FirePro™ W9000 and W2000 is fixed.
- Display issue seen with 1024x768 resolution virtual display creation using EDID is fixed.
Known Issues
- Display issue may occur with DVI passive dongles when emulated.
- Call trace may be observed on reboot after driver installation on SLED 15 operating system.
Packaged Driver Version
Radeon Pro Software for Enterprise 19.Q4 for Linux installation package contains the following:
- AMDGPU-Pro Driver and AMDGPU All-Open (base driver 19.30)
- ROCm Platform 1.6 in supported distributions.
Supported APIs
Radeon Pro Software for Enterprise 19.Q4 for Linux is designed to support the following APIs:
- OpenGL 4.5 and GLX 1.4
- OpenCL™ 1.2 (not supported for Radeon™ Pro WX 2100 and Radeon™ Pro WX 3100)
- Vulkan® 1.1
- VDPAU/VAAPI
Compatible Operating Systems
Radeon Pro Software for Enterprise 19.Q4 for Linux is designed to support the following Linux platforms:
- Red Hat® Enterprise Linux® 7.6 (64-bit version)
- CentOS 7.6 (64-bit version)
- Ubuntu® 18.04.2 (64-bit version)
- SLED/SLES 15 (64-bit version)
Download: | Radeon Pro Software for Enterprise |
Version: | 19Q4 |
Dateigröße | Verschieden |
Veröffentlicht am: | 12.11.2019 |
Betriebssystem: | RHEL 7.6 / CentOS 7.6 Ubuntu 18.04.2 SLED/SLES 15 |
Lizenz: | - |
Webseite | AMD |
