Dem vierteljährlichen Releaseschema folgend hat AMD den Radeon Pro Software Enterprise Edition 20.Q1-Treiber für Linux herausgebracht. AMD listet dabei folgende Distributionen als kompatibel: Red Hat Enterprise Linux 8.1, CentOS 8.1, Red Hat Enterprise Linux 7.7, CentOS 7.7, Ubuntu 18.04.2 und SLED/SLES 15.1.
Release Notes:
Fixed Issues
Call traces seen in Display message logs in RHEL 8.
User logout and login may cause segmentation fault in display message
Known Issues
When changing display resolution in multi GPU configuration with 8 displays, resolution may remain unchanged.
Segmentation fault may be observed in display message upon launching steam.
Packaged Driver Version
Radeon Pro Software for Enterprise 20.Q1 for Linux installation package contains the following:
AMDGPU-Pro Driver and AMDGPU All-Open (base driver 19.50)
ROCm Platform 1.6 in supported distributions.
Supported APIs
Radeon Pro Software for Enterprise 20.Q1 for Linux is designed to support the following APIs:
OpenGL 4.6 and GLX 1.4
OpenCL™ 2.0 (not supported for Radeon™ Pro WX 2100 and Radeon™ Pro WX 3100)
Vulkan® 1.2
VDPAU/VAAPI
Compatible Operating Systems
Radeon Pro Software for Enterprise 20.Q1 for Linux is designed to support the following Linux platforms:
