AMD Unveils Suite of New Radeon GPUs to Power High-Performance, Power-Efficient Gaming Laptops
AMD Rade­on RX 7000M Series Gra­phics deli­ver out­stan­ding per­for­mance-per-watt, sta­te-of-the-art visu­als and high-frame­ra­te gam­ing, with 26% hig­her per­for­mance on avera­ge than pre­vious gene­ra­ti­on; AMD Rade­on RX 7000S Series Gra­phics rede­fi­ne gam­ing per­for­mance for thin and light laptops
LAS VEGAS, Jan. 04, 2023 (GLOBE NEWSWIRE) — Today at CES 2023, AMD (NASDAQ: AMD) announ­ced the AMD Rade­on™ RX 7000 Series Gra­phics for Lap­tops. Built on the ground­brea­king AMD RDNA™ 3 archi­tec­tu­re, the new GPUs are desi­gned to deli­ver excep­tio­nal ener­gy effi­ci­en­cy and per­for­mance to power 1080p gam­ing at ultra set­tings and advan­ced con­tent crea­ti­on appli­ca­ti­ons on next-gene­ra­ti­on pre­mi­um laptops.
The new GPUs expand the recent­ly announ­ced AMD Rade­on RX 7000 Series Gra­phics fami­ly. The new AMD Rade­on RX 7000M Series Gra­phics offer out­stan­ding per­for­mance-per-watt while deli­ve­ring sta­te-of-the-art visu­als and high-FPS gam­ing, while the new AMD Rade­on RX 7000S Series Gra­phics maxi­mi­ze the effi­ci­en­ci­es of AMD RDNA 3 archi­tec­tu­re to deli­ver out­stan­ding per­for­mance at low power levels ide­al­ly sui­ted for thin and light laptops.
AMD Rade­on RX 7000 Series Gra­phics for Lap­tops offer up to 32 new uni­fied com­pu­te units, 32MB of second-gene­ra­ti­on AMD Infi­ni­ty Cache™ tech­no­lo­gy, 8GB of high-speed GDDR6 memo­ry with up to a 128-bit memo­ry inter­face, as well as dedi­ca­ted AI and ray­tra­cing hard­ware. In addi­ti­on, they sup­port AI-acce­le­ra­ted video enco­ding and hard­ware-acce­le­ra­ted AV1 enco­ding1AMD Fide­li­ty­FX™ Super Reso­lu­ti­on (FSR) and AMD Rade­on Super Reso­lu­ti­on (RSR) ups­ca­ling tech­no­lo­gies, advan­ced AMD smart tech­no­lo­gies, and other fea­tures that pro­vi­de visual­ly stun­ning, high-refresh rate gam­ing experiences.
The new pro­ducts expand our port­fo­lio of RDNA 3 archi­tec­tu­re-based GPUs and offer the ide­al blend of per­for­mance and power effi­ci­en­cy to let gamers enjoy their favo­ri­te games when on the go,” said Scott Her­kel­man, seni­or vice pre­si­dent and gene­ral mana­ger, Gra­phics Busi­ness Unit at AMD. “Modern games with incre­asing­ly life-like visu­als requi­re new levels of gra­phics hor­se­power, and we’re thril­led to offer a new fami­ly of GPUs allo­wing gamers to enjoy the most deman­ding games as they’re inten­ded to be expe­ri­en­ced whe­re­ver they are.”
AMD Rade­on RX 7000 Series Gra­phics for Laptops
Com­bi­ning per­for­mance, balan­ced power pro­files and pixel-per­fect visu­als, AMD Rade­on RX 7600M XT and Rade­on RX 7600M gra­phics rede­fi­ne lap­top gam­ing and con­tent crea­ti­on capa­bi­li­ties, brin­ging desk­top-class expe­ri­en­ces to mobi­le plat­forms. Enab­ling high frame­ra­tes with max set­tings for the latest lap­top dis­plays, AMD Rade­on RX 7600M XT gra­phics offer 26% hig­her per­for­mance on avera­ge than the pre­vious gene­ra­ti­on AMD Rade­on GPUs across sel­ect titles at 1080p2.
AMD Rade­on RX 7700S and Rade­on RX 7600S gra­phics rede­fi­ne gam­ing per­for­mance for thin-and-light lap­tops, pro­vi­ding serious hor­se­power for the latest games and con­tent crea­ti­on pro­jects, while ope­ra­ting at 100W or below. AMD Rade­on RX 7700S gra­phics enable high-frame­ra­te gam­ing and 29% hig­her per­for­mance on avera­ge than the pre­vious gene­ra­ti­on across sel­ect 1080p titles3. Key fea­tures of the new gra­phics offe­rings include:
  • AMD RDNA 3 Archi­tec­tu­re – New com­pu­te units share resour­ces bet­ween ren­de­ring, AI and ray­tra­cing to make the most effec­ti­ve use of each tran­sis­tor for fast, effi­ci­ent performance.
  • Dedi­ca­ted AI and Ray­tra­cing Acce­le­ra­ti­on – New AI acce­le­ra­tors and second-gene­ra­ti­on ray­tra­cing acce­le­ra­tors deli­ver incre­di­ble per­for­mance while maxi­mi­zing image quality.
  • High-Refresh Gam­ing – The new GPUs are desi­gned to deli­ver maxi­mum hor­se­power com­pared to com­pe­ti­ti­ve pro­ducts for a flu­id, high-refresh rate mobi­le gam­ing expe­ri­ence in the latest AAA and esports games.
  • AMD Radi­ance Dis­play™ Engi­ne – Pro­vi­des 12 bit-per-chan­nel color for up to 68 bil­li­on colors and hig­her refresh rate dis­plays com­pared to AMD RDNA 2 archi­tec­tu­re, and includes sup­port for Dis­play­Po­rt™ 2.1.
  • AV1 Enco­ding – Unlocks new mul­ti­me­dia expe­ri­en­ces with full AV1 encode sup­port, desi­gned for ultra-high defi­ni­ti­on reso­lu­ti­ons, wide color gamut, and HDR enhancements.
  • AMD Fide­li­ty­FX™ Super Reso­lu­ti­on tech­no­lo­gy (FSR) – Now available and upco­ming in 230 games4, FSR boosts frame­ra­tes in sup­port­ed games while deli­ve­ring incre­di­ble image quality.
Key spe­ci­fi­ca­ti­ons for the Rade­on RX 7000M Series and Rade­on RX 7000S Series Gra­phics can be found here.
AMD Advan­ta­ge™ Lap­tops and AMD Smart Technologies
AMD Advan­ta­ge-cer­ti­fied lap­tops are desi­gned to deli­ver the ulti­ma­te plat­form for gamers and crea­tors, offe­ring sta­te-of-the-art gam­ing expe­ri­en­ces with new levels of per­for­mance and respon­si­ve­ness. They com­bi­ne AMD Rade­on RX 6000M Series, Rade­on RX 6000S Series, Rade­on RX 7000M Series, or Rade­on RX 7000S Series Gra­phics, AMD Ryzen™ 5000 Series, Ryzen 6000 Series or Ryzen 7000 Series mobi­le pro­ces­sors, AMD Soft­ware: Adre­na­line Edi­ti­on™ appli­ca­ti­ons, and other advan­ced sys­tem design characteristics.
AMD Advan­ta­ge lap­tops also fea­ture AMD smart tech­no­lo­gies that ampli­fy per­for­mance, inclu­ding the new AMD SmartS­hift RSR tech­no­lo­gy. Expec­ted to be available in the first half of 2023, AMD SmartS­hift RSR intel­li­gent­ly dis­tri­bu­tes ren­de­ring, ups­ca­ling, and pre­sen­ta­ti­on demands bet­ween APU and GPU resour­ces to help deli­ver the best pos­si­ble performance.
Seve­ral lea­ding OEMs announ­ced plans to deli­ver AMD Advan­ta­ge Edi­ti­on lap­tops begin­ning in the first half of 2023, powered by the new AMD Rade­on RX 7000 Series Gra­phics and AMD Ryzen 7000 Series pro­ces­sors, inclu­ding new sys­tems by Ali­en­wa­re, ASUS, Emdoor and IP3.
Sup­port­ing Resources
  • Learn more about the AMD Rade­on RX 7000 Series Gra­phics for Lap­tops here
  • Learn more about AMD Advan­ta­ge here
  • Fol­low AMD on Lin­ke­dIn
  • Fol­low AMD on Twit­ter
About AMD
For 50 years AMD has dri­ven inno­va­ti­on in high-per­for­mance com­pu­ting, gra­phics and visua­liza­ti­on tech­no­lo­gies ― the buil­ding blocks for gam­ing, immersi­ve plat­forms and the dat­a­cen­ter. Hundreds of mil­li­ons of con­su­mers, lea­ding For­tu­ne 500 busi­nesses and cut­ting-edge sci­en­ti­fic rese­arch faci­li­ties around the world rely on AMD tech­no­lo­gy dai­ly to impro­ve how they live, work and play. AMD employees around the world are focu­sed on buil­ding gre­at pro­ducts that push the boun­da­ries of what is pos­si­ble. For more infor­ma­ti­on about how AMD is enab­ling today and inspi­ring tomor­row, visit the AMD (NASDAQ:AMD) web­site, blog, Face­book and Twit­ter pages.
CAUTIONARY STATEMENT
This press release con­ta­ins for­ward-loo­king state­ments con­cer­ning Advan­ced Micro Devices, Inc. (AMD) such as the fea­tures, func­tion­a­li­ty, per­for­mance, avai­la­bi­li­ty, timing and expec­ted bene­fits of AMD pro­ducts inclu­ding the AMD Rade­on™ RX 7000M Series Gra­phics, which are made pur­su­ant to the Safe Har­bor pro­vi­si­ons of the Pri­va­te Secu­ri­ties Liti­ga­ti­on Reform Act of 1995. For­ward-loo­king state­ments are com­mon­ly iden­ti­fied by words such as \“would,\” \“may,\” \“expects,\” \“belie­ves,\” \“plans,\” \“intends,\” \“pro­jects\” and other terms with simi­lar mea­ning. Inves­tors are cau­tio­ned that the for­ward-loo­king state­ments in this press release are based on cur­rent beliefs, assump­ti­ons and expec­ta­ti­ons, speak only as of the date of this press release and invol­ve risks and uncer­tain­ties that could cau­se actu­al results to dif­fer mate­ri­al­ly from cur­rent expec­ta­ti­ons. Such state­ments are sub­ject to cer­tain known and unknown risks and uncer­tain­ties, many of which are dif­fi­cult to pre­dict and gene­ral­ly bey­ond AMD’s con­trol, that could cau­se actu­al results and other future events to dif­fer mate­ri­al­ly from tho­se expres­sed in, or impli­ed or pro­jec­ted by, the for­ward-loo­king infor­ma­ti­on and state­ments. Mate­ri­al fac­tors that could cau­se actu­al results to dif­fer mate­ri­al­ly from cur­rent expec­ta­ti­ons include, wit­hout limi­ta­ti­on, the fol­lo­wing: Intel Corporation’s domi­nan­ce of the micro­pro­ces­sor mar­ket and its aggres­si­ve busi­ness prac­ti­ces; glo­bal eco­no­mic uncer­tain­ty; cycli­cal natu­re of the semi­con­duc­tor indus­try; mar­ket con­di­ti­ons of the indus­tries in which AMD pro­ducts are sold; loss of a signi­fi­cant cus­to­mer; impact of the COVID-19 pan­de­mic on AMD’s busi­ness, finan­cial con­di­ti­on and results of ope­ra­ti­ons; com­pe­ti­ti­ve mar­kets in which AMD’s pro­ducts are sold; quar­ter­ly and sea­so­nal sales pat­terns; AMD’s abili­ty to ade­qua­te­ly pro­tect its tech­no­lo­gy or other intellec­tu­al pro­per­ty; unfa­vorable cur­ren­cy exch­an­ge rate fluc­tua­tions; abili­ty of third par­ty manu­fac­tu­r­ers to manu­fac­tu­re AMD’s pro­ducts on a time­ly basis in suf­fi­ci­ent quan­ti­ties and using com­pe­ti­ti­ve tech­no­lo­gies; avai­la­bi­li­ty of essen­ti­al equip­ment, mate­ri­als, sub­stra­tes or manu­fac­tu­ring pro­ces­ses; abili­ty to achie­ve expec­ted manu­fac­tu­ring yields for AMD’s pro­ducts; AMD’s abili­ty to intro­du­ce pro­ducts on a time­ly basis with expec­ted fea­tures and per­for­mance levels; AMD’s abili­ty to gene­ra­te reve­nue from its semi-cus­tom SoC pro­ducts; poten­ti­al secu­ri­ty vul­nerabi­li­ties; poten­ti­al secu­ri­ty inci­dents inclu­ding IT outa­ges, data loss, data brea­ches and cyber-attacks; poten­ti­al dif­fi­cul­ties in upgrading and ope­ra­ting AMD’s new enter­pri­se resour­ce plan­ning sys­tem; uncer­tain­ties invol­ving the orde­ring and ship­ment of AMD’s pro­ducts; AMD’s reli­ance on third-par­ty intellec­tu­al pro­per­ty to design and intro­du­ce new pro­ducts in a time­ly man­ner; AMD’s reli­ance on third-par­ty com­pa­nies for design, manu­fac­tu­re and sup­p­ly of mother­boards, soft­ware and other com­pu­ter plat­form com­pon­ents; AMD’s reli­ance on Micro­soft and other soft­ware ven­dors’ sup­port to design and deve­lop soft­ware to run on AMD’s pro­ducts; AMD’s reli­ance on third-par­ty dis­tri­bu­tors and add-in-board part­ners; impact of modi­fi­ca­ti­on or inter­rup­ti­on of AMD’s inter­nal busi­ness pro­ces­ses and infor­ma­ti­on sys­tems; com­pa­ti­bi­li­ty of AMD’s pro­ducts with some or all indus­try-stan­dard soft­ware and hard­ware; cos­ts rela­ted to defec­ti­ve pro­ducts; effi­ci­en­cy of AMD’s sup­p­ly chain; AMD’s abili­ty to rely on third par­ty sup­p­ly-chain logi­stics func­tions; AMD’s abili­ty to effec­tively con­trol sales of its pro­ducts on the gray mar­ket; impact of govern­ment actions and regu­la­ti­ons such as export admi­nis­tra­ti­on regu­la­ti­ons, tariffs and trade pro­tec­tion mea­su­res; AMD’s abili­ty to rea­li­ze its defer­red tax assets; poten­ti­al tax lia­bi­li­ties; cur­rent and future claims and liti­ga­ti­on; impact of envi­ron­men­tal laws, con­flict mine­rals-rela­ted pro­vi­si­ons and other laws or regu­la­ti­ons; impact of acqui­si­ti­ons, joint ven­tures and/or invest­ments, inclu­ding acqui­si­ti­ons of Xilinx and Pen­san­do, on AMD’s busi­ness and AMD’s abili­ty to inte­gra­te acqui­red busi­nesses; impact of any impair­ment of the com­bi­ned company’s assets on the com­bi­ned company’s finan­cial posi­ti­on and results of ope­ra­ti­on; rest­ric­tions impo­sed by agree­ments gover­ning AMD’s notes, the gua­ran­tees of Xilinx’s notes and the revol­ving cre­dit faci­li­ty; AMD’s indeb­ted­ness; AMD’s abili­ty to gene­ra­te suf­fi­ci­ent cash to meet its working capi­tal requi­re­ments or gene­ra­te suf­fi­ci­ent reve­nue and ope­ra­ting cash flow to make all of its plan­ned R&D or stra­te­gic invest­ments; poli­ti­cal, legal, eco­no­mic risks and natu­ral dis­as­ters; future impairm­ents of good­will and tech­no­lo­gy licen­se purcha­ses; AMD’s abili­ty to attract and retain qua­li­fied per­son­nel; AMD’s stock pri­ce vola­ti­li­ty; and world­wi­de poli­ti­cal con­di­ti­ons. Inves­tors are urged to review in detail the risks and uncer­tain­ties in AMD’s Secu­ri­ties and Exch­an­ge Com­mis­si­on filings, inclu­ding but not limi­t­ed to AMD’s most recent reports on Forms 10‑K and 10‑Q.
Cont­act:
Geor­ge Millington
AMD Communications
(408) 547‑7481
George.Millington@amd.com
Suresh Bhas­ka­ran
AMD Inves­tor Relations
(408) 749‑2845
suresh.bhaskaran@amd.com
1 GD-176 – Video codec acce­le­ra­ti­on (inclu­ding at least the HEVC (H.265), H.264, VP9, and AV1 codecs) is sub­ject to and not ope­ra­ble wit­hout inclusion/installation of com­pa­ti­ble media players.
2 RM-102 – Test­ing done by AMD per­for­mance labs, Decem­ber 14, 2022, on a Refe­rence Sys­tem equip­ped with an AMD Ryzen 5 5600X and AMD Rade­on RX 7600M XT 16GB DDR4-3600MHz, Video Dri­ver 22.40 RCP 6, Win 11 ver­sus a Refe­rence Sys­tem equip­ped with an AMD Ryzen 5 5600X and AMD Rade­on RX 6600M 16GB DDR4-3600MHz, Video Dri­ver 22.40 RCP 6, Win 11. Tes­ted at 1080p on the fol­lo­wing games and settings:
Con­trol @ DX12 High, Cyber­punk 2077 @ DX12 Ultra, Hori­zon Zero Dawn @ DX12 Ulti­ma­te Qua­li­ty, Resi­dent Evil Vil­la­ge @ DX12 Max, The Wit­cher 3 @ DX11 Ultra, Sni­per Eli­te 5 @ DX12 Ultra, The Wit­cher 3 @ DX11 Ultra, Tiny Tina’s Won­der­lands @ DX12 Bad­ass. Sys­tem manu­fac­tu­r­ers may vary con­fi­gu­ra­ti­ons, yiel­ding dif­fe­rent results. Per­for­mance may vary.
3 RM-106 – Test­ing done by AMD per­for­mance labs, Decem­ber 14, 2022, on a Refe­rence Sys­tem equip­ped with an AMD Ryzen 5 5600X and AMD Rade­on RX 7700S, 16GB DDR4-3600MHz, Video Dri­ver 22.40 RCP 6, Win 11 ver­sus a Refe­rence Sys­tem equip­ped with an AMD Ryzen 5 5600X and AMD Rade­on RX 6700S, 16GB DDR4-3600MHz, Video Dri­ver 526.86, Win 11.
Tes­ted at 1080p on the fol­lo­wing games and set­tings: Assassin’s Creed Val­hal­la @ DX12 Ultra High, Bor­der­lands 3 @ DX12 Bad­ass, Cyber­punk 2077 @ DX12 Ultra, Death Stran­ding @ DX12 Very High, The Divi­si­on 2 @ DX12 Ultra, Far Cry 6 @ DX12 Ultra, Shadow of the Tomb Rai­der @ DX12 Hig­hest, Tiny Tina’s Won­der­lands @ DX12 Bad­ass. Sys­tem manu­fac­tu­r­ers may vary con­fi­gu­ra­ti­ons, yiel­ding dif­fe­rent results. Per­for­mance may vary.
4 As of Decem­ber 14, 2022
©2023 Advan­ced Micro Devices, Inc. All rights reser­ved. AMD, the AMD Arrow logo, AMD Advan­ta­ge, Adre­na­lin Edi­ti­on, Fide­li­ty­FX, Rade­on, RDNA, Ryzen, Smart Access Memo­ry, and com­bi­na­ti­ons the­reof are trade­marks of Advan­ced Micro Devices, Inc. Dis­play­Po­rt and the Dis­play­Po­rt logo are trade­marks owned by the Video Elec­tro­nics Stan­dards Asso­cia­ti­on (VESA®) in the United Sta­tes and other count­ries. Other pro­duct names used her­ein are for iden­ti­fi­ca­ti­on pur­po­ses and may be trade­marks of their respec­ti­ve owners.
