AMD EPYC Embedded Series Processors Power New HPE Alletra Storage MP Solution
AMD EPYC pro­ces­sors enable HPE to trans­form data life­cy­cle manage­ment with high-per­for­mance sca­le-out block and file sto­rage deli­ver­ed through HPE Green­La­ke
LAS VEGAS, June 21, 2023 (GLOBE NEWSWIRE) — AMD (NASDAQ: AMD) today announ­ced that its AMD EPYC™ Embedded Series pro­ces­sors are powe­ring Hew­lett Packard Enterprise’s new modu­lar, mul­ti-pro­to­col sto­rage solu­ti­on, HPE Alle­tra Sto­rage MP. AMD EPYC Embedded pro­ces­sors pro­vi­de the per­for­mance and ener­gy effi­ci­en­cy requi­red for enter­pri­se-class sto­rage sys­tems with high avai­la­bi­li­ty, resi­li­ence, and indus­try-lea­ding con­nec­ti­vi­ty and longevity.
The HPE Alle­tra Sto­rage MP sup­ports a dis­ag­gre­ga­ted infra­struc­tu­re with mul­ti­ple sto­rage pro­to­cols on the same hard­ware that can sca­le inde­pendent­ly for per­for­mance and capa­ci­ty. Con­fi­gura­ble for block and file stores, HPE Alle­tra Sto­rage MP gives cus­to­mers the abili­ty to deploy, mana­ge, and orchest­ra­te data and sto­rage ser­vices via the HPE Green­La­ke edge-to-cloud plat­form, regard­less of the workload and sto­rage pro­to­col. This eli­mi­na­tes data silos, redu­cing cost and com­ple­xi­ty while impro­ving performance.
  • Based on HPE Alle­tra MP, HPE Green­La­ke for File Sto­rage pro­vi­des a sca­le-out file ser­vice to acce­le­ra­te pro­ces­sing of data-inten­si­ve workloads through enter­pri­se per­for­mance at sca­le, with read through­put of hundreds of giga­bytes per second and bey­ond1.
  • An expan­ded HPE Green­La­ke for Block Sto­rage now pro­vi­des mis­si­on-cri­ti­cal resi­li­en­cy at midran­ge eco­no­mics with the industry’s first dis­ag­gre­ga­ted, sca­le-out block sto­rage with a 100% data avai­la­bi­li­ty gua­ran­tee. Deli­ver­ed and mana­ged via the HPE Green­La­ke plat­form, the new HPE Green­La­ke for Block Sto­rage lever­a­ges HPE Alle­tra Sto­rage MP and brings an intui­ti­ve cloud expe­ri­ence, effi­ci­ent sca­le, and extre­me resi­li­en­cy and per­for­mance to mis­si­on-cri­ti­cal apps and mixed workloads.
Data is rapidly incre­asing in volu­me and com­ple­xi­ty, crea­ting new chal­lenges for our cus­to­mers, who are try­ing to effec­tively and effi­ci­ent­ly store, mana­ge and pro­tect their data,” said Patrick Osbor­ne, seni­or vice pre­si­dent and gene­ral mana­ger, Cloud Data Infra­struc­tu­re, HPE Sto­rage. “The new HPE Alle­tra Sto­rage MP with AMD EPYC Series pro­ces­sors allow us to give cus­to­mers bet­ter pri­ce-for-per­for­mance today and the abili­ty to cost-effec­tively sca­le out infra­struc­tu­re on the same hard­ware in the future.”
EPYC Embedded Series pro­ces­sors com­bi­ne speed and effi­ci­en­cy which tog­e­ther are desi­gned to help redu­ce both over­all sys­tem ener­gy cos­ts and TCO. HPE Alle­tra Sto­rage MP uses a ran­ge of EPYC Embedded pro­ces­sor models, with per­for­mance opti­ons ran­ging from 16 to 64 cores, and a ther­mal design power pro­fi­le ran­ging from 155W to 225W.
We are proud of our expan­ded col­la­bo­ra­ti­on with HPE to pro­vi­de enter­pri­se cus­to­mers with advan­ced solu­ti­ons that can dri­ve bet­ter busi­ness out­co­mes, fas­ter,” said Raj­nee­sh Gaur, cor­po­ra­te vice pre­si­dent and gene­ral mana­ger, Embedded Pro­ces­sor Group, AMD. “Embedded EPYC pro­ces­sors enable HPE to usher in a new era in sto­rage with new levels of per­for­mance and I/O agi­li­ty in a power-opti­mi­zed profile.”
Sup­port­ing Resour­ces
About AMD
For more than 50 years AMD has dri­ven inno­va­ti­on in high-per­for­mance com­pu­ting, gra­phics and visua­liza­ti­on tech­no­lo­gies. Bil­li­ons of peo­p­le, lea­ding For­tu­ne 500 busi­nesses and cut­ting-edge sci­en­ti­fic rese­arch insti­tu­ti­ons around the world rely on AMD tech­no­lo­gy dai­ly to impro­ve how they live, work and play. AMD employees are focu­sed on buil­ding lea­der­ship high-per­for­mance and adap­ti­ve pro­ducts that push the boun­da­ries of what is pos­si­ble. For more infor­ma­ti­on about how AMD is enab­ling today and inspi­ring tomor­row, visit the AMD (NASDAQ: AMDweb­siteblogLin­ke­dIn and Twit­ter pages.
© 2023 Advan­ced Micro Devices, Inc. All rights reser­ved. AMD, the AMD Arrow logo, EPYC and com­bi­na­ti­ons the­reof are trade­marks of Advan­ced Micro Devices, Inc. Other pro­duct names used in this publi­ca­ti­on are for iden­ti­fi­ca­ti­on pur­po­ses only and may be trade­marks of their respec­ti­ve owners.
All per­for­mance and cost savings claims con­cer­ning HPE Green­La­ke are pro­vi­ded by HPE and have not been inde­pendent­ly veri­fied by AMD. Per­for­mance and cost bene­fits are impac­ted by a varie­ty of varia­bles. Results her­ein are spe­ci­fic to HPE and may not be typi­cal. GD-181
