ZT Systems Showcases XPO200 3U PCIe Expansion System Based on Microsoft’s Project Olympus and Featuring AMD Technology at OCP EU Summit 2018
AMSTERDAM–ZT Sys­tems, a lea­ding pro­vi­der of pur­po­se-built com­pu­te and sto­rage solu­ti­ons for hypers­ca­le dat­a­cen­ters, today show­ca­sed the new XPO200 3U PCIe Expan­si­on Sys­tem fea­turing AMD tech­no­lo­gy at the Open Com­pu­te EU Sum­mit. Based on Microsoft’s Pro­ject Olym­pus, this solu­ti­on lever­a­ges powerful AMD acce­le­ra­tors and pro­ces­sors in a fle­xi­ble Open Com­pu­te platform.
The XPO200 3U PCIe Expan­si­on Sys­tem with AMD tech­no­lo­gy is desi­gned to deli­ver out­stan­ding fle­xi­bi­li­ty, per­for­mance and value for GPU-inten­si­ve sca­le-out com­pu­ting and Vir­tu­al Desk­top Infra­struc­tu­re. With AMD Rade­on Instinct™ MI25 GPUs and AMD EPYC™ CPUs, this solu­ti­on is an attrac­ti­ve opti­on for an array of modern dat­a­cen­ter applications.
“ZT Sys­tems is plea­sed to part­ner with AMD in show­ca­sing this plat­form,” said Ray­mond Miles, ZT Sys­tems VP of Archi­tec­tu­re. “The XPO200 3U PCIe Expan­si­on Sys­tem with AMD tech­no­lo­gy deli­vers a com­pel­ling alter­na­ti­ve to help cus­to­mers tack­le today’s incre­asing­ly pre­va­lent AI and deep lear­ning workloads. Lever­aging the “known good” of Microsoft’s Pro­ject Olym­pus spe­ci­fi­ca­ti­on enab­led ZT to signi­fi­cant­ly acce­le­ra­te the deve­lo­p­ment of this plat­form, and pro­vi­des for stream­li­ned cus­to­miza­ti­on as neces­sa­ry to meet cus­to­mer requirements.
“AMD has a long-stan­ding com­mit­ment to the Open Com­pu­te Pro­ject and is exci­ted to see Microsoft’s Pro­ject Olym­pus plat­form, to which AMD was a signi­fi­cant ear­ly con­tri­bu­tor, gain the sup­port of ZT Sys­tems’ XPO200 3U PCIe Expan­si­on Sys­tem,” said Scott Aylor, cor­po­ra­te vice pre­si­dent, dat­a­cen­ter pro­ducts, AMD. “The com­bi­na­ti­on of AMD Rade­on Instinct™ GPU and the AMD EPYC™ CPU pro­ducts in this ZT Sys­tems solu­ti­on deli­vers out­stan­ding vir­tua­liza­ti­on den­si­ty and an excep­tio­nal com­bi­na­ti­on for exe­cu­ting AI and deep lear­ning workloads”
“This new ZT Sys­tems expan­si­on sys­tem brings a powerful com­bi­na­ti­on of AMD GPU and CPU tech­no­lo­gy to bear on deman­ding cloud workloads,” said Kus­ha­gra Vaid, Gene­ral Mana­ger and Distin­gu­is­hed Engi­neer, Azu­re Hard­ware Infra­struc­tu­re, Micro­soft Corp. “The speed and effi­ci­en­cy with which ZT deve­lo­ped this solu­ti­on demons­tra­tes why Microsoft’s Pro­ject Olym­pus spe­ci­fi­ca­ti­on is the lea­ding open source hard­ware stan­dard for next-gene­ra­ti­on dat­a­cen­ters. ZT Sys­tems con­ti­nues to demons­tra­te their abili­ty to rapidly deve­lop and deli­ver fle­xi­ble solu­ti­ons to the market.”
ZT Sys­tems XPO200 Ser­ver Solu­ti­ons com­bi­ne the ground­brea­king ener­gy effi­ci­en­cy, per­for­mance, ver­sa­ti­li­ty and cost effec­ti­ve­ness of Microsoft’s Pro­ject Olym­pus plat­form with ZT’s hypers­ca­le-focu­sed inte­gra­ti­on, sup­p­ly chain and deploy­ment capa­bi­li­ties. Cus­to­mers bene­fit from ZT’s uni­que expe­ri­ence deploy­ing plat­forms fea­turing the­se tech­no­lo­gies into real-world hypers­ca­le environments.
The XPO200 3U PCIe Expan­si­on Sys­tem with AMD tech­no­lo­gy and based on Microsoft’s Pro­ject Olym­pus can be seen at the Open Com­pu­te EU Sum­mit in Microsoft’s booth B1.
About ZT Systems
With over 24 years of expe­ri­ence, ZT Sys­tems is a lea­ding sup­pli­er of hypers­ca­le com­pu­te and sto­rage solu­ti­ons. Head­quar­te­red in Secau­cus, NJ, ZT’s glo­bal manu­fac­tu­ring spans the US, EMEA and APAC. A trus­ted design, manu­fac­tu­ring, and logi­stics part­ner, ZT ser­ves data cen­ter ope­ra­tors from enter­pri­se orga­niza­ti­ons to the lar­gest cloud pro­vi­ders. Through clo­se, con­fi­den­ti­al cus­to­mer enga­ge­ment, ZT lever­a­ges deep expe­ri­ence with hypers­ca­le workloads and sup­p­ly chain con­side­ra­ti­ons to deve­lop appli­ca­ti­on-tail­o­red solu­ti­ons. Fle­xi­ble, pur­po­se-built manu­fac­tu­ring capa­bi­li­ties enable ZT to sus­tain high qua­li­ty while accom­mo­da­ting the dyna­mic natu­re of hypers­ca­le. Inte­gra­ted rack-level solu­ti­ons are ship­ped world­wi­de with an indus­try-lea­ding deli­very SLA, and sup­port­ed with glo­bal ser­vice and RMA capa­bi­li­ties. ZT’s com­mit­ment to ope­ra­tio­nal excel­lence is demons­tra­ted by a strong track record of on-time delivery.
Learn more at ztsystems.com/ocp or cont­act us at 866–298-7089 / ocpsales@ztsystems.com.
