DRAM Calculator for Ryzen v1.4.1
Der “DRAM Calculator for Ryzen” hilft beim Übertakten des Arbeitsspeichers auf Plattformen mit AMDs Ryzen-Prozessoren, indem auf Basis der Daten des eingesetzten Arbeitsspeichers Vorschläge für die Einstellungen der Timings gemacht werden.
v1.4.1 (January 17th, 2019)
- Added a window with information about the minimum voltage for SOC
- Major updated presets for : samsung b‑die , samsung d/e‑die , hynix cjr , hynix mfr , hynix cjr (timings, voltages)
- Minor updated other presets (timings)
- Some corrections for debug profile
- Other corrections/bug fixes
Nuances
- In some presets tRC a multiple of tRFC (better stability and performance)
- Hynix MFR V2 profile has been deleted (many users had difficulty choosing the right profile)
- tWR’s basic recommendation is now 12 (this high timing timing adversely affects stability)
- RTT_NOM . Newer BIOS versions should not always have RZQ / 7 (34ohm), sometimes the RZQ/6(40ohm) or disabled has better stability
- CAD_BUS. AddrCMDDrvStr slightly increases with the frequency of the RAM, 24–30(ohm) are the optimal value.
- New bios allow a slight decrease in SOC voltage (that’s why I created a window with information about the minimum voltage)
Download: DRAM Calculator for Ryzen v1.4.1 — Win 10, 8, 7 (32 Bit & 64 Bit)
