Der “DRAM Calculator for Ryzen” hilft beim Übertakten des Arbeitsspeichers auf Plattformen mit AMDs Ryzen-Prozessoren, indem auf Basis der Daten des eingesetzten Arbeitsspeichers Vorschläge für die Einstellungen der Timings gemacht werden. Die Version 1.6.0.1 bietet nun Unterstützung für Prozessoren auf Basis von AMDs Zen 2 und für Mainboards mit X570-Chipsatz.
Changelog 1.6.0.1:
Added full support for Zen 2 and X570 motherboards.
Added recommendations for VDDG and FCLK for Zen 2.
Added recommendations for Vref (CHA / CHB).
The maximum frequency for 1:1 mode is now 3800 MHz, and for 2:1 mode — 4200.
Updated presets for Samsung b‑die, Hynix CJR and Micron e‑die.
Added backward compatibility of Zen 2 with previous generations of motherboards.
Added PMU Training recommendations for all Ryzen platforms. Better training — a more stable system.
Added autosave of the main tab settings when closing the program and automatically loading them when the program is started.
Improved tWRRD prediction for Dual Rank.
Color notification of voltage limits and FCLK. Black is the norm, red is the limit.
Timing detection for Zen and Zen + generations. For the generation Zen 2 at the moment there is no possibility to add a definition of timings due to NDA. Unfortunately.
Fixed a lack of presets for X399.
Fixed a rare error in which it was impossible to calculate the timings.
Added a button to access the Internet overclocking statistics generation Zen 2.
For users of Intel systems in the “Additional Calculators” section, it is possible to calculate tREFI and RTLIO‑L.
Added 2 new latency tests for MEMbench. Custom latency is a memory access test that the processor cannot predict (using a specific offset). Random latency — the average time is measured for random memory accesses in a buffer of a certain size. Partially affects the result of TLB. Both versions are release candidates, but I do not deny that there will be calibrations.
Custom latency and Random latency are included in the Easy and Default packages. Please note that during testing the program will open / close the prompt itself (you do not need to deal with it).
Added information about the size of the L3 cache processor. Also, the size of the test blocks for latency tests is controlled relative to it.
Added button Clear standby. There is to clean the cached memory by the operating system. Didn’t the test run? — Click Clear standby.
Max RAM button better determines the amount of free memory available for testing. Useful for checking memory for errors.
There are exceptions for many functions. Fault tolerance of the program increased.
